AC0201FR-07165KL
AC0201FR-07165KL
    YAGEO(国巨)
    贴片电阻 0201 165KΩ ±1% 1/20W ±200ppm/℃
AC0201FR-07165KL 数据手册
DATA SHEET SURFACE MOUNT MULTILAYER CERAMIC CAPACITORS Automotive grade NP0/X7R/X7S 6.3 V TO 2000 V Product Specification – April 16, 2022 V.18 0.2 pF to 680nF Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NPO/X7R/X7S 6.3 V to 2000 V SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER This specification describes Automotive grade chip capacitors with lead-free terminations and used for automotive equipments. All part numbers are identified by the series, size, tolerance, TC material, packing style, voltage, process code, termination and capacitance value. GLOBAL PART NUMBER AC APPLICATIONS All general purpose applications under normal operation and usage conditions for automotive equipments. XXXX X X XXX X (1) (2) (3) (4) B (5) X XXX (6) (7) (1) SIZE – INCH BASED (METRIC) 0201 (0603) / 0402 (1005) / 0603 (1608) / 0805 (2012) / 1206 (3216)/ 1210 (3225) / 1812 (4532) / 2220 (5750) (2) TOLERANCE FEATURES NPO(< 10 pF) NPO(≥ 10 pF) X7R/X7S  AEC-Q200 qualified  MSL class: MSL 1  AC series soldering is compliant with J-STD-020D  High component and equipment reliability  The capacitors are 100% performed by automatic optical inspection prior to taping. B = ± 0.1 pF F = ± 1% J = ± 5% C = ± 0.25 pF G = ± 2% K = ± 10% D = ± 0.5 pF J = ± 5% M = ± 20% Note: Capacitance tolerance ±5% doesn’t available for full X7R range, please contact local sale before order. (3) PACKING STYLE (SEE TABLE. 9 FOR DETAIL) R = Paper/PE taping reel; Reel 7 inch K = Blister taping reel; Reel 7 inch P = Paper/PE taping reel; Reel 13 inch F = Blister taping reel; Reel 13 inch (4) TC MATERIAL NPO X7R X7S (5) RATED VOLTAGE 5 = 6.3 V 6 = 10 V B = 500 V 7 = 16 V C = 1000 V D = 2000 V 8 = 25 V Z = 630 V 9 = 50 V 0 = 100 V A = 200 V Y = 250 V 6) PROCESS N = NPO B = X7R/X7S (7) CAPACITANCE VALUE 2 significant digits+number of zeros The 3rd digit signifies the multiplying factor, and letter R is decimal point Example: 121 = 12 x 101 = 120 pF www.yageo.com Apr. 16, 2022 V.18 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NPO/X7R/X7S 6.3 V to 2000 V CONSTRUCTION The capacitor consists of a rectangular block of ceramic dielectric in which a number of interleaved metal electrodes are contained. This structure gives rise to a high capacitance per unit volume. The inner electrodes are connected to the two end terminations and finally covered with a layer of plated tin (Matte Sn). The terminations are leadfree. A cross section of the structure is shown in Fig.1. terminations electrodes MLB457 ceramic material Fig. 1 Surface mounted multilayer ceramic capacitor construction OUTLINES DIMENSION Table 1 For outlines see fig. 2 For dimension see Table 1 TYPE L1 (mm) W (mm) T (MM) 0201 0.6± 0.03 0.3± 0.03 0402 1.0± 0.05 0603 0805 L2 / L3 (mm) L4 (mm) min. max. min. 0.3± 0.03 0.10 0.20 0.20 0.5 ± 0.05 0.5± 0.05 0.15 0.35 0.30 1.6± 0.10 0.8± 0.10 0.8± 0.10 0.20 0.60 0.40 2.0± 0.10 1.25± 0.10 0.25 0.75 0.70 2.0± 0.20 1.25± 0.20 3.2± 0.15 1.6± 0.15 0.25 0.75 1.40 0.25 0.75 1.40 0.25 0.75 2.20 0.25 0.75 2.20 0.25 0.75 3.40 0.6± 0.10 0.85± 0.10 1.25± 0.20 Fig. 2 Surface mounted multilayer ceramic capacitor dimension 0.6± 0.10 0.85± 0.10 1.00± 0.10 1206 3.2± 0.30 1.6± 0.20 1.15± 0.10 1.25± 0.20 1.6± 0.20 1210 1808 3.2± 0.30 1.6± 0.30 1.6± 0.30 3.2± 0.20 2.5± 0.20 3.2± 0.30 2.5± 0.20 3.2± 0.40 2.5± 0.30 2.5± 0.20 4.5± 0.40 2.0± 0.30 1.25± 0.20 0.85± 0.10 1.25± 0.20 1.6± 0.20 2.0± 0.20 0.85± 0.10 1812 4.5± 0.40 3.2± 0.30 1.25± 0.20 1.60± 0.20 2220 5.7± 0.40 5.0± 0.30 0.85 0.10 2.0±±0.20 1.25 ± 1.25 ± 0.20 0.20 1.6 ± 0.20 1.6 ± 0.20 www.yageo.com Apr. 16, 2022 V.18 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NPO/X7R/X7S 6.3 V to 2000 V CAPACITANCE RANGE & THICKNESS FOR NP0 Table 2 Sizes from 0201 to 0805 0201 CAP. 0402 0603 0805 0.2 pF 0.3± 0.03 0.47 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.56 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.68 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.82 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.0 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.2 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.5 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.8 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 2.2 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 2.7 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 3.3 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 3.9 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 4.7 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 5.6 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 6.8 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 8.2 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 10 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 12 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 15 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 18 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 22 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 27 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 33 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 39 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 47 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 56 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 68 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 82 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 100 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-12 series is on request www.yageo.com Apr. 16, 2022 V.18 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NPO/X7R/X7S 6.3 V to 2000 V CAPACITANCE RANGE & THICKNESS FOR NP0 Table 3 Sizes from 0402 to 0805 (continued) CAP. 0402 0603 0805 120 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 150 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 180 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 220 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 270 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 330 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 390 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 470 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 560 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.85± 0.1 0.85± 0.1 680 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.85± 0.1 0.85± 0.1 820 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.85± 0.1 0.85± 0.1 1.0 nF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.85± 0.1 0.85± 0.1 1.2 nF 0.8± 0.1 0.8± 0.1 0.85± 0.1 0.85± 0.1 1.5 nF 0.8± 0.1 0.8± 0.1 0.85± 0.1 0.85± 0.1 1.8 nF 0.8± 0.1 0.8± 0.1 0.85± 0.1 0.85± 0.1 2.2 nF 0.8± 0.1 0.8± 0.1 1.25± 0.2 1.25± 0.2 2.7 nF 0.8± 0.1 1.25± 0.2 1.25± 0.2 3.3 nF 0.8± 0.1 1.25± 0.2 1.25± 0.2 3.9 nF 0.8± 0.1 1.25± 0.2 1.25± 0.2 4.7 nF 0.8± 0.1 1.25± 0.2 1.25± 0.2 5.6 nF 0.8± 0.1 1.25± 0.2 1.25± 0.2 6.8 nF 0.8± 0.1 1.25± 0.2 1.25± 0.2 8.2 nF 0.8± 0.1 1.25± 0.2 1.25± 0.2 10 nF 0.8± 0.1 1.25± 0.2 1.25± 0.2 NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-12 series is on request www.yageo.com Apr. 16, 2022 V.18 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NPO/X7R/X7S 6.3 V to 2000 V CAPACITANCE RANGE & THICKNESS FOR NP0 Table 4 Sizes from 1206 to 1210 CAP. 1210 1206 50 V 100 V 200 V / 250 V 500 V 630 V 1000 V 2000 V 10 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 1.25± 0.2 12 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 15 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 18 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 1.25± 0.2 22 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 1.25± 0.2 27 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 1.25± 0.2 33 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 1.25± 0.2 39 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 1.25± 0.2 47 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 1.25± 0.2 56 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 68 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 82 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 100 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 120 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 150 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 180 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 220 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 270 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 330 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 390 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 470 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 560 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 680 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 820 pF 0.6± 0.1 0.6± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 1.0 nF 0.6± 0.1 0.6± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 1.2 nF 0.6± 0.1 0.6± 0.1 1.5 nF 0.6± 0.1 0.6± 0.1 1.8 nF 0.6± 0.1 2.2 nF 2.7 nF 50 V 100 V 200 V / 250 V 500 V 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 0.85± 0.1 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 0.85± 0.1 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 0.6± 0.1 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 1.25± 0.2 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 1.25± 0.2 NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-12 series is on request www.yageo.com Apr. 16, 2022 V.18 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NPO/X7R/X7S 6.3 V to 2000 V CAPACITANCE RANGE & THICKNESS FOR X7R/X7S Table 5 Sizes from 0201 to 0603 0201 CAP. 25V 0603 0402 50 V 10V 16 V 25 V 50 V 100 V 10V 16 V 25 V 50 V 100 V 1.0 nF 0.3± 0.03 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 1.5 nF 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 2.2 nF 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 3.3 nF 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 4.7 nF 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 6.8 nF 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 10 nF 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 15 nF 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 22 nF 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 33 nF 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 47 nF 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 68 nF 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 100 nF 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 150 nF 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 220 nF 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 330 nF 0.8± 0.1 0.8± 0.1 0.8± 0.1 470 nF 0.8± 0.1 0.8± 0.1 0.8± 0.1 680 nF 0.8± 0.1 0.8± 0.1 0.8± 0.1 100 pF 0.3± 0.03 0.3± 0.03 150 pF 0.3± 0.03 0.3± 0.03 220 pF 0.3± 0.03 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 330 pF 0.3± 0.03 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 470 pF 0.3± 0.03 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 680 pF 0.3± 0.03 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 (X7S) (X7S) (X7S) (X7S) NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-6 series is on request www.yageo.com Apr. 16, 2022 V.18 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NPO/X7R/X7S 6.3 V to 2000 V CAPACITANCE RANGE & THICKNESS FOR X7R Table 6 Size 0805 0805 CAP. 10 V 16 V 25 V 50 V 100 V 200 V / 250 V 500 V 1.0 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.5 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 2.2 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 3.3 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 4.7 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 6.8 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 10 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 15 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 22 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 33 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 47 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 68 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 100 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 150 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 220 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 330 nF 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 470 nF 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 680 nF 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 0.85± 0.1 1.25± 0.2 0.85± 0.1 1.25± 0.2 1.25± 0.2 1.25± 0.2 NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-6 series is on request www.yageo.com Apr. 16, 2022 V.18 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NPO/X7R/X7S 6.3 V to 2000 V CAPACITANCE RANGE & THICKNESS FOR X7R Table 7 Size 1206 1206 CAP. 6.3 V 10V 16V 25V 50 V 100 V 200 V / 250 V 500 V 630 V 1000 V 220 pF 1.25± 0.2 1.25± 0.2 1.25± 0.2 330 pF 1.25± 0.2 1.25± 0.2 1.25± 0.2 470 pF 1.25± 0.2 1.25± 0.2 1.25± 0.2 680 pF 1.25± 0.2 1.25± 0.2 1.25± 0.2 1 nF 1.25± 0.2 1.25± 0.2 1.25± 0.2 2.2 nF 1.25± 0.2 1.25± 0.2 4.7 nF 1.25± 0.2 1.25± 0.2 10 nF 1.25± 0.2 1.25± 0.2 22 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 33 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.60± 0.2 47 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.60± 0.2 68 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 1.60± 0.2 100 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 1.60± 0.2 150 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 1.25± 0.2 220 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 1.25± 0.2 330 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.60± 0.2 1.60± 0.2 470 nF 1.00± 0.1 1.00± 0.1 1.00± 0.1 1.00± 0.1 1.60± 0.2 1.60± 0.2 680 nF 1.15± 0.1 1.15± 0.1 1.15± 0.1 1.60± 0.2 1.60± 0.2 1.60± 0.2 Table 8 Size 1210 1812 1210 CAP. 6.3V 10 V 16 V 25 V 50V 100 V 200 V / 250 V 50V 100V 100 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 150 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 1.25± 0.2 220 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 1.25± 0.2 330 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 2.0± 0.2 470 nF 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 2.0± 0.2 1.60± 0.2 1.60± 0.2 680 nF 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 2.0± 0.2 1.60± 0.2 1.60± 0.2 NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-6 series is on request www.yageo.com Apr. 16, 2022 V.18 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NPO/X7R/X7S 6.3 V to 2000 V ELECTRICAL CHARACTERISTICS NP0/X7R DIELECTRIC CAPACITORS; NI/SIN TERMINATIONS Unless otherwise specified, all test and measurements shall be made under standard atmospheric conditions for testing as given in 5.3 of IEC 60068-1: - Temperature: 15 °C to 35 °C - Relative humidity: 25% to 75% - Air pressure: 86 kPa to 106 kPa Before the measurements are made, the capacitor shall be stored at the measuring temperature for a time sufficient to allow the entire capacitor to reach this temperature. The period as prescribed for recovery at the end of a test is normally sufficient for this purpose. Table 9 VALUE DESCRIPTION Capacitance range 0.2 pF to 680 nF Dissipation factor (D.F.) NPO C < 30 pF ≤ 1 / ( 400 + 20C ) C ≥ 30 pF X7R/X7S ≤ 0.1 % 0402 0603 0805 1206 1210 ≤10V 220pF to 220nF 1nF to 680nF 1nF to 680nF 22nF to 680nF 100nF to 680nF ≤ 5% 16V 220pF to 22nF 1nF to 220nF 1nF to 470nF 22nF to 680nF 100nF to 680nF ≤ 3.5% 27nF to 220nF 330nF to 680nF 680nF 220pF to 10nF 1nF to 39nF 1nF to 180nF 12nF to 27nF 47nF to 220nF 220nF 33nF to 100nF 330nF to 680nF 330nF to 680nF 100pF to 470nF FF 220pF to 10nF 1nF to 39nF 1nF to 180nF 47nF to 220nF 220nF to 470nF 25V 0201 100pF to 470pF 560pF to 10nF 50V 560pF to 1nF 12nF to 100nF 100V 560nF to 680nF 220pF to 1.5nF 1nF to 10nF 1nF to 100nF 12nF to 100nF 1812 ≤ 5% 22nF to 680nF 100nF to 680nF ≤ 2.5% ≤ 3.5% ≤ 5% 22nF to 470nF 100nF to 680nF 470nF to 680nF ≤ 2.5% ≤ 3.5% 680nF ≤ 5% 22nF to 470nF 100nF to 270nF 560nF to 680nF 330nF to 680nF ≤ 5% 100nF ≤ 2.5% 200V/250V 1nF to 22nF 22nF to 100nF 500V 1nF to 4.7nF 470nF to 680nF ≤ 2.5% 220pF to 10nF ≤ 2.5% 630V 220pF to 10nF ≤ 2.5% 1KV 220pF to 1nF ≤ 2.5% Insulation resistance after 1 minute at Ur (DC) NPO (general) X7R (general) 0603/25V/330nF to 680nF 0402/10V/>100nF 0402/16V/>100nF X7S (general) 0402/10V/>100nF 0402/16V/>100nF I.R. ≥ 100 GΩ or I.R. × C ≥ 1000 Ω.F. whichever is less I.R. ≥ 10 GΩ or I.R. × C ≥ 500 Ω.F. whichever is less I.R. X C ≥ 100 Ω.F. I.R. X C ≥ 50 Ω.F. I.R. X C ≥ 50 Ω.F. I.R. ≥ 1 GΩ or I.R. × C ≥ 100 Ω.F. whichever is less I.R. X C ≥ 50 Ω.F. I.R. X C ≥ 50 Ω.F. Operating temperature range: NP0/X7R/X7S –55 °C to +125 °C www.yageo.com Apr. 16, 2022 V.18 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NPO/X7R/X7S 6.3 V to 2000 V SOLDERING RECOMMENDATION Table 10 SOLDERING METHOD Reflow SIZE 0201 0402 Reflow only ≥ 0.1 µF ≥ 1.0 µF < 0.1 µF < 1.0 µF Reflow/Wave 0603 0805 1206 ≥ 1210 ≥ 2.2 µF ≥ 4.7 µF Reflow only < 2.2 µF < 4.7 µF --- SOLDERING CONDITIONS The lead free MLCCs are able to stand the reflow soldering conditions as below: Temperature: above 220 °C Endurance: 95 to 120 seconds Cycles: 3 times    The test of "soldering heat resistance" is carried out in accordance with the schedule of "MIL-STD-202G-method 210F", "The robust construction of chip capacitors allows them to be completely immersed in a solder bath of 260 °C for 10 seconds". Therefore, it is possible to mount MLCCs on one side of a PCB and other discrete components on the reverse (mixed PCBs). Surface Mount Capacitors are tested for solderability at 245 °C during 2 seconds. The test condition for no leaching is 260°C for 30 seconds. TESTS AND REQUIREMENTS Table 11 Test procedures and requirements NO AEC-Q200 TEST TEST METHOD Unpowered ; 1000hours @ T=150 °C REQUIREMENTS No visual damage Measurement at 24± 2 hours after test conclusion. ∆C/C NPO: Within ± 2.5% or 0.25 pF, whichever is greater X7R/X7S: Within ± 10% 1 High Temperature Exposure D.F.: within initial specified value IR: within initial specified value Preconditioning; 150 +0/–10 °C for 1 hour, then keep for 24 ± 1 hours at room temperature 2 Temperature Cycling 1000 cycles with following detail: 30 minutes at lower category temperature 30 minutes at upper category temperature Recovery time 24 ± 2 hours No visual damage ∆C/C NPO: Within ± 2.5% or 0.25 pF, whichever is greater X7R/X7S: ± 10% D.F. meet initial specified value IR meet initial specified value 3 Destructive Physical Analysis Electrical test not required. www.yageo.com Apr. 16, 2022 V.18 Product specification Surface-Mount Ceramic Multilayer Capacitors NO AEC-Q200 TEST Automotive grade NPO/X7R/X7S 6.3 V to 2000 V TEST METHOD T=24 hrs/per cycle; 10 continuous cycles unpowered. Measurement at 24 ± 2 hours after test condition. REQUIREMENTS No visual damage ∆C/C NPO: Within ± 3% or 3 pF, whichever is greater X7R/X7S: ± 15% D.F. Within initial specified value IR Meet initial specified value 4 Moisture Resistance Fig. 3 Moisture resistant 1. Preconditioning, class 2 only: 150 +0/-10 °C /1 hour, then keep for 24 ± 1 hour at room temp 2. Initial measure: Spec. refer to initial spec. C. D. I.R. Note: Series with 100 KΩ 5 Biased Humidity 3. Test condition: 85 °C, 85% R.H. connected with 100 KΩ resistor, applied 1.5V/Ur (no more than 630V) for 1,000 hours. 4. Recovery: NPO: 6 to 24 hours X7R/X7S: 24 ± 2 hours 5. Final measure: C. D. I.R. No visual damage after recovery ∆C/C NPO: Within ± 2% or 1 pF, whichever is greater X7R/X7S: ± 15% D.F. NPO: ≤ 2 x specified value. X7R/X7S: (1) ≤ 16V: ≤ 7% or specified value whichever is greater (2) ≥ 25V: ≤ 5% or specified value whichever is greater I.R. The insulation resistance shall greater than 10% of initial spec. www.yageo.com Apr. 16, 2022 V.18 Product specification Surface-Mount Ceramic Multilayer Capacitors NO AEC-Q200 TEST Automotive grade NPO/X7R/X7S 6.3 V to 2000 V TEST METHOD 1. Preconditioning, class 2 only: 150 +0/-10 °C /1 hour, then keep for 24 ± 1 hour at room temp 2. Initial measure: Spec: refer to initial spec C, D, IR 3. Endurance test: Temperature: 125 °C Specified stress voltage applied for 1,000 hours: 6 No visual damage ∆C/C NPO: Within ± 2% or 1 pF, whichever is greater X7R/X7S: ± 15% D.F. NPO: ≤ 2 x specified value. Applied 2.0 x Ur for general products * X7R/X7S: High voltage series follows with below (1) ≤ 16V: ≤ 7% or specified stress condition: value whichever is greater Applied 1.5 x Ur for 200V, 250V series High Temperature Operational Life REQUIREMENTS Applied 1.3 x Ur for 500V, 630V series Applied 1.2 x Ur for 1KV, 2KV, 3KV series (2) ≥ 25V: ≤ 5% or specified value whichever is greater IR 4. Recovery time: 24 ± 2 hours NPO: ≥ 4,000 MΩ or IR x Cr ≥ 5. Final measure: C, D, IR 40Ω.F. whichever is less X7R/X7S: ≥ 1,000 MΩ or Note: If the capacitance value is less than the minimum value IRx Cr ≥ 50Ω.F. permitted, then after the other measurements have been whichever is less * made the capacitor shall be preconditioned according to “IEC * IRx Cr ≥ 5Ω.F. 60384 4.1” and then the requirement shall be met. * Applied 1.5 x Ur 0402/X7S/10V~16V/>100nF 0402/10V-16V/>100nF * IRx Cr ≥ 10Ω.F. 0603/25V/>220nF 0402/X7R/50V/>10nF 0603/X7R/25V/>220nF; 0603/X7R/50V/220nF 0603/X7R/100V/≥100nF 0805/X7R/100V/≥ 470nF 7 External Visual 8 Physical Dimension 9 Mechanical Shock Any applicable method using × 10 magnification In accordance with specification Verify physical dimensions to the applicable device In accordance with specification specification. Three shocks in each direction shall be applied along the three ∆C/C mutually perpendicular axes of the test specimen NPO: Within ± 0.5% or 0.5 pF, (18 shocks) whichever is greater Peak value: 1,500 g’s X7R/X7S: ± 10% Duration: 0.5 ms Velocity change: 15.4 ft/s Waveform: Half-sin D.F. Within initial specified value IR Within initial specified value www.yageo.com Apr. 16, 2022 V.18 Product specification Surface-Mount Ceramic Multilayer Capacitors NO AEC-Q200 TEST Automotive grade NPO/X7R/X7S 6.3 V to 2000 V TEST METHOD REQUIREMENTS 5 g’s for 20 minutes, 12 cycles each of 3 orientations. ∆C/C Test from 10-2000 Hz. NP0: Within ± 0.5% or 0.5 pF, whichever is greater 10 X7R/X7S: ± 10% Vibration D.F: meet initial specified value IR meet initial specified value Precondition: 150 +0/–10 °C for 1 hour, then keep for 24 ± 1 Dissolution of the end face hours at room temperature plating shall not exceed 25% of Preheating: for size ≤ 1206: 120 °C to 150 °C for 1 minute the length of the edge Preheating: for size >1206: 100 °C to 120 °C for 1 minute and concerned 170 °C to 200 °C for 1 minute 11 Resistance to Soldering Heat Solder bath temperature: 260± 5 °C ∆C/C Dipping time: 10± 0.5 seconds NPO: Within ± 1% or 0.5 pF, Recovery time: 24± 2 hours whichever is greater. X7R/X7S: ± 10% D.F. within initial specified value IR within initial specified value 1. Preconditioning, class 2 only: No visual damage 150 +0/-10 °C /1 hour, then keep for 24± 1 hour at room temp 2. Initial measure: Spec: refer to initial spec C, D, IR ∆C/C NPO: Within ± 1% or 1 pF, whichever is greater 3. Rapid change of temperature test: 12 Thermal Shock -55 °C to +125 °C; 300 cycles 15 minutes at -55°C ; 15 minutes at 125 °C 4. Recovery time: NPO: 6 to 24 hours X7R/X7S: ± 15% D.F: meet initial specified value IR meet initial specified value X7R/X7S 24± 2 hours 5. Final measure: C, D, IR www.yageo.com Apr. 16, 2022 V.18 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NPO/X7R/X7S 6.3 V to 2000 V Per AEC-Q200-002 A component passes a voltage level if all components stressed at that voltage level pass. YNM0053-1 6 kV DC FAIL PASS 2 kV DC FAIL 13 ESD 12 kV AD PASS 1 kV DC FAIL 4 kV DC PASS 500 V DC FAIL FAIL 1 kV DC FAIL 2 kV DC PASS 8 kV DC PASS 4 kV DC FAIL 16 kV AD PASS 6 kV DC FAIL 8 kV DC 12 kV AD PASS < 500 V DC PASS 25 kV AD FAIL 500 V DC PASS 16 kV AD 25 kV AD Note: Classify the components according to the highest ESD voltage level survived during ESD testing. Fig. 4 Passive component HBM ESD test flow diagram (DC = Direct Contact Discharge, AD = Air Discharge) The solder should cover over 1. Preheat at 155°C for 4 hours. After preheating, immerse the capacitor in a solution of ethanol and rosin (25% rosin in 95% of the critical area of each termination. weight proportion). Immerse in eutectic solder solution for 5+0/-0.5 seconds at 235± 5°C. 2. Should be placed into steam aging for 8 hours± 15 minutes. After preheating, immerse the capacitor in a solution of 14 Solderability ethanol and rosin (25% rosin in weight proportion). Immerse in eutectic solder solution for 5+0/-0.5 seconds at 235± 5°C. 3. Should be placed into steam aging for 8 hours± 15 minutes. After preheating, immerse the capacitor in a solution of Ethanol and rosin (25% rosin in weight proportion). Immerse in eutectic solder solution for 120± 5 seconds at 260± 5°C. www.yageo.com Apr. 16, 2022 V.18 Product specification Surface-Mount Ceramic Multilayer Capacitors 15 Automotive grade NPO/X7R/X7S 6.3 V to 2000 V Within specified tolerance Capacitance NPO: f = 1 MHz for C ≤ 1nF, measuring at voltage 1 Vrms at 25 °C f = 1 KHz for C > 1nF, measuring at voltage 1 Vrms at 25 °C X7R/X7S: At 25 °C, 24 hours after annealing f = 1± 0.1 KHz, measuring at voltage 1± 0.1 Vrms at 25 °C In accordance with specification on Table 9 Dissipation Factor (D.F.) NPO: f = 1 MHz for C ≤ 1nF, measuring at voltage 1 Vrms at 25 °C f = 1 KHz for C > 1nF, measuring at voltage 1 Vrms at 25°C X7R/X7S: At 25 °C, 24 hours after annealing f = 1± 0.1 KHz, measuring at voltage 1± 0.1 Vrms at 25 °C Insulation Resistance (I.R.) At Ur (DC) for 1 minute In accordance with specification on Table 9 Capacitance shall be measured by the steps shown in the following table. ∆C/C NPO: ± 30ppm /°C The capacitance change should be measured after 5 min at each specified temperature stage. X7R: ± 15% Electrical Characterization Temperature coefficient Step Temperature(°C) a 25± 2 b Lower temperature± 3°C c 25± 2 d Upper Temperature± 2°C e 25± 2 X7S: ± 22% (1) NPO Temperature Coefficient shall be calculated from the formula as below C2 - C1 Temp, Coefficient = 10 6 [ppm/°C] C1xΔT C1: Capacitance at step c C2: Capacitance at 125°C ∆T: 100°C (=125°C -25°C) (2) X7R/X7S Capacitance Change shall be calculated from the formula as below ∆C = C2 - C1 x 100% C1 C1: Capacitance at step c C2: Capacitance at step b or d Voltage Proof 1. Specified stress voltage applied for 1~5 seconds 2. Ur ≤ 100 V: series applied 2.5 Ur 3. 100 V < Ur ≤ 200 V series applied (1.5 Ur + 100) 4. 200 V < Ur ≤ 500 V series applied (1.3 Ur + 100) 5. Ur > 500 V: 1.3 Ur 6. Ur ≥ 1000 V: 1.2 Ur Charge/Discharge current is less than 50 mA No breakdown or flashover www.yageo.com Apr. 16, 2022 V.18 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NPO/X7R/X7S 6.3 V to 2000 V Part mounted on a 100mm × 40mm FR4 PCB board, which is 1.6± 0.2 mm thick and has a layer-thickness 35µm± 10 µm. Part should be mounted using the following soldering reflow profile. Conditions: No visual damage ∆C/C NPO: Within ± 1% or 0.5 pF, whichever is greater X7R/X7S: ± 10% NPO: Bending 3 mm at a rate of 1 mm/s, radius jig 340 mm X7R/X7S: Bending 2 mm at a rate of 1 mm/s, radius jig 340 mm 16 Board Flex Dimension(mm) Test Substrate: b C 4.5 YNSC147 40 Terminal Strength c 0201 0.3 0.9 0.3 0402 0.4 1.5 0.5 0603 1.0 3.0 1.2 1.2 4.0 1.65 1206 2.2 5.0 1.65 100 1210 2.2 5.0 2.0 1808 3.5 7.0 3.7 With the component mounted on a PCB obtained with the device to be tested, apply a 17.7N (1.8Kg) force to the side of a device being tested. This force shall be applied for 60+1 seconds. Also the force shall be applied gradually as not to apply a shock to the component being tested. Place the part in the beam load fixture. Apply a force until the part breaks or the minimum acceptable force level required in the user specification(s) is attained. Beam Load Test b 0805 * Apply 2N force for 0402 size. * Apply 1N force for 0201 size. 18 a a unit: mm 17 Type Magnification of 20X or greater may be employed for inspection of the mechanical integrity of the device body, terminals and body/terminal junction. Before, during and after the test, the device shall comply with all electrical requirements stated in this specification. ≤ 0805 Thickness > 0.5mm: 20N Thickness ≤ 0.5mm: 8N ≥ 1206 Thickness ≥1.25 mm: 54N Thickness < 1.25 mm: 15N www.yageo.com Apr. 16, 2022 V.18 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NPO/X7R/X7S 6.3 V to 2000 V THICKNESS CLASSES AND PACKING QUANTITY Table 12 SIZE CODE THICKNESS CLASSIFICATION PACKING CODE 7 INCH 13 INCH QUANTITY PER REEL TAPE WIDTH Ø 180 MM / 7 INCH Paper Blister Ø 330 MM / 13 INCH Paper Blister 0201 0.3 ± 0.03 mm R P 8 mm 15,000 --- 50,000 --- 0402 0.5 ± 0.05 mm R P 8 mm 10,000 --- 50,000 --- 0603 0.8 ± 0.1 mm R P 8 mm 4,000 --- 15,000 --- 0.6 ± 0.1 mm R P 8 mm 4,000 --- 20,000 --- 0.85 ± 0.1 mm R P 8 mm 4,000 --- 15,000 --- 1.25 ± 0.2 mm K F 8 mm --- 3,000 --- 10,000 0.6 ± 0.1 mm R P 8 mm 4,000 --- 20,000 --- 0.85 ± 0.1 mm R P 8 mm 4,000 --- 15,000 --- 1.0/1.15 ± 0.1 mm K F 8 mm --- 3,000 --- 10,000 1.25 ± 0.2 mm K F 8 mm --- 3,000 --- 10,000 1.60 ± 0.2 mm K F 8 mm --- 2,000 --- 8,000 0.85 ± 0.1 mm K F 8 mm --- 4,000 --- 10,000 1.15 ± 0.1 mm K F 8 mm --- 3,000 --- 10,000 1.25 ± 0.2 mm K F 8 mm --- 3,000 --- 10,000 2.0 ± 0.2 mm K 8 mm --- 2,000 --- --- 2.5 ± 0.2 mm K 8 mm --- 1,000 --- --- 0.6 / 0.85± 0.1 mm K 12 mm --- 2,000 --- --- 1.15± 0.1 mm K 12 mm --- 1,000 --- --- 1.25± 0.2 mm K 12 mm --- 1,000 --- --- 1.6 ± 0.2 mm K 12 mm --- 2,000 --- --- 0805 1206 1210 1812 www.yageo.com Apr. 16, 2022 V.18 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NPO/X7R/X7S 6.3 V to 2000 V PAPER/PE TAPE SPECIFICATION Fig. 5 Paper/PE tape Table 13 Dimensions of paper/PE tape for relevant chip size; see Fig.5 SIZE Unit: mm SYMBOL CODE A0 B0 W E F 0201 0.39 ± 0.06 0.70 ± 0.06 8.0 ± 0.20 1.75 ± 0.1 0402 0.70 ± 0.15 1.21 ± 0.12 8.0 ± 0.20 0603 1.05 ± 0.14 1.86 ± 0.13 0805 1.50 ± 0.15 1206 1.90 ± 0.15 P0 (1) P1 P2 Ø D0 K0 T 3.50 ± 0.05 4.0 ± 0.05 2.0 ± 0.05 2.0 ± 0.05 1.55 ± 0.03 0.38 ± 0.05 (0.47 / 0.55)±0.10 1.75 ± 0.1 3.50 ± 0.05 4.0 ± 0.05 2.0 ± 0.05 2.0 ± 0.05 1.50 +0.1 /-0 (0.75 / 0.60)±0.10 (0.85 / 0.70)±0.10 8.0 ± 0.20 1.75 ± 0.1 3.50 ± 0.05 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.50 +0.1 /-0 (1.05 / 0.95 / 0.75)±0.10 (1.15 / 1.05 / 0.85)±0.10 2.26 ± 0.20 8.0 ± 0.20 1.75 ± 0.1 3.50 ± 0.05 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.50 +0.1 /-0 (1.05 / 0.95 / 0.75)±0.10 (1.15 / 1.05 / 0.85)±0.10 3.50 ± 0.20 8.0 ± 0.20 1.75 ± 0.1 3.50 ± 0.05 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.50 +0.1 /-0 (0.95 / 0.75)±0.10 (1.05 / 0.85)± 0.10 NOTE 1. P0 pitch tolerance over any 10 pitches is 0.2 mm www.yageo.com Apr. 16, 2022 V.18 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NPO/X7R/X7S 6.3 V to 2000 V BLISTER TAPE SPECIFICATION P0 D0 K0 P2 E F cover tape W B0 A0 T2 SCM015 D1 P1 K0: so chosen that the orientation of the component cannot change For W = 8 mm: T2 = 3.5 mm max. For W = 12 mm: T2 = 6.5 mm max. direction of unreeling Fig. 6 Blister tape Table 14 Dimensions of blister tape for relevant chip size; see Fig.6 SYMBOL SIZE A0 B0 CODE Unit: mm K0 W E F Min. Max. Min. Max. Min. Max. Ø D0 Ø D1 P0 (2) P1 P2 T2 Min. Min. Max. 0805 1.29 1.65 2.09 2.60 1.25 1.62 8.1 ± 0.20 1.75 ± 0.1 3.5 ± 0.05 1.5 +0.1/-0.0 1 +0.1/-0.0 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.30 1.67 1206 1.65 2.12 3.30 3.75 1.22 2.15 8.1 ± 0.20 1.75 ± 0.1 3.5 ± 0.05 1.5 +0.1/-0.0 1 +0.1/-0.0 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.27 2.20 1210 2.55 3.02 3.31 3.88 0.97 2.92 8.1 ± 0.20 1.75 ± 0.1 3.5 ± 0.05 1.5 +0.1/-0.0 1 +0.1/-0.0 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.02 2.97 1808 2.05 2.55 4.80 5.45 1.30 2.45 12.1 ± 0.20 1.75 ± 0.1 5.5 ± 0.05 1.5 +0.1/-0.0 1.5 +0.1/-0.0 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.35 2.50 1812 3.35 3.75 4.70 5.33 0.70 2.40 12.1 ± 0.20 1.75 ± 0.1 5.5 ± 0.05 1.5 +0.1/-0.0 1.5 +0.1/-0.0 4.0 ± 0.10 8.0 ± 0.10 2.0 ± 0.05 0.75 2.45 NOTE 1. Typical capacitor displacement in pocket 2. P0 pitch tolerance over any 10 pitches is ±0.2 mm www.yageo.com Apr. 16, 2022 V.18 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NPO/X7R/X7S 6.3 V to 2000 V REEL SPECIFICATION W2 C N A HBK039 W1 Fig. 7 Reel Table15 Reel dimensions; see Fig.7 TAPE WIDTH SYMBOL Unit: mm A N C W1 W2max. 8 (Ø 178 mm/7") 178 ± 1.0 60 ± 1.0 13 +0.50/-0.20 9.4 ± 1.5 14.4 8 (Ø 330 mm/13") 330 ± 1.0 100 ± 1.0 13 +0.50/-0.20 9.0 ± 0.2 14.4 12 (Ø 178 mm/7") 178 ± 1.0 60 ± 1.0 13 +0.50/-0.20 13.4 ± 1.5 18.4 P ROPERTIES OF REEL Material: polystyrene Surface resistance: 100 °C). Therefore, it is advised to use the smallest possible size and follow the dimensional recommendations given in Tables 8, 9 and 10 for reflow and wave soldering. More detailed information is available on request. Solid line: Typical process (terminal temperature) Dotted lines: Process limits - bottom process limit (terminal temperature) & upper process limit (top surface temperature). Fig. 8 Infrared soldering, forced gas convection reflow soldering - Temperature/time profile for SnPb solders www.yageo.com Apr. 16, 2022 V.18 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NPO/X7R/X7S 6.3 V to 2000 V 300 YNM0016 10 s max. T (C) 260 C 255 C 245 C 250 220 C 200 180 C Preheating ca. 45~90 s > 220 C 150 C 150 Typical Ramp down rate < 6 C/s 100 Ramp up rate < 3 C/s 50 0 0 50 100 150 200 250 300 350 400 t (s) Solid line: Typical process (terminal temperature) Dotted lines: Process limits - bottom process limit (terminal temperature) & upper process limit (top surface temperature). Fig. 9 Infrared soldering, forced gas convection reflow soldering - Temperature/time profile for lead-free SnAgCu solders 300 T 10 s max., max. contact time 5 s per wave (C) 235 C to 260 C (SnPb) 250 C to 260 C (SnAgCu) 250 second wave cooling first wave 200 YNM0017 Preheating ca. 2 C/s T < 150 C ca. 3.5 C/s typical 150 ca. 5 C/s 130 C 120 C 100 C 100 Typical 50 0 0 50 100 150 200 t (s) 250 Solid line: Typical process Dotted lines: Process limits Fig. 10 Double wave soldering for SnPb and lead-free SnAgCu solder - Temperature/time profile (terminal temperature) www.yageo.com Apr. 16, 2022 V.18 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NPO/X7R/X7S 6.3 V to 2000 V FOOTPRINT DIMENSIONS D C G B A F preferred direction during wave soldering solder land / solder paste pattern solder resist pattern occupied area MBG628-1 Fig. 11 Discrete capacitors recommended dimensions of footprint Table 17 Reflow soldering; for footprint dimensions see Fig.11 Unit: mm SIZE FOOTPRINT DIMENSIONS B C CODE A D F G 0201 0.8 ± 0.20 0.25 ± 0.05 0.28 ± 0.07 0.3 ± 0.10 --- --- 0402 1.5 ± 0.15 0.5 ± 0.15 0.5 ± 0.15 0.5 ± 0.15 1.75 ± 0.15 0.95 ± 0.15 0603 2.3 ± 0.15 0.7 ± 0.15 0.8 ± 0.15 0.9 ± 0.15 2.7 ± 0.15 1.5 ± 0.15 0603 2.3 ± 0.25 0.5 ± 0.25 0.9 ± 0.25 0.9 ± 0.25 2.7 ± 0.25 1.5 ± 0.25 0805 2.8 ± 0.25 0.9 ± 0.25 0.95 ± 0.25 1.4 ± 0.25 3.2 ± 0.25 2.1 ± 0.25 1206 4.0 ± 0.25 2.0 ± 0.25 1.0 ± 0.25 1.8 ± 0.25 4.4 ± 0.25 2.5 ± 0.25 1210 4.0 ± 0.25 2.0 ± 0.25 1.0 ± 0.25 2.7 ± 0.25 4.4 ± 0.25 3.4 ± 0.25 1808 5.4 ± 0.25 3.3 ± 0.25 1.05 ± 0.25 2.3 ± 0.25 5.8 ± 0.25 2.9 ± 0.25 1812 5.4 ± 0.25 3.3 ± 0.25 1.05 ± 0.25 3.5 ± 0.25 5.8 ± 0.25 4.1 ± 0.25 2220 6.6 ± 0.25 4.5 ± 0.25 1.05 ± 0.25 5.3 ± 0.25 7.0 ± 0.25 5.9 ± 0.25 Processing remarks IR or hot plate soldering Ceramic substrate only www.yageo.com Apr. 16, 2022 V.18 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NPO/X7R/X7S 6.3 V to 2000 V REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version 18 Apr. 16, 2022 - - Add 0402/X7S/10V~16V/150nF~220nF Version 17 Jan. 14, 2022 - - Add 1206/NPO/2000V/10pF to 47pF Version 16 Nov. 17, 2021 - - Add 1206/X7R/500V to 1000V/220pF to 1nF Version 15 Oct. 12, 2021 - - Add 0603/NPO/25V/50V/2.7nF to 10nF - I.R. for NPO change to " I.R. ≥ 100 GΩ or I.R. × C ≥ 1000Ω.F. whichever is less" Version 14 Aug. 09, 2021 - - Add 1206/NPO/1kV/10pF to 220pF 1206/X7R/1kV/1nF Version 13 Jun. 08, 2021 - - Move out "Array" and "High Cap" to individual specification Add 0603 NPO 50V/100V 1.2nF to 2.2nF 0402 X7R 50V 15nF to 100nF 0603 X7R 25V 330nF to 680nF 0603 X7R 50V 150nF to 220nF 0603 X7R 100V 68nF to 100nF Version 12 Feb. 26, 2021 - Add 0201/ X7R/ 50V / 100 pF to 1nF 0603/ X7R/ 16V / 680nF to 1µF 0603/ X7R/ 25V / 150nF / 220nF/ 1µF 1210/ X7R/ 50V / 4.7µF Version 11 Jun. 29, 2018 - - Add 0201 NPO 25V/ 50V, 0.2pF to 33pF, Add 0402 NPO 50V 270pF to Version 10 May. 2, 2018 - - Add 0603 NPO 100V 820pF to 1nF, 1nF, Add 0805 X7R 25V 2.2uF - Add 0805 NPO 50V to 100V, 1.2nF to 10nF, - Add 0805 X7R 16V 2.2uF, 50V 680nF to 1uF, - Add 1206 X7R 100V 330nF to 2.2uF, 250V 33nF to 100nF Version 9 Mar. 22, 2018 - - Add 0402 X7R 100nF 25~50V Version 8 Nov. 22, 2017 - - Add X7R/0201/25V/100pF~10nF Version 7 Jul. 7, 2017 - - Add X7R/0805/330nF to 470nF/50V, X7R/1206/10uF/6.3V Version 6 Mar. 31, 2017 - - Add NPO/0603/1nF/50V, X7R/0603/1uF/10V, X7R/0603/470nF/16V, X7R/0603/220nF/25V Version 5 Nov. 15, 2016 - - Add Soldering Condition Version 4 Jun. 14, 2016 - - Add X7R/0805/2.2uF/10V and NPO/1206/1.2nF to 1.5nF/250V Version 3 Jul. 21, 2015 - - Tests and Requirements update Version 2 Jul. 17, 2014 - - Tests and Requirements update Version 1 Apr. 19, 2013 - - Capacitance range update Version 0 Dec. 25, 2012 - - New www.yageo.com Apr. 16, 2022 V.18 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NPO/X7R/X7S 6.3 V to 2000 V LEGAL DISCLAIMER YAGEO, its distributors and agents (collectively, “YAGEO”), hereby disclaims any and all liabilities for any errors, inaccuracies or incompleteness contained in any product related information, including but not limited to product specifications, datasheets, pictures and/or graphics. YAGEO may make changes, modifications and/or improvements to product related information at any time and without notice. YAGEO makes no representation, warranty, and/or guarantee about the fitness of its products for any particular purpose or the continuing production of any of its products. To the maximum extent permitted by law, YAGEO disclaims (i) any and all liability arising out of the application or use of any YAGEO product, (ii) any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for a particular purpose, non -infringement and merchantability. YAGEO products are designed for general purpose applications under normal operation and usage conditions. Please contact YAGEO for the applications listed below which require especially high reliability for the prevention of defects which might directly cause damage to the third party's life, body or property: Aerospace equipment (artificial satellite, rocket, etc.), Atomic energy-related equipment, Aviation equipment, Disaster prevention equipment, crime prevention equipment, Electric heating apparatus, burning equipment, Highly public information network equipment, data-processing equipment , Medical devices, Military equipment, Power generation control equipment, Safety equipment, Traffic signal equipment, Transportation equipment and Undersea equipment, or for any other application or use in which the failure of YAGEO products could result in personal injury or death, or serious property damage. Information provided here is intended to indicate product specifications only. YAGEO reserves all the rights for revising this content without further notification, as long as products are unchanged. Any product change will be announced by PCN. www.yageo.com Apr. 16, 2022 V.18 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: YAGEO: AC0402KRX7R7BB104 AC1206KKX7R0BB224 AC0402KRX7R9BB103 AC0402KRX7R8BB333 AC0603KRX7R8BB104 AC0805KRX7R9BB104 AC0402KRX7R9BB102 AC0402KRX7R9BB681 AC0402DRNPO9BN6R8 AC0402KRX7R9BB472 AC0402JRNPO9BN220 AC0402JRNPO9BN150 AC1206KKX7R8BB105 AC0603KRX7R9BB104 AC0402JRNPO9BN121 AC0402KRX7R9BB332 AC0603KRX7R9BB473 AC0402JRNPO9BN470 AC0402JRNPO9BN100 AC0805KKX7R0BB104 AC0402KRX7R9BB221 AC0402JRNPO9BN120 AC0603KRX7R7BB104 AC0402JRNPO9BN101 AC0603JRNPO0BN101 AC0805KRX7R8BB104 AC0805KRX7RYBB222 AC0805KKX7R5BB105 AC0805KRX7R9BB472 AC0805KRX7RBBB472 AC0805KRX7R9BB223 AC1206KKX7R8BB474 AC0603CRNPO9BN3R3 AC0603KRX7R7BB102 AC0402KRX7R8BB473 AC0402CRNPO9BN1R5 AC0603CRNPO9BN3R9 AC0402CRNPO9BN3R9 AC0603BRNPO9BN2R0 AC0402KRX7R9BB471 AC1210KKX7R9BB104 AC1210JKNPOYBN222 AC0603JRNPO9BN101 AC0603KRX7R0BB102 AC1206JKNPOZBN101 AC1206KRX7R0BB223 AC0603JRNPO9BN100 AC1206JKNPOZBN471 AC1206KKX7R0BB104 AC0603JRNPO0BN220 AC0603JRNPOYBN471 AC1210KKX7R0BB104 AC0612JRNPO9BN471 AC0603JRNPO0BN221 AC0603KRX7R0BB472 AC1206KKX7RYBB223 AC0603KRX7R9BB222 AC0603JRNPOYBN101 AC1206KRX7R8BB104 AC0402BRNPO9BN2R4 AC0402BRNPO9BN1R0 AC0402CRNPO9BN1R8 AC0603CRNPO9BN2R2 AC0603JRNPO9BN470 AC1210KKX7R8BB474 AC0603JRNPOYBN221 AC1206JKNPOZBN102 AC0402JRNPO9BN221 AC0603JRNPO0BN471 AC0402CRNPO9BN2R2 AC1206KRX7R0BB473 AC0402CRNPO9BN3R3 AC0402KRX7R8BB471 AC1210JKNPO0BN222 AC0603JRNPO9BN220 AC0402KRX7R8BB223 AC0402KRX7R7BB222 AC0603KRX7R7BB224 AC0805KRX7R8BB102 AC0805JRNPO9BN100 AC0402KRX7R8BB102 AC0603KRX7R8BB102 AC0603KRX7R0BB103 AC0805KRX7R8BB223 AC0805KRX7RBBB222 AC0805JRNPO0BN100 AC0805JRNPO0BN220 AC0805KRX7R7BB223 AC0805KRX7R7BB104 AC0805KKX7R8BB105 AC0805KKX7RYBB223 AC0805KRX7R9BB102 AC0805KRX7R8BB103 AC0805KRX7R0BB223 AC0805JRNPOYBN221 AC0805KRX7RYBB102 AC0805KKX7R7BB105 AC0805JRNPOYBN101 AC0805KRX7R7BB103 AC0805KKX7R8BB474
AC0201FR-07165KL 价格&库存
很抱歉,暂时无法提供与“AC0201FR-07165KL”相匹配的价格&库存,您可以联系我们找货
