FR107WS
FR107WS
    JUXING(钜兴)
    SOD-323
    快/超快恢复二极管 1KV SOD-323
FR107WS 数据手册
FR107WS Surface Mount Glass Passivated Fast Recovery Rectifier Reverse Voltage - 1000 V Forward Current - 1.0A PINNING FEATURES • Low forward voltage drop • Low leakage current • For surface mounted applications • Low profile package • Glass Passivated Chip Junction • Easy to pick and place • Lead free in comply with EU RoHS 2011/65/EU directives MECHANICAL DATA ▪Case: SOD-323 ▪Terminals: Solderable per MIL-STD-750, Method 2026 ▪A pprox. Weight: 5.48mg / 0.00019oz PIN DESCRIPTION 1 Cathode 2 Anode 2 1 Simplified outline SOD-323 and symbol Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Symbols FR107WS Units Maximum Repetitive Peak Reverse Voltage V RRM 1000 V Maximum RMS voltage V RMS 700 V Maximum DC Blocking Voltage V DC 1000 V Maximum Average Forward Rectified Current I F(AV) 1 A Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load I FSM 15 A Maximum Instantaneous Forward Voltage at 1 A VF 1.3 V IR 5 50 μA trr 500 ns Cj 5 pF T j , T stg -55 ~ +150 °C Parameter Maximum DC Reverse Current T a = 25 °C at Rated DC Blocking Voltage T a =125 °C Typical reverse recovery time Typical junction capacitance (2) (3) Operating and Storage Temperature Range (1)P.C.B. mounted with 0.2" X 0.2" (5 X 5 mm) copper pad areas. (2)Measured with I F =0.5A,I R =1A,I rr = 0.25A (3)Measured at 1 MHz and applied reverse voltage of 4 V D.C version: 02 http://www.trr-jx.com FR107WS Surface Mount Glass Passivated Fast Recovery Rectifier Characteristic Curves (TA=25 ℃ unless otherwise noted) Fig.1 Forward Current Derating Curve Average Forward Current (A) 1.2 1.0 0.8 0.6 0.4 0.2 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 75 50 100 125 150 175 Instaneous Reverse Current ( μ A) Fig.2 Typical Instaneous Reverse Characteristics 100 T J =150°C 10 T J =125°C T J =100°C 1.0 T J =75°C 0.1 T J =25°C 0.01 0 Case Temperature (°C) Junction Capacitance ( pF) 00 TJ = =1 TJ 2 5° C °C °C 25 =1 TJ Instaneous Forward Current (A) 0.5 0.8 0.9 0.2 1.0 1.1 Peak Forward Surage Current (A) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current 25 20 15 10 5 8.3 ms Single Half Sine Wave (JEDEC Method) 00 10 Number of Cycles version: 02 http://www.trr-jx.com 100 T J =25°C 10 1 0.1 1.0 10 Reverse Voltage (V) Instaneous Forward Voltage (V) 1 800 Fig.4 Typical Junction Capacitance 1.0 0.7 600 Instaneous Reverse Voltage (V) Fig.3 Typical Forward Characteristic 0.1 0.6 400 200 100 100 FR107WS Surface Mount Glass Passivated Fast Recovery Rectifier PACKAGE OUTLINE Plastic surface mounted package; 2 leads SOD-323 E E D b A C A1 ∠ALL ROUND L1 E1 SOD-323 mechanical data A C D E E1 b L1 A1 max 1.1 0.15 1.4 1.8 2.75 0.4 0.45 0.2 min 0.8 0.08 1.2 1.4 2.55 0.25 0.2 max 43 5.9 55 70 108 16 16 min 32 3.1 47 63 100 9.8 7.9 UNIT ∠ mm 9° 8 mil The recommended mounting pad size Marking Type number 1.4 (55) FR107WS 1.2 (47) 1.2 (47) 1.2 (47) Unit: mm (mil) version: 02 http://www.trr-jx.com Marking code R7
FR107WS 价格&库存
很抱歉,暂时无法提供与“FR107WS”相匹配的价格&库存,您可以联系我们找货
FR107WS
  • 50+0.11102
  • 500+0.08680
  • 3000+0.07141
  • 6000+0.06331
  • 24000+0.05633
  • 51000+0.05254
