FR107WS
FR107WS
    MDD(辰达半导体)
    SOD-323
    快/超快恢复二极管 电压:1KV 电流:1A SOD-323
FR107WS 数据手册
FR101WS THRU FR107WS Reverse Voltage - 50 to 1000 Volts Forward Current - 1.0 Ampere SURFACE MOUNT GLASS PASSIVATED FAST RECOVERY RECTIFIER Features SOD-323  Glass passivated Chip Junction  Low forward voltage drop  Low leakage current  For surface mounted applications 0.008(0.20)max. Cathode bar 0.055(1.40) 0.016(0.40) 0.009(0.25) 0.047(1.20)  Low profile package  Easy to pick and place 0.070 (1.80) 0.063 (1.40) 0.108 (2.75) 0.100 (2.55) 8° 0.0079 (0.20) 0.019 (0.475) ref. 0.10 (0.0031) Case: 6OD-323 Terminals: Solderable per MIL-STD-750,Method 2026 Polarity: Polarity symbol marking on body Mounting Position: Any Appro .Weight : 0.0019 ounce, 0.0548 grams 0.15 (0.0059) 0.016 (0.45) 0.008 (0.2 ) Mechanical Data 0° to 0.043 (1.10) directives 0.032 (0.8)  Lead free in comply with EU RoHS 2011/65/EU Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. FR101WS FR102WS FR103WS FR104WS FR105WS FR106WS FR107WS Parameter UNITS SYMBOLS Marking Code Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage VRMM VRMS VDC 1R 2R 3R 4R 5R 6R 7R 50 35 50 100 70 100 200 140 200 400 280 400 600 420 600 800 560 800 1000 700 1000 V V V Maximum average forward rectified current IF(AV) 1.0 A Peak forward surge current 8.3ms single half sine-wave superimposed onrated load (JEDEC Method) IFSM 15 A Maximum instantaneous forward voltage at 1.0A VF V Maximum DC reverse current at rated DCblocking voltage IR 1.3 5 50 TA=25℃ TA=125℃ Typical junction capacitance (NOTE 3) Typical reverse recovery time (NOTE 2) Operating junction temperature range Storage temperature range CJ Trr uA 5 150 pF 250 500 ns TJ -55 to +125 ℃ TSTG -55 to +150 ℃ Note:1.P.C.B. mounted with 0.2" X 0.2" (5 X 5 mm) copper pad areas. 2.Measured with IF=0.5A,IR =1A,Irr=0.25A 3.Measured at 1.0MHz and applied reverse voltage of 4.0V D.C. 4.The typical data above is for reference only. http://www.microdiode.com Rev:2024A1 Page :1 FR101WS THRU FR107WS Reverse Voltage - 50 to 1000 Volts Forward Current - 1.0 Ampere Typical Characterisitics Fig.2 Typical Instaneous Reverse Characteristics Average Forward Current (A) 1.2 1.0 0.8 0.6 0.4 0.2 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 75 50 100 125 150 175 Instaneous Reverse Current (μA) Fig.1 Forward Current Derating Curve 100 T J =150°C 10 T J =125°C T J =100°C 1.0 T J =75°C 0.1 T J =25°C 0.01 Junction Capacitance (pF) TJ = 2 5° C °C 00 =1 TJ =1 25 °C 0.5 TJ Instaneous Forward Current (A) 1.0 0.9 800 Fig.4 Typical Junction Capacitance Fig.3 Typical Forward Characteristic 0.8 600 Instaneous Reverse Voltage (V) Case Temperature (°C) 0.2 0.1 0.6 400 200 0 100 T J =25°C 10 1 0.7 1.0 1.1 0.1 1.0 10 100 Reverse Voltage (V) Instaneous Forward Voltage (V) Peak Forward Surage Current (A) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current 25 20 15 10 5 8.3 ms Single Half Sine Wave (JEDEC Method) 00 10 1 100 Number of Cycles The curve above is for reference only. http://www.microdiode.com Rev:2024A1 Page :2 FR101WS THRU FR107WS Reverse Voltage - 50 to 1000 Volts Forward Current - 1.0 Ampere Packing information unit:mm P0 P1 d Item Symbol Tolerance Carrier width Carrier length Carrier depth Sprocket hole 13" Reel outside diameter 13" Reel inner diameter 7" Reel outside diameter 7" Reel inner diameter Feed hole diameter Sprocket hole position Punch hole position Punch hole pitch Sprocket hole pitch Embossment center Overall tape thickness Tape width Reel width A B C d D D1 D D1 D2 E F P P0 P1 T W W1 0.1 0.1 0.1 0.05 2.0 min 2.0 min 0.5 0.1 0.1 0.1 0.1 0.1 0.1 0.3 1.0 SOD-323 E F B A W P D2 T D1 C W1 D 1.46 2.90 1.25 1.50 330.00 50.00 178.00 54.40 13.00 1.75 3.50 4.00 4.00 2.00 0.06 8.00 12.30 Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above. Reel packing PACKAGE SOD-323 REEL SIZE 7" REEL (pcs) COMPONENT SPACING (m/m) BOX (pcs) INNER BOX (m/m) REEL DIA, (m/m) 3,000 4.0 45,000 210*208*203 178 CARTON SIZE (m/m) 430*430*235 CARTON (pcs) APPROX. GROSS WEIGHT (kg) 180,000 9.0 Suggested Pad Layout Symbol A http://www.microdiode.com Unit (mm) Unit (inch) 0.047 B 1.2 1.2 C 3.6 0.141 D 1.4 0.055 E 3.8 0.149 0.047 Rev:2024A1 Page :3
FR107WS 价格&库存
很抱歉,暂时无法提供与“FR107WS”相匹配的价格&库存,您可以联系我们找货
FR107WS
  • 20+0.42760
  • 100+0.25510
  • 800+0.17860
  • 3000+0.12750
  • 6000+0.12120
  • 30000+0.11220
