FR101WS THRU FR107WS SOD-323
Surface Mount Fast Recovery Rectifiers
Reverse Voltage - 50 to 1000 V
2
Forward Current - 1 A
FEATURES
Low forward voltage drop
Low leakage current
For surface mounted applications
Low profile package
Glass Passivated Chip Junction
1.Cathode
2.Anode
1
■ Simplified outline(SOD-323)
Top View
Marking Code
Lead free in comply with EU RoHS 2011/65/EU directives
MECHANICAL DATA
Case: SOD-3 23
Terminals: Solderable per MIL-STD-750, Method 2026
Approx. Weight: 4.5mg / 0.00016oz
Absolute Maximum Ratings and characteristics
FR101WS
1R
FR102WS
2R
FR103WS
3R
FR104WS
4R
FR105WS
5R
FR106WS
6R
FR107WS
7R
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Symbols
Parameter
FR101WS FR102WS FR103WS FR104WS FR105WS FR106WS FR107WS Units
Maximum Repetitive Peak Reverse Voltage
VRRM
50
100
200
400
600
800
1000
V
Maximum RMS voltage
VRMS
35
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
VDC
50
100
200
400
600
800
1000
V
Maximum Average Forward Rectified Current
at Tc = 125 °C
IF(AV)
1
A
Peak Forward Surge Current 8.3 ms Single
Half Sine Wave Superimposed on Rated Load
IFSM
25
A
Maximum Instantaneous Forward Voltage at 1 A
VF
1.3
V
IR
5
50
μA
Typical Junction Capacitance at VR=4V,f=1MHZ
Cj
5
pF
Maximum Reverse Recovery Time(1)
Trr
Typical Thermal Resistance (2)
RθJA
85
°C/W
Tj, Tstg
-55 ~ +150
°C
Maximum DC Reverse Current T a = 25 °C
at Rated DC Blocking Voltage
T a=125 °C
Operating and Storage Temperature Range
150
250
500
nS
(1)Measured with IF=0.5A,IR=1A,In=0.25A
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
www.yfwdiode.com
1/3
G uangDong YFW Electronics Co, Ltd.
Fig.2 Typical Instaneous Reverse
Characteristics
Fig.1 Forward Current Derating Curve
Instaneous Reverse Current ( μ A)
Average Forward Current (A)
1.2
1.0
0.8
0.6
0.4
0.2
0.0
25
75
50
100
125
150
175
100
T J =150°C
10
T J =125°C
T J =100°C
1.0
T J =75°C
0.1
T J =25°C
0.01
Junction Capacitance ( pF)
TJ =
2 5°
C
00
=1
TJ
=1
25
°C
°C
0.5
TJ
Instaneous Forward Current (A)
1.0
0.8
0.9
600
800
Fig.4 Typical Junction Capacitance
Fig.3 Typical Forward Characteristic
0.2
0.1
0.6
400
200
Instaneous Reverse Voltage (V)
Case Temperature (°C)
100
T J =25°C
10
1
0.7
1.0
1.1
0.1
1.0
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
Fig.5 Maximum Non-Repetitive Peak
30
25
10
5
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
www.yfwdiode.com
2/3
SOD-323
Package Outline
Plastic surface mounted package; 2 leads
E
E
D
b
A
C
A1
∠ALL ROUND
L1
E1
A
C
D
E
E1
b
L1
A1
max
1.1
0.15
1.4
1.8
2.75
0.4
0.45
0.2
min
0.8
0.08
1.2
1.4
2.55
0.25
0.2
max
43
5.9
55
70
108
16
16
min
32
3.1
47
63
100
9.8
7.9
UNIT
mm
9°
8
mil
The recommended mounting pad size
1.4
(55)
1.2
(47)
1.2
(47)
1.2
(47)
Unit: mm
(mil)
Summary of Packing Options
Package
SOD-323
www.yfwdiode.com
Packing Description
Packing Quantity
Industry Standard
Tape/Reel,7”reel
3000
EIA-481-1
3/3
很抱歉,暂时无法提供与“FR107WS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.20520
- 200+0.16200
- 600+0.13800
- 3000+0.12969
- 9000+0.11717
- 21000+0.11040
- 国内价格
- 20+0.17084
- 300+0.13169
- 1200+0.10993
- 3000+0.09867
- 国内价格
- 1+0.55330
- 200+0.18370
- 1500+0.11550
- 3000+0.09141
