ZMM5221-ZMM5267
Product specification
ZMM5221-ZMM5267
Standard zener voltage tolerance is ± 20%. Add suffix "A" for ± 10% tolerance, suffix "B" for ± 5% tolerance and suffix "C" for ±
2% tolerance. Other tolerance, non standard and higher zener voltages are upon request.
LL-34
P/N
ZMM5221-ZMM5267
PKG
QTY
LL-34
2500
Symbol
Parameter
Value
1)
500
Unit
Power Dissipation
Ptot
Junction Temperature
Tj
175
O
Tstg
- 65 to + 175
O
Storage Temperature Range
Parameter
Symbol
Thermal Resistance Junction to Ambient Air
RthA
Forward Voltage
at IF = 200 mA
VF
Copyright© Msksemi Incorporated
Max.
0.3
1)
1.1
mW
C
C
Unit
K/mW
V
www.msksemi.com
ZMM5221-ZMM5267
Characteristics at Ta = 25℃
Type
V Znom
(V)
Zener Voltage Range
VZT
Min. (V)
Max. (V)
1)
Dynamic Resistance
at lZT
(mA)
ZZT
Max. (Ω)
ZZK
Max. (Ω)
at IZK
(mA)
Reverse Current
IR
Max. (µA)
at VR
(V)
ZMM5221B
2.4
2.28
2.52
1200
0.25
100
1
ZMM5222B
2.5
2.38
2.62
1250
0.25
100
1
ZMM5223B
2.7
2.57
2.83
1300
0.25
75
1
ZMM5224B
2.8
2.66
2.94
1400
0.25
75
1
ZMM5225B
3
2.85
3.15
1600
0.25
50
1
ZMM5226B
3.3
3.14
3.46
1600
0.25
25
1
ZMM5227B
3.6
3.42
3.78
1700
0.25
15
1
ZMM5228B
3.9
3.71
4.09
1900
0.25
10
1
ZMM5229B
4.3
4.09
4.51
2000
0.25
5
1
ZMM5230B
4.7
4.47
4.93
1900
0.25
5
2
ZMM5231B
5.1
4.85
5.35
1600
0.25
5
2
ZMM5232B
5.6
5.32
5.88
1600
0.25
5
3
ZMM5233B
6
5.7
6.3
1600
0.25
5
3.5
ZMM5234B
6.2
5.89
6.51
1000
0.25
5
4
ZMM5235B
6.8
6.46
7.14
750
0.25
3
5
ZMM5236B
7.5
7.13
7.87
500
0.25
3
6
ZMM5237B
8.2
7.79
8.61
500
0.25
3
6.5
ZMM5238B
8.7
8.27
9.13
600
0.25
3
6.5
ZMM5239B
9.1
8.65
9.55
600
0.25
3
7
ZMM5240B
10
9.5
10.5
600
0.25
3
8
ZMM5241B
11
10.45
11.55
600
0.25
2
8.4
ZMM5242B
12
11.4
12.6
600
0.25
1
9.1
ZMM5243B
13
12.35
13.65
9.5
13
600
0.25
0.5
9.9
ZMM5244B
14
13.3
14.7
9
15
600
0.25
0.1
10
ZMM5245B
15
14.25
15.75
8.5
16
600
0.25
0.1
11
ZMM5246B
16
15.2
16.8
7.8
17
600
0.25
0.1
12
ZMM5247B
17
16.15
17.85
7.4
19
600
0.25
0.1
13
ZMM5248B
18
17.1
18.9
7.0
21
600
0.25
0.1
14
ZMM5249B
19
18.05
19.95
6.6
23
600
0.25
0.1
14
ZMM5250B
21
6.2
25
600
0.25
0.1
15
ZMM5251B
22
20.9
23.1
5.6
29
600
0.25
0.1
17
ZMM5252B
24
22.8
25.2
5.2
33
600
0.25
0.1
18
ZMM5253B
25
23.75
26.25
5
35
600
0.25
0.1
19
ZMM5254B
27
25.65
28.35
4.6
41
600
0.25
0.1
21
ZMM5255B
28
26.6
29.4
4.4
44
600
0.25
0.1
21
ZMM5256B
30
28.5
31.5
4.2
49
600
0.25
0.1
23
ZMM5257B
33
31.35
34.65
3.8
58
700
0.25
0.1
25
ZMM5258B
36
34.2
37.8
3.4
70
700
0.25
0.1
27
ZMM5259B
39
37.05
40.95
3.2
80
800
0.25
0.1
30
ZMM5260B
43
40.85
45.15
3
93
900
0.25
0.1
33
ZMM5261B
47
44.65
49.35
2.7
105
1000
0.25
0.1
36
ZMM5262B
51
48.45
53.55
2.5
125
1100
0.25
0.1
39
ZMM5263B
56
53.2
58.8
2.2
150
1300
0.25
0.1
45
ZMM5264B
60
57
63
2.1
170
1400
0.25
0.1
46
ZMM5265B
62
58.9
65.1
2
185
1400
0.25
0.1
47
ZMM5266B
68
64.6
71.4
1.8
230
1600
0.25
0.1
52
ZMM5267B
75
71.25
78.75
1.7
270
1700
0.25
0.1
56
1) Tested with pulsestp = 20 ms.
www.msksemi.com
ZMM5221-ZMM5267
Attention
■ Any and all MSKSEMI Semiconductor products described or contained herein do not
handle applications that require extremely high levels of reliability, such as life-support
have specifications
that can
systems, aircraft's control systems, or
other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with
your MSKSEMI Semiconductor representative
nearest
you before using any MSKSEMI Semiconductor products described
or contained herein in such applications.
■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products
at values that
exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in
products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein.
■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the
performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the
performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To
verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test
devices mounted in the customer’sproducts orequipment.
■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor
products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could
endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing
equipment, adopt safety measures so that these kinds of accidents
or events cannot occur. Such measures include but are
not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design.
■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described
or contained
herein are controlled under any of applicable local export control laws and regulations, such products must not be exported
without obtaining the export license from theauthorities
concerned
in accordance with the above law.
■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or
mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior
written permission of MSKSEMI Semiconductor.
Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume
production. MSKSEMI Semiconductor believes information herein is accurate and
reliable, but no guarantees are made or
implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties.
Any and all information described or contained herein are subject to change without notice due to
product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI
Semiconductor productthat you intend to use.
www.msksemi.com
很抱歉,暂时无法提供与“ZMM5231B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.14775
- 500+0.11859
- 2500+0.09299
- 5000+0.08327
- 25000+0.07485
- 50000+0.07020
