BAV23S
BAV23S
    XINZHANTONG(信展通)
    SOT-23
    开关二极管(小信号) 电压:250V 电流:225mA SOT-23
BAV23S 数据手册
X• T ELECTRONICS BAV23A/C/S SWITCHING DIODE SOT-23 FEATURES  Fast Switching Speed For General Purpose Switching Applications  High Conductance  3 1 2 MARKING: BAV23A:KT7 BAV23C:KT6 BAV23S:KL31 MAXIMUM RATINGS ( Ta=25℃ unless otherwise noted ) Symbol Parameter Value Unit 250 V RMS Reverse Voltage 175 V Average Rectified Output Current 225 mA IFRM Repetitive Peak Forward Surge Current 625 mA IFSM Non-repetitive Peak Forward Surge Current @ t= 8.3ms 1.7 A PD Power Dissipation 350 mW Thermal Resistance from Junction to Ambient 357 ℃/W -55~+150 ℃ VRRM Peak Repetitive Reverse Voltage VRWM Working Peak Reverse Voltage VR(RMS) IO RΘJA TJ,Tstg Operation Junction and Storage Temperature Range ELECTRICAL CHARACTERISTICS(Ta=25℃ unless otherwise specified) Parameter Symbol Test conditions IR=100μA Min Typ Max 250 V Reverse voltage V(BR) Reverse current = VR 250V IR 0.1 Forward voltage = IF 100mA VF = IF 200mA 1 Total capacitance Reverse recovery time http://www.xt-elec.com = = VR 0V,f 1MHz Ctot trr IF= IR=30mA, Irr=0.1×IR, RL=100Ω 第1页共3页 Unit 1.25 μA V 5 pF 50 ns Rev : B X• T ELECTRONICS BAV23A/C/S SWITCHING DIODE Typical Characteristics Forward 300 Characteristics Reverse 1000 Pulsed Characteristics Pulsed (nA) (mA) 100 REVERSE CURRENT IR ℃ T= a 2 5 FORWARD CURRENT T= a 1 00 ℃ IF 10 1 0.1 0.01 0.2 0.4 0.6 0.8 FORWARD VOLTAGE 1.0 VF 100 10 Ta=25℃ 1 1.2 0 50 (V) 100 150 REVERSE VOLTAGE Capacitance Characteristics 1.6 Ta=100℃ 200 250 (V) VR Power Derating Curve 400 (mW) f=1MHz 350 300 PD 1.4 1.2 POWER DISSIPATION CAPACITANCE BETWEEN TERMINALS CT (pF) Ta=25℃ 1.0 0.8 0.6 0 4 8 12 REVERSE VOLTAGE http://www.xt-elec.com 16 VR 20 250 200 150 100 50 0 (V) 0 25 50 75 100 AMBIENT TEMPERATURE 第2页共3页 125 Ta 150 (℃) Rev : B X• T ELECTRONICS BAV23A/C/S SWITCHING DIODE SOT-23 Package Outline Dimensions Symbol A A1 A2 b c D E E1 e e1 L L1 θ Dimensions In Millimeters Min Max 0.900 1.150 0.000 0.100 0.900 1.050 0.300 0.500 0.080 0.150 2.800 3.000 1.200 1.400 2.250 2.550 0.950 TYP 1.800 2.000 0.550 REF 0.300 0.500 0° 8° Dimensions In Inches Min Max 0.035 0.045 0.000 0.004 0.035 0.041 0.012 0.020 0.003 0.006 0.110 0.118 0.047 0.055 0.089 0.100 0.037 TYP 0.071 0.079 0.022 REF 0.012 0.020 0° 8° SOT-23 Suggested Pad Layout http://www.xt-elec.com 第3页共3页 Rev : B
BAV23S 价格&库存
很抱歉,暂时无法提供与“BAV23S”相匹配的价格&库存,您可以联系我们找货
BAV23S
  • 50+0.09245
  • 500+0.07204
  • 3000+0.06070
  • 6000+0.05390
  • 24000+0.04796
  • 51000+0.04482
库存:2749
