SS36AT
SS36AT
    AGERTECH(艾吉芯)
    SMA(DO-214AC)
    肖特基二极管 SMA(DO-214AC)
SS36AT 数据手册
SS32AT THRU SS320AT SURFACE MOUNT SCHOTTKY BARRIER RECTIFIERS Forward Current-3.0A Reverse Voltage-20V to 200V FEATURES PINNING PIN  For surface mount applications  High forward surge current capability  Low power loss,high efficiency  Metal silicon junction,majority carriers conduction DESCRIPTION 1 Cathode 2 Anode MECHANICAL DATA 1  Case: SMA molded plastic body  Terminals: Solderable per MIL-STD-750, Method 2026  Weight: Approximated 0.06 grams 2 Top View Simplified outline SMA and symbol MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25℃ ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derating by 20 %. PARAMETER SYMBOL SS32AT SS34AT SS34AAT SS36AT SS38AT SS310AT SS312AT SS315AT SS320AT UNIT Maximum Repetitive Peak Reverse Voltage VRRM 20 40 45 60 80 100 120 150 200 V Maximum RMS Voltage VRMS 14 28 31.5 42 56 70 84 105 140 V Maximum DC Blocking Voltage VDC 20 40 45 60 80 100 120 150 200 V Maximum Average Forward Rectified Current at TC=75℃ IF(AV) Peak Forward Surge Current (Note1) IFSM 3.0 A 80 VF Maximum DC Reverse Current at Rated DC Blocking Voltage at TA=25℃ IR 0.5 5 0.3 3 mA CJ 450 400 pF Typical Junction Capacitance (Note2) Typical Thermal Resistance (Note3) Operating and Storage Temperature Range RθJA TJ,TSTG 0.70 0.85 A Maximum Forward Voltage at 3.0 A TA=100℃ 0.55 70 70 -55 to +150 0.95 V ℃/W ℃ Notes: 1. Measured at 8.3 ms single half sine wave superimposed on rated load (JEDEC Method). 2. Measured at 1MHz and applied reverse voltage of 4 V D.C. 3. P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. AGERTECH MICROELECTRONICS   Subsidiary of Sino-Talent International Holdings Ltd.  1 / 3  Dated: 06/2016  Rev:1.0  SS32AT THRU SS320AT RATINGS AND CHARACTERISTIC CURVES AGERTECH MICROELECTRONICS   Subsidiary of Sino-Talent International Holdings Ltd.  2 / 3  Dated: 06/2016  Rev:1.0  SS32AT THRU SS320AT PACKAGE OUTLINE SMA g g A E D C a HE UNIT mm mil A D E HE C e g max 2.2 4.5 2.7 5.2 0.31 1.6 1.5 min 1.9 4.0 2.3 4.7 0.15 1.3 0.9 max 87 181 106 205 12 63 59 min 75 157 91 185 6 51 35 a 0.3 12 ORDERING INFORMATION Device Package Shipping SS32AT thru SS320AT SMA 5,000/ Tape & Reel (13 inches) AGERTECH MICROELECTRONICS   Subsidiary of Sino-Talent International Holdings Ltd.  3 / 3  Dated: 06/2016  Rev:1.0
SS36AT 价格&库存
很抱歉,暂时无法提供与“SS36AT”相匹配的价格&库存,您可以联系我们找货
