PLPVYL1 940A_E
PLPVYL1 940A_E
    AMSOSRAM(艾迈斯半导体)
PLPVYL1 940A_E 数据手册
www.osram-os.com Produktdatenblatt | Version 1.1 PLPVYL1 940A_E   PLPVYL1 940A_E BIDOS® E1005 L VCSEL (940 nm) Applications —Remote Control, Proximity, Ambient Light Sensing Features —Package: clear epoxy —ESD: 2 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 2) —Multimode VCSEL —Very small SMT package Ordering Information  IF = 15 mA; tp = 1 ms Type Optical output power  PLPVYL1 940A_E  Popt  ≥ 7 mW 1 Version 1.2 | 2022-02-08 Optical output power  typ. Popt 11 mW Ordering Code Q65112A9493 PLPVYL1 940A_E   Maximum Ratings TA = 25 °C Parameter Symbol Operating temperature Top min. max. -40 °C 85 °C Storage temperature Tstg min. max. -40 °C 85 °C Junction temperature Tj max. 100 °C Forward current IF max. 20 mA Surge current tp ≤ 1 ms; D = 0.024  IFSM max. 25 mA Reverse voltage 1) VR max. 10 V ESD withstand voltage acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 2) VESD max. 2 kV   2 Version 1.2 | 2022-02-08 Values PLPVYL1 940A_E   Characteristics IF = 15 mA; tp = 1 ms; TA = 25 °C Parameter Symbol Peak wavelength 2) λpeak min. typ. max. Spectral bandwidth at 50% Ie,rel,max ∆λ typ. 4 nm 3) Optical output power  Popt min. typ. 7 mW 11 mW Optical output power 3) IF = 8 mA; tp = 1 ms Popt min. max. 3.5 mW 7.5 mW Beam divergence (1/e²) parallel to pn-junction Θ‖ typ. max. 18 ° 25 ° Beam divergence (1/e²) perpendicular to pn-junction Θ┴ typ. max. 18 ° 25 ° Threshold current Ith typ. 2 mA Forward voltage 4) VF min. typ. max. 1.8 V 2.0 V 2.4 V Forward voltage 4) IF = 10 µA; tp = 10 ms VF min. 0.7 V Thermal resistance junction solder point real RthJS real max. 270 K / W   3 Version 1.2 | 2022-02-08 Values 931 nm 940 nm 949 nm PLPVYL1 940A_E   Relative Spectral Emission 5), 6) Ie,rel = f (λ); IF = 15 mA; tp = 1 ms [ ] 1.0 0.8 0.6 0.4 0.2 0.0 930 935 940 945 950 ] λ[ Radiation Characteristics 5), 6) Ie,rel = f (φ) φ[ ] : 0°  -40° -50° -60° -70° -20° -30° -10° 0° 10° 20° 30° 40° 50° 60° 70° 80° 90° 1.0 0.9 0.8 0.7 0.6 0.5 0.4 0.3 -80° 0.2 0.1  -90° 4 Version 1.2 | 2022-02-08 0.0 PLPVYL1 940A_E   Optical Output Power Forward Voltage 5), 6) Popt = f (IF) 5), 6) VF = f (IF) [ ] [ 0.020 ] 101 0.015 1 0.010 0.1 0.005 0.01 0.000 0 5 10 15 20 1.0 1.2 1.4 1.6 1.8 2.0 2.2 25 [ ] [ ] Max. Permissible Forward Current Permissible Pulse Handling Capability IF,max = f (TS); Rthjs = 270K / W IF = f (tp); duty cycle D = parameter; TA = 85°C [ ] 20 [  15 ] 30 20 10 :D=1 : D = 0,5 : D =0,2 : D =0,1 : D =0,05 : D =0,02 : D =0,01 : D =0,005 10 5 0 20  0 5 Version 1.2 | 2022-02-08 40 60 80 [ ] 0 10-4 10-3 0.01 0.1 1 10 [ ] PLPVYL1 940A_E   Dimensional Drawing 7) Further Information: Approximate Weight: 0.6 mg   6 Version 1.2 | 2022-02-08 PLPVYL1 940A_E   Recommended Solder Pad   7 Version 1.2 | 2022-02-08 7) PLPVYL1 940A_E   Reflow Soldering Profile Product complies to MSL Level 3 acc. to JEDEC J-STD-020E OHA04525 300 ˚C T 250 Tp 245 ˚C 240 ˚C tP 217 ˚C 200 tL 150 tS 100 50 25 ˚C 0 0 50 100 150 200 250 s 300 t Profile Feature Symbol Pb-Free (SnAgCu) Assembly Minimum Recommendation Maximum Ramp-up rate to preheat*) 25 °C to 150 °C tS Time tS TSmin to TSmax Ramp-up rate to peak*) TSmax to TP Liquidus temperature  60 2 3 100 120 2 3 Unit K/s s K/s TL 217 Time above liquidus temperature tL 80 100 s Peak temperature TP 245 260 °C Time within 5 °C of the specified peak temperature TP - 5 K tP 20 30 3 6 Ramp-down rate* TP to 100 °C 10 Time 25 °C to TP  All temperatures refer to the center of the package, measured on the top of the component * slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range 8 Version 1.2 | 2022-02-08 °C 480 s K/s s PLPVYL1 940A_E   Taping 7)   9 Version 1.2 | 2022-02-08 PLPVYL1 940A_E   Tape and Reel 8) Reel Dimensions A 180 mm W Nmin 8 + 0.3 / - 0.1 mm   10 Version 1.2 | 2022-02-08 W1 60 mm W2 max 8.4 + 2 mm 14.4 mm Pieces per PU 3000 PLPVYL1 940A_E   Barcode-Product-Label (BPL) Dry Packing Process and Materials 7) Moisture-sensitive label or print L E E V l e be sela ). k, H de L If an bl r co ba (R id m ity . H R hu 0% e e /6 tiv ˚C la ared ag ck re fr 30 _ < in pa % k of to 90 rs ea s d ). rs ou or te (p on rs H de , ou iti H an bjec ng ou rs co ˚C 72 si nd H ou 5 te 48 ˚C su es e H co ± 24 6 da e y 40 be oc tim ˚C e or < ith tim ill pr). or ct w O w nt 23 tim e at lo or fa M TO F s al tim at le ˚C at lo at or e. P th F l tic th va lo or ur O F lo s ui on be if: read en w ed l 4 5 F m la ce eq id lo g, n oc l ve vi 5a is in or be 24 de pr ve l 6 Le de , nt whe e te co g: , w e Le ve l ke r ou se da ba ed flo ur e Le ve m % ba e ba al st ur e Le r en re ed e re> 10 oi st e e fo tim ur se al op fo M se oi st ur as k, is or . 33 se is M oi st bed k, lo H an , g ph -0 M oi in an in F R ng ar rbl D M e ba T r po If bl ith % lif ki r C. (if S is p. w ea r ks lf J10 ba to et th va Y ea m rs m _ r w, < he ed 1 ee te Y d, EC iredicat S fte at nt > 1 W Hou D A flody qu In no ire 1. d e ou 4 8 re reity is qu/JE re 2. bo e M tim to es id 2b re C 16 : e a) S tim is IP ic ed loor tim e b) ev Humor or e en F tim lo or D 2a king nc te F op a) lo or 3. b) ba re F lo da e fe l 1 2 F If al re tim ve l 4. se d l 2a ve Le 3 an ve l ag e Le e B ve ur e Le at st ur e Le D oi st ur e M oi st ur M oi st M oi M N E RS s in IV O IT T S C nta N U TIO U coSEND Ais bUagRMEICO T E CThIS S d Barcode label < M RA OS  Humidity indicator Barcode label Please check the HIC immidiately after bag opening. Discard if circles overrun. Avoid metal contact. Do not eat. Comparator check dot WET If wet, examine units, if necessary bake units 15% If wet, examine units, if necessary bake units 10% 5% If wet, parts still adequately dry. change desiccant Humidity Indicator MIL-I-8835 Desiccant AM OSR OHA00539  Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card according JEDEC-STD-033. 11 Version 1.2 | 2022-02-08 PLPVYL1 940A_E   Notes The evaluation of eye safety occurs according to the standard IEC 62471:2006 (photo biological safety of lamps and lamp systems). Within the risk grouping system of this IEC standard, the device specified in this data sheet fall into the class exempt group (exposure time 10000 s). Under real circumstances (for exposure time, conditions of the eye pupils, observation distance), it is assumed that no endangerment to the eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light sources have a high secondary exposure potential due to their blinding effect. When looking at bright light sources (e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation. Subcomponents of this device contain, in addition to other substances, metal filled materials including silver. Metal filled materials can be affected by environments that contain traces of aggressive substances. Therefore, we recommend that customers minimize device exposure to aggressive substances during storage, production, and use. Devices that showed visible discoloration when tested using the described tests above did show no performance deviations within failure limits during the stated test duration. Respective failure limits are described in the IEC60810. For further application related information please visit www.osram-os.com/appnotes   12 Version 1.2 | 2022-02-08 PLPVYL1 940A_E   Disclaimer Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version on the OSRAM OS website. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Product and functional safety devices/applications or medical devices/applications OSRAM OS components are not developed, constructed or tested for the application as safety relevant component or for the application in medical devices. OSRAM OS products are not qualified at module and system level for such application. In case buyer – or customer supplied by buyer – considers using OSRAM OS components in product safety devices/applications or medical devices/applications, buyer and/or customer has to inform the local sales partner of OSRAM OS immediately and OSRAM OS and buyer and /or customer will analyze and coordinate the customer-specific request between OSRAM OS and buyer and/or customer.   13 Version 1.2 | 2022-02-08 PLPVYL1 940A_E   Glossary 1) Reverse Operation: This product is intended to be operated applying a forward current within the specified range. Applying any continuous reverse bias or forward bias below the voltage range of light emission shall be avoided because it may cause migration which can change the electro-optical characteristics or damage the LED. 2) Wavelength: λpeak is measured with an internal reproducibility of ±0.7 nm (acc. to GUM with a coverage factor of k = 3). 3) Brightness: The brightness values are measured with a tolerance of ±11%. 4) Forward Voltage: The forward voltages are measured with a tolerance of ±0.1 V. 5) Typical Values: Due to the special conditions of the manufacturing processes of semiconductor devices, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 6) Testing temperature: TA = 25°C (unless otherwise specified) 7) Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and dimensions are specified in mm. 8) Tape and Reel: All dimensions and tolerances are specified acc. IEC 60286-3 and specified in mm.   14 Version 1.2 | 2022-02-08 PLPVYL1 940A_E   Revision History Version Date Change 1.0 2020-10-30 Initial Version 1.1 2021-11-10 Ordering Information Characteristics Further Information 1.2 2022-02-08 Derating (Diagrams)   15 Version 1.2 | 2022-02-08 PLPVYL1 940A_E     Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 16 Version 1.2 | 2022-02-08
PLPVYL1 940A_E 价格&库存
很抱歉,暂时无法提供与“PLPVYL1 940A_E”相匹配的价格&库存,您可以联系我们找货
