TPW4051-TR
TPW4051-TR
    3PEAK(思瑞浦)
    TSSOP-16
    模拟开关芯片 TSSOP-16
TPW4051-TR 数据手册
TPW4051 12V General Purpose Analog Switch Features Description ⚫ Analog Switch Voltage: 3.3V, 5V, 10V, ±5V The TPW4051 is a single-pole octal-throw analog switch (SP8T) ⚫ Low ON-State Resistance: suitable for use in analog or digital 8:1 multiplexer/demultiplexer typical 50Ω at Vs = ±4.5V or 9V applications. The switch features three digital select inputs (S0, typical 60Ω at Vs = 4.5V S1 and S2), eight independent inputs/outputs (An), a common typical 300Ω at Vs = 3V input/output (A) and a digital enable input (/E). When /E is HIGH, the switches are turned off. ⚫ Bandwidth: 200 MHz ⚫ Fast switching times: tON = 60ns, tOFF = 50ns ⚫ Break-Before-Make Switching ⚫ Operation Temperature Range: –40°C to 125°C The device is designed on an enhanced process that provides lower power dissipation yet gives high switching speeds. These devices can operate equally well as either multiplexers or demultiplexers and have an input range that extends to the supplies. All channels exhibit break-before-make switching Applications ⚫ Industry control systems ⚫ Battery-powered systems ⚫ Audio Signal Routing ⚫ Instrumentation action, preventing momentary shorting when switching channels. Switch Selection Guide Product Switch Supply Ron(OHM) Bandwidth(MHz) Package Configuration Voltage(V) TPW4051 8:1 12 50 200 SOIC-16, TSSOP-16, QFN-16 TPW4052 (4:1)*2 12 50 200 SOIC-16, TSSOP-16 TPW4053 (2:1)*3 12 50 200 SOIC-16, TSSOP-16 TPW3111 1:1 5.5 1 100 SC70-5 TPW3115 1:1 5.5 5 250 SC70-5, SOT23-5 TPW4157 2:1 5.5 1 100 SC70-6 TPW3157A 2:1 5.5 2 100 SC70-6 TPW3221 (2:1)*2 5.5 1 100 MSOP-10 TPW3223 (2:1)*2 5.5 1 100 QFN-10, 1.4*1.8mm www.3peak.com 1 / 18 Rev.A.1 TPW4051 12V General Purpose Analog Switch Table of Contents Features ........................................................................................................................................................................... 1 Applications ..................................................................................................................................................................... 1 Description....................................................................................................................................................................... 1 Switch Selection Guide .................................................................................................................................................. 1 Table of Contents ............................................................................................................................................................ 2 Revision History .............................................................................................................................................................. 3 Order Information ............................................................................................................................................................ 3 Pin Configuration, Description and Functional Table Note 1 ......................................................................................... 4 TPW4051 ..................................................................................................................................................................................... 4 Absolute Maximum Ratings Note 1 ................................................................................................................................... 6 ESD Rating ....................................................................................................................................................................... 6 Thermal Information ....................................................................................................................................................... 6 Recommended Operating Conditions Note 1 .................................................................................................................. 6 Typical Performance Characteristics .......................................................................................................................... 11 Test Circuit and Waveforms ......................................................................................................................................... 12 Application Information ................................................................................................................................................ 13 Tape and Reel Information ........................................................................................................................................... 14 Package Outline Dimensions ....................................................................................................................................... 15 SOIC-16 ..................................................................................................................................................................................... 15 Package Outline Dimensions ....................................................................................................................................... 16 TSSOP-16 .................................................................................................................................................................................. 16 Package Outline Dimensions ....................................................................................................................................... 17 QFN-16 ...................................................................................................................................................................................... 17 IMPORTANT NOTICE AND DISCLAIMER .................................................................................................................... 17 www.3peak.com 2 / 18 Rev.A.1 TPW4051 12V General Purpose Analog Switch Revision History Date Revision Notes 2018/8/8 Rev.Pre Pre-Release Version 2019/3/4 Rev.0 Initial Version 2019/10/2 Rev.0.01 HBM: 2KV -> 1KV 2019/12/25 Rev.0.02 Correct test conditions of RON and switch leakage to follow the product test(Product test is not changed): all of “0V” -> “VEE”; On Resistance Match between Channels at 3 to 3.6V Vcc: -> remove; On Resistance Match between Channels at 9 to 11V Vcc: VIS = 3.5V -> VIS = 1V; On Resistance Match between Channels at 4.5 to 5.5V Vcc, Vee = -4.5V to 5.5V: VIS = 3.5V -> VIS = -3.5V 2020/1/14 Rev.0.03 Correct the “P0” information of TR in Tape and Reel Information 2020/11/26 Rev.A.0 Correct the Quantity of TPW4051-QF4R in order information: 3000 -> 4000 2022/4/21 Rev.A.1 Add the thermal information and update the high POD of QFN-16 package Order Information Order Number Operating Temperature Range Package Marking Information MSL Transport Media, Quantity TPW4051-SR -40 to 125°C 16-Pin SOIC W4051 3 Tape and Reel, 2500 TPW4051-TR -40 to 125°C 16-Pin TSSOP W4051 3 Tape and Reel, 3000 TPW4051-QF4R -40 to 125°C 16-Pin QFN3X3 W4051 3 Tape and Reel, 4000 www.3peak.com 3 / 18 Rev.A.1 TPW4051 12V General Purpose Analog Switch Pin Configuration, Description and Functional Table Note 1 TPW4051 TPW4051 16-Pin SOIC/TSSOP A6 A4 VCC A2 16 15 14 13 TPW4051 16-Pin QFN 3*3 15 A2 12 14 A1 A 1 A 3 A1 A7 4 13 A0 A7 2 11 A0 A5 5 12 A3 A5 3 10 A3 /E 6 11 S0 /E 4 9 S0 LOGIC 10 S1 GND 8 9 S2 5 VEE 7 VEE GND 8 A6 2 7 16 VCC 6 A4 1 S2 S1 Pin Description of SOIC and TSSOP Pin No. Pin Name Input / Output Description Pin No. Pin Name Input / Output Description 1 A4 Input / Output Channel 4 input or output 9 S2 Input Control Input 2 A6 Input / Output Channel 6 input or output 10 S1 Input Control Input 3 A Input / Output Common input or output 11 S0 Input Control Input 4 A7 Input / Output Channel 7 input or output 12 A3 Input / Output Channel 3 input or output 5 A5 Input / Output Channel 5 input or output 13 A0 Input / Output Channel 0 input or output 6 /E Input Enable switchs, active low 14 A1 Input / Output Channel 1 input or output 7 VEE Negative Power Input 15 A2 Input / Output Channel 2 input or output 8 GND Ground 16 VCC Positive Power Input Pin Description of QFN Pin No. Pin Name Input / Output Description Pin No. Pin Name Input / Output Description 1 A Input / Output Common input or output 9 S0 Input Control Input 2 A7 Input / Output Channel 7 input or output 10 A3 Input / Output Channel 3 input or output 3 A5 Input / Output Channel 5 input or output 11 A0 Input / Output Channel 0 input or output 4 /E Input Enable switchs, active low 12 A1 Input / Output Channel 1 input or output 5 VEE Negative Power Input 13 A2 Input / Output Channel 2 input or output 6 GND Ground 14 VCC 7 S2 Input Control Input 15 A4 Input / Output Channel 4 input or output 8 S1 Input Control Input 16 A6 Input / Output Channel 6 input or output www.3peak.com 4 / 18 Positive Power Input Rev.A.1 TPW4051 12V General Purpose Analog Switch Functional Table /E, Enable S2 S1 S0 ON Channel L L L L A0 L L L H A1 L L H L A2 L L H H A3 L H L L A4 L H L H A5 L H H L A6 L H H H A7 H X X X None X = Don’t care www.3peak.com 5 / 18 Rev.A.1 TPW4051 12V General Purpose Analog Switch Absolute Maximum Ratings Note 1 Parameters Rating Supply Voltage, VCC - VEE -0.5V to 13V Supply Voltage, VCC - GND -0.5V to 13V Supply Voltage, VEE - GND -6.5V to 0.5V Analog Switch Voltage VEE – 0.5V to VCC + 0.5V Analog Switch Current ±25mA Analog Switch Diode Current ±20mA Digital Input Voltage, /E, S2, S1, S0 GND to VCC + 0.5V Digital Input Diode Current ±20mA Maximum Junction Temperature 150°C Storage Temperature Range –65 to 150°C Lead Temperature (Soldering, 10 sec) 260°C Note 1: Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. Exposure to any Absolute Maximum Rating condition for extended periods may affect device reliability and lifetime. ESD Rating Symbol Parameter Condition Minimum Level Unit HBM Human Body Model ESD ANSI/ESDA/JEDEC JS-001 1 kV CDM Charged Device Model ESD ANSI/ESDA/JEDEC JS-002 1 kV Thermal Information Package Type θJA θJC Unit 16-Pin SOIC 100 50 °C/W 16-Pin TSSOP 150 60 °C/W 16-Pin QFN 65 41 °C/W Recommended Operating Conditions Note 1 Over operating temperature range Parameters Min Max Unit Supply Voltage, VCC - VEE 3 12 V Supply Voltage, VCC – GNDNote2 3 12 V Supply Voltage, VEE – GNDNote2 -6 0 V Select Input Voltage 0 VCC V 100 ns/V Input Transition Rise and Fall Rate Switch I/O Port Voltage VEE VCC V Operating Temperature Range –40 125 °C Note 1: Select input must be held HIGH or LOW and it must not float. Note 2: The voltage of VCC, VEE need be in the range of VCC-VEE www.3peak.com 6 / 18 Rev.A.1 TPW4051 12V General Purpose Analog Switch Electrical Characteristics Single Supply, VCC = 4.5 to 5.5V, VEE = 0V, GND = 0V, unless otherwise noted. Symbol Parameter Conditions VCC (V) 25°C -40°C to 85°C -40°C to 125°C Limit Unit VIN = VEE or VCC 5.5 4 6 8 Max μA Power Supply ICC Quiescent Supply Current Digital Input VIH Input Voltage High 2.0 2.0 Min V VIL Input Voltage Low 0.8 0.8 Max V IIN Control Input Leakage ±1 ±1 Max μA Typ Ω VIN = 0V or VCC 5.5 ±0.4 IOUT = 1mA, VIS = VEE or VCC 4.5 60 IOUT = 1mA, VIS = VEE or VCC 4.5 100 130 150 Max Ω Analog Switch RON (1) RON ΔRON On Resistance Match between Channels IOUT = 1mA, VIS = 2.5V 4.5 20 30 35 Max Ω RFLAT(ON) On Resistance Flatness IOUT = 1mA 4.5 60 80 80 Max Ω ICH(OFF) Switch OFF Leakage Current on Channel VIS = VEE, VOS = VCC; or VIS = VCC, VOS = VEE 5.5 ±0.4 ±1 ±1 Max μA ICOM(OFF) Switch OFF Leakage Current on Common VIS = VEE, VOS = VCC; or VIS = VCC, VOS = VEE, 5.5 ±0.4 ±4 ±4 Max μA I(ON) Switch ON Leakage Current VIS = VEE or VCC 5.5 ±0.4 ±4 ±4 Max μA Dynamic Characteristics tPHL, tPLH Switch IN to OUT time (1) CL = 50pF 4.5 5 Typ ns tON Switch turn-on time CL = 50pF 4.5 60 Max ns tOFF Switch turn-off time CL = 50pF 4.5 50 Max ns f = 1MHz, RL = 50Ω, CL = 10pF 5 -70 Typ dB f = 1MHz, RL = 50Ω, CL = 10pF 5 -70 Typ dB Crosstalk in control (1) Between control and any switch; RL = 600Ω; f = 1 MHz; E or Sn square wave between VCC and GND 5 110 Typ mV BW Bandwidth (1) RL = 50Ω 5 200 Typ MHz THD Total Harmonic Distortion (1) RL = 10kΩ, f = 1kHz 5 0.05 Typ % OFF-Isolation (1) Crosstalk in channel (1) Capacitance CIN Switch Input Capacitance (1) 5 5 Typ pF CCOM Common Output 5 25 Typ pF 5 50 Typ pF Capacitance (1) CPD Power Dissipation Capacitance (1) (1) Test data based on bench test and design simulation www.3peak.com 7 / 18 Rev.A.1 TPW4051 12V General Purpose Analog Switch Single Supply, VCC = 3 to 3.6V, VEE = 0V, GND = 0V, unless otherwise noted. Symbol Parameter Conditions VCC (V) 25°C -40°C to 85°C -40°C to 125°C Limit Unit VIN = VEE or VCC 3.6 4 6 8 Max μA Power Supply ICC Quiescent Supply Current Digital Input VIH Input Voltage High 2.0 2.0 Min V VIL Input Voltage Low 0.8 0.8 Max V IIN Control Input Leakage ±1 ±1 Max μA VIN = 0V or VCC 3.6 Analog Switch RON (1) IOUT = 1mA, VIS = VEE or VCC 3 300 Typ Ω RFLAT(ON) On Resistance Flatness (1) IOUT = 1mA 3 100 Typ Ω ICH(OFF) Switch OFF Leakage Current on Channel VIS = VEE, VOS = VCC; or VIS = VCC, VOS = VEE 3.6 ±0.4 ±1 ±1 Max μA ICOM(OFF) Switch OFF Leakage Current on Common VIS = VEE, VOS = VCC; or VIS = VCC, VOS = VEE, 3.6 ±0.4 ±4 ±4 Max μA I(ON) Switch ON Leakage Current VIS = VEE or VCC 3.6 ±0.4 ±4 ±4 Max μA Dynamic Characteristics tPHL, tPLH Switch IN to OUT time (1) CL = 50pF 3 5 Typ ns tON Switch turn-on time (1) CL = 50pF 3 70 Typ ns (1) CL = 50pF 3 60 Typ ns f = 1MHz, RL = 50Ω, CL = 10pF 3.3 -70 Typ dB f = 1MHz, RL = 50Ω, CL = 10pF 3.3 -70 Typ dB Between control and any switch; RL = 600Ω; f = 1 MHz; E or Sn square wave between VCC and GND 3.3 110 Typ mV tOFF Switch turn-off time OFF-Isolation (1) Crosstalk (1) Crosstalk in control (1) BW Bandwidth (1) RL = 50Ω 3.3 100 Typ MHz THD Total Harmonic Distortion (1) RL = 10kΩ, f = 1kHz 3.3 0.2 Typ % Capacitance CIN Switch Input Capacitance (1) 3.3 5 Typ pF CCOM Common Output 3.3 25 Typ pF 3.3 50 Typ pF Capacitance CPD (1) Power Dissipation Capacitance (1) (1) Test data based on bench test and design simulation www.3peak.com 8 / 18 Rev.A.1 TPW4051 12V General Purpose Analog Switch Single Supply, VCC = 9V to 11V, VEE = 0V, GND = 0V, unless otherwise noted. Symbol Parameter Conditions VCC (V) 25°C -40°C to 85°C -40°C to 125°C Limit Unit VIN = VEE or VCC 9 8 12 16 Max μA Power Supply ICC Quiescent Supply Current Digital Input VIH Input Voltage High 2.4 2.4 Min V VIL Input Voltage Low 0.8 0.8 Max V IIN Control Input Leakage ±1 ±1 Max μA Typ Ω VIN = 0V or VCC 11 ±0.4 IOUT = 1mA, VIS = VEE or VCC 9 50 IOUT = 1mA, VIS = VEE or VCC 9 80 95 105 Max Ω Analog Switch RON (1) RON ΔRON On Resistance Match between Channels IOUT = 1mA, VIS = 1V 9 15 25 30 Max Ω RFLAT(ON) On Resistance Flatness IOUT = 1mA 9 30 40 40 Max Ω ICH(OFF) Switch OFF Leakage Current on Channel VIS = VEE, VOS = VCC; or VIS = VCC, VOS = VEE 11 ±0.4 ±1 ±1 Max μA ICOM(OFF) Switch OFF Leakage Current on Common VIS = VEE, VOS = VCC; or VIS = VCC, VOS = VEE, 11 ±0.4 ±4 ±4 Max μA I(ON) Switch ON Leakage Current VIS = VEE or VCC 11 ±0.4 ±4 ±4 Max μA Dynamic Characteristics tPHL, tPLH Switch IN to OUT time (1) CL = 50pF 9 5 Typ ns tON Switch turn-on time CL = 50pF 9 60 Max ns tOFF Switch turn-off time CL = 50pF 9 50 Max ns f = 1MHz, RL = 50Ω, CL = 10pF 10 -70 Typ dB f = 1MHz, RL = 50Ω, CL = 10pF 10 -70 Typ dB Crosstalk in control (1) Between control and any switch; RL = 600Ω; f = 1 MHz; E or Sn square wave between VCC and GND 10 220 Typ mV BW Bandwidth (1) RL = 50Ω 10 200 Typ MHz THD Total Harmonic Distortion (1) RL = 10kΩ, f = 1kHz 10 0.03 Typ % OFF-Isolation Crosstalk (1) (1) Capacitance CIN Switch Input Capacitance (1) 10 5 Typ pF CCOM Common Output 10 25 Typ pF 10 50 Typ pF Capacitance (1) CPD Power Dissipation Capacitance (1) (1) Test data based on bench test and design simulation www.3peak.com 9 / 18 Rev.A.1 TPW4051 12V General Purpose Analog Switch Dual Supply, VCC = 4.5 to 5.5V, VEE = -4.5 to 5.5V, GND = 0V, unless otherwise noted. Symbol Parameter Conditions VCC /VEE(V) 25°C -40°C to 85°C -40°C to 125°C Limit Unit VIN = VEE or VCC 5.5/-5.5 8 12 16 Max μA Power Supply ICC Quiescent Supply Current Digital Input VIH Input Voltage High 70%* VCC 70%* VCC Min V VIL Input Voltage Low 30%* VCC 30%* VCC Max V IIN Control Input Leakage ±1 ±1 Max μA Typ Ω VIN = 0V or VCC 5.5/-5.5 ±0.4 IOUT = 1mA, VIS = VEE or VCC 4.5/-4.5 50 IOUT = 1mA, VIS = VEE or VCC 4.5/-4.5 80 95 105 Max Ω Analog Switch RON (1) RON ΔRON On Resistance Match between Channels IOUT = 1mA, VIS = -3.5V 4.5/-4.5 15 25 30 Max Ω RFLAT(ON) On Resistance Flatness IOUT = 1mA 4.5/-4.5 30 40 40 Max Ω ICH(OFF) Switch OFF Leakage Current on Channel VIS = VEE, VOS = VCC; or VIS = VCC, VOS = VEE 5.5/-5.5 ±0.4 ±1 ±1 Max μA ICOM(OFF) Switch OFF Leakage Current on Common VIS = VEE, VOS = VCC; or VIS = VCC, VOS = VEE, 5.5/-5.5 ±0.4 ±4 ±4 Max μA I(ON) Switch ON Leakage Current VIS = VEE or VCC 5.5/-5.5 ±0.4 ±4 ±4 Max μA Dynamic Characteristics tPHL, tPLH Switch IN to OUT time (1) CL = 50pF 4.5/-4.5 5 Typ ns tON Switch turn-on time CL = 50pF 4.5/-4.5 60 Max ns tOFF Switch turn-off time CL = 50pF 4.5/-4.5 50 Max ns OFF-Isolation (1) f = 1MHz, RL = 50Ω, CL = 10pF 5/-5 -70 Typ dB f = 1MHz, RL = 50Ω, CL = 10pF 5/-5 -70 Typ dB Between control and any switch; RL = 600Ω; f = 1 MHz; E or Sn square wave between VCC and GND 5/-5 220 Typ mV Crosstalk (1) Crosstalk in control (1) BW Bandwidth (1) RL = 50Ω 5/-5 200 Typ MHz THD Total Harmonic Distortion (1) RL = 10kΩ, f = 1kHz 5/-5 0.03 Typ % Capacitance CIN Switch Input Capacitance (1) 5/-5 5 Typ pF CCOM Common Output 5/-5 25 Typ pF 5/-5 50 Typ pF Capacitance CPD (1) Power Dissipation Capacitance (1) (1) Test data based on bench test and design simulation www.3peak.com 10 / 18 Rev.A.1 TPW4051 12V General Purpose Analog Switch Typical Performance Characteristics 250 1.0 0.0 Vcc=9v -1.0 Vcc=4.5V 150 Gain(dB) RON(OHM) 200 Vcc=3.0v 100 -2.0 -3.0 Vcc=9V -4.0 Vcc=4.5V -5.0 50 -6.0 0 0.0 2.0 4.0 6.0 -7.0 8.0 1M Vis(V) Figure 1. RON vs. VIS www.3peak.com 10M 100M Frenquency(Hz) Figure 2. Bandwidth 11 / 18 Rev.A.1 TPW4051 12V General Purpose Analog Switch Test Circuit and Waveforms VCC VIS AN A S1 VOS 1KΩ 50pF Sn,/E VEE Logic Input tON: tPZH or tPZL tOFF: tPHZ or tPLZ tR=6ns Switch Input 10% tF=6ns 90% 50% GND 90% 50% 10% tW tPLH tR=6ns Logic Input VEE 90% 50% 10% 90% 50% Vcc 10% Gnd tPHZ VCC tPZH tPHL 50% 50% 90% 50% VOH Output tF=6ns VOS VOL tPZL tPLZ VCC 50% 10% Figure 3 AC Test Circuit and Test Waveforms VCC Signal 0.1uF Generator 50Ω VCC SWITCH ON 50Ω Signal 0.1uF Generator 50Ω ½ Vcc ½ Vcc SWITCH OFF Analyzer 50Ω VCC 10pF ½ Vcc 50Ω ½ Vcc Figure 4 Off Isolation www.3peak.com 10pF SWITCH OFF Analyzer 50Ω 10pF ½ Vcc Figure 5 Crosstalk 12 / 18 Rev.A.1 TPW4051 12V General Purpose Analog Switch Application Information A 0.1-μF bypass capacitor on VCC and GND is recommended to prevent power disturbance, another 0.1-μF bypass capacitor on VEE and GND is also recommended if the VEE is not connected to GND. www.3peak.com 13 / 18 Rev.A.1 TPW4051 12V General Purpose Analog Switch Tape and Reel Information Order Number Package D1 W1 A0 B0 K0 P0 W0 Pin1 Quadrant TPW4051-SR SOIC-16 330 21.6 6.7±0.1 10.4±0.1 2.1±0.1 8.0±0.1 16.0±0.3 Q1 TPW4051-TR TSSOP-16 330 17.6 6.8±0.1 5.4±0.1 1.3±0.1 8.0±0.1 12.0±0.1 Q1 TPW4051-QF4R QFN-16 330 17.6 3.3±0.1 3.3±0.1 1.0±0.1 8.0±0.1 12.0±0.1 Q1 www.3peak.com 14 / 18 Rev.A.1 TPW4051 12V General Purpose Analog Switch Package Outline Dimensions SOIC-16 www.3peak.com 15 / 18 Rev.A.1 TPW4051 12V General Purpose Analog Switch Package Outline Dimensions TSSOP-16 www.3peak.com 16 / 18 Rev.A.1 TPW4051 12V General Purpose Analog Switch Package Outline Dimensions QFN-16 www.3peak.com 17 / 18 Rev.A.1 TPW4051 12V General Purpose Analog Switch IMPORTANT NOTICE AND DISCLAIMER Copyright© 3PEAK 2012-2023. All rights reserved. Trademarks. Any of the 思瑞浦 or 3PEAK trade names, trademarks, graphic marks, and domain names contained in this document /material are the property of 3PEAK. You may NOT reproduce, modify, publish, transmit or distribute any Trademark without the prior written consent of 3PEAK. Performance Information. Performance tests or performance range contained in this document/material are either results of design simulation or actual tests conducted under designated testing environment. Any variation in testing environment or simulation environment, including but not limited to testing method, testing process or testing temperature, may affect actual performance of the product. Disclaimer. 3PEAK provides technical and reliability data (including data sheets), design resources (including reference designs), application or other design recommendations, networking tools, security information and other resources "As Is". 3PEAK makes no warranty as to the absence of defects, and makes no warranties of any kind, express or implied, including without limitation, implied warranties as to merchantability, fitness for a particular purpose or non-infringement of any third-party’s intellectual property rights. Unless otherwise specified in writing, products supplied by 3PEAK are not designed to be used in any life-threatening scenarios, including critical medical applications, automotive safety-critical systems, aviation, aerospace, or any situations where failure could result in bodily harm, loss of life, or significant property damage. 3PEAK disclaims all liability for any such unauthorized use. www.3peak.com 18 / 18 Rev.A.1
TPW4051-TR 价格&库存
很抱歉,暂时无法提供与“TPW4051-TR”相匹配的价格&库存,您可以联系我们找货
TPW4051-TR
    • 5+1.38964
    • 50+1.06859
    • 600+0.75940
    • 1200+0.74801
    • 3000+0.68296
    库存:2965
    TPW4051-TR
      • 5+1.71580
      • 50+1.31930
      • 150+1.14950
      • 500+0.93760
      • 3000+0.84330
      库存:3140
      TPW4051-TR
      • 1+1.03761
      • 200+0.71631
      • 1500+0.65205
      • 3000+0.60858
      库存:2922
      TPW4051-TR
      • 3000+2.514863000+0.32508
      库存:2907
      TPW4051-TR
      • 1+5.379801+0.69540
      • 10+3.8042910+0.49175
      • 25+3.4037925+0.43998
      • 100+2.96861100+0.38373
      • 250+2.76078250+0.35686
      • 500+2.63525500+0.34064
      • 1000+2.532061000+0.32730
      库存:2907
      TPW4051-TR
        • 100+0.46380
        库存:2585
        TPW4051-TR
          • 10+0.39600
          库存:1055
          TPW4051-TR
            • 3000+0.62700
            库存:57047
