SSP809
Power Supply Supervisor
SSP809 series
General Description
The SSP809 series are highly accurate, low power consumption
voltage detectors, manufactured using CMOS and laser trimming
technologies. A delay circuit is built-in to each detectors. Detect
voltage is extremely accurate with minimal temperature drift.
Both CMOS and N-ch open drain output configurations are
available. Since the delay circuit is built-in, peripherals are
unnecessary and high density mounting is possible.
Features
Low power consumption
Low temperature coefficient
Built-in delay circuit: 200ms
High input voltage (up to 8V)
Output voltage accuracy: tolerance ±2%
SOT23 package
Applications
● Microprocessor reset circuitry
● Memory battery back-up circuits
● Power on reset circuits
● System battery life and charge voltage monitors
● Delay circuitry
● Power failure detection
上海矽朋微电子有限公司
V1.6
第1 页 共7 页
SSP809
Order Information
Part No
Mark
Detectable Voltage
SSP809C263
AFAA
2.63V
SSP809C293
ADAA
2.93V
SSP809C308
ACAA
3.08V
SSP809C400
CWAA
4.00V
SSP809C438
ABAA
4.38V
SSP809N263
BFAA
2.63V
SSP809N293
BDAA
2.93V
SSP809N308
BCAA
3.08V
SSP809N400
BWAA
4.00V
SSP809N438
BBAA
4.38V
Package
Devices per reel
SOT23
3000PCS
Note:SSP809①②③④
Designator
Symbol
Description
C
CMOS output
N
NMOS output
②
XXX
Detect voltage
③
N
Package:SOT23
R
RoHS/PbFree
G
Halogen Free
①
④
Block Diagram
上海矽朋微电子有限公司
V1.6
第2 页 共7 页
SSP809
Pin Assignment
SOT23 (TOP VIEW)
2
Table1
Pin No.
Pin Name
Function
1
GND
GND pin
2
VIN
Input voltage pin
3
Vout/Reset
Vout/Reset pin
Mark
1
SSP809C/SSP809N series (SOT23 PKG)
3
Functional Description
The SSP809 series are highly accurate, low power consumption voltage detectors,
manufactured using CMOS and laser trimming technologies. A delay circuit is builtin to each detectors. Detect voltage is extremely accurate with minimal temperature
drift.
Absolute Maximum Ratings
Parameter
Symbol
Value
Unit
Input Voltage
VIN
-0.3~8.0
V
Operating Temperature
Tamb
-30~80
Storage Temperature
Tstg
-40~125
Note: These are stress ratings only. Stresses exceeding the range specified under “Absolute
Maximum Ratings” may cause substantial damage to the device. Functional operation of
this device at other conditions beyond those listed in the specification is not implied and
prolonged exposure to extreme conditions may affect device reliability.
Thermal Information
Parameter
Symbol
Max.
Unit
Thermal Resistance (Junction to
Ambient) (Assume no ambient
airflow, no heat sink)
θ JA
250
℃/W
Power Dissipation
PD
0.20
W
上海矽朋微电子有限公司
V1.6
第3 页 共7 页
SSP809
Electrical Characteristics
Parameter
Symbol
Test Conditions
Min.
Input Voltage
(VCC) Range
VCC
25℃
1.2
Supply
Current
ISS
VIN=6V,Vdet=2.63V
1
TA=25℃
Vout/Reset
Threshold
VDET
Max.
Unit
7.5
V
1.8
2.5
μA
4.56
4.63
4.70
TA=25℃
4.31
4.38
4.45
TA=25℃
3.93
4.00
4.06
TA=25℃
3.04
3.08
3.11
TA=25℃
2.89
2.93
2.96
TA=25℃
2.59
2.63
2.66
Vout/Reset
Threshold
Stability
30
VCC to
Vout/Reset
Delay
Vout/Reset
Active Timeout
Period
Typ.
VCC=VTH to VTH 100mV
VOL
上海矽朋微电子有限公司
V1.6
V
Ppm/
us
200
ms
第4 页 共7 页
SSP809
Timing Chart
Application Circuits
CMOS Output
上海矽朋微电子有限公司
N-ch Open Drain Output
V1.6
第5 页 共7 页
SSP809
Package Information(SOT23)
Symbol
Dimensions In Millimeters
Dimensions In Inches
Min.
Max.
Min.
Max.
A
0.900
1.150
0.035
0.045
A1
0.000
0.100
0.000
0.004
A2
0.900
1.050
0.035
0.041
b
0.300
0.500
0.012
0.020
c
0.080
0.150
0.003
0.006
D
2.800
3.000
0.110
0.118
E
1.200
1.400
0.047
0.055
E1
2.250
2.550
0.089
0.100
0.950TYP.
e
e1
1.800
0.037TYP.
2.000
0.071
0.550REF.
L
0.079
0.022REF.
L1
0.300
0.500
0.012
0.020
θ
0°
8°
0°
8°
上海矽朋微电子有限公司
V1.6
第6 页 共7 页
SSP809
Special Instructions
The company reserves the right of final interpretation of this specification.
Version Change Description
Version:V1.6
2021.9.14
Author:Yangyang
Time:
Modify the record:
1. Re-typesetting the manual and checking some data
上海矽朋微电子有限公司
V1.6
第7 页 共7 页
很抱歉,暂时无法提供与“SSP809C293NR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.33633
- 100+0.26738
- 300+0.23291
- 3000+0.19987
- 6000+0.17914
- 9000+0.16878
