GBU8005 thru GBU810
8.0A Single-Phase GLass Passivated Bridge Rectifiers
Recifiter Reverse Voltage 50V to 1000V
GBU
Features
●Glass passivated junction
●The plastic material used carries Underwriters Laboratory
flammability recognition 94V-0
●Suge overload ratings to 200 amperes peak
●Ideal for printed circuit board application
●High temperature soldering guaranteed 265℃/10
Mechanical Data
Case:Molded plastic
Terminals:Platde leads solderable per MIL-STD-750,
Method 2026
Polarity:Polarity symbols molded or Marked on body
Mounting Position:Any
Weight:0.138ounce,3.9 grams(approx)
Maximum Ratings & Thermal Characteristics
Dimensions in inches and (milimeters)
Rating at 25℃ ambient temperature unless otherwise specified,Resistive or inductive load,60HZ.
For Capacitive load derate current by 20%
Parameter
Symbol GBU8005 GBU801 GBU802 GBU804 GBU806 GBU808 GBU810
unit
Maximum repetitive peak reverse voltage
VRRM
50
100
200
400
600
800
1000
V
Maximum RMS bridge input voltage
VRMS
35
70
140
280
420
560
700
V
VDC
50
100
200
400
8.0
600
800
1000
V
Maximum DC blocking voltage
Maximum average forward rectified
IF(AV)
output current at TA=40℃
Peak forward surge current single sine-wave
A
3.2
IFSM
200
A
I2 t
ReJA
166
Mounting torque(Suggests 045~0.65)
Tor
Rating Torque:0.8(Suggests 045~0.65)
A2sec
℃/w
N.m
Typical thermal resistance per element(2)
Cj
60.0
PF
Operating junction and stroage temperature
TJ,
-55to+150
superimposed on rated load (JEDEC Method)
Rating for fusing(t
很抱歉,暂时无法提供与“GBU806”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.75997
- 50+1.38921
- 150+1.23023
- 500+0.99846
- 2500+0.91023
- 5000+0.85720
