1N5408G(H3)
1N5408G(H3)
    PINGWEI(平伟)
    DO-27(DO-201AA)
    1N5408G(H3)
1N5408G(H3) 数据手册
1N5408G 规格书 1N5408G 3.0AMPS . GLASS PASSIVATED RECTIFIERS DO-27/DO-201AD FEATURE .High current capability .Low forward voltage drop .Low power loss, high efficiency .High surge capability .High temperature soldering guaranteed: 260°C /10sec/ 0.375" lead length at 5 lbs tension 0.96(24.4) MIN. .Terminal: Plated axial leads solderable per MIL-STD 202E, method 208C .Case: Molded with UL-94 Class V-0 recognized Flame Retardant Epoxy (free halogen) .Polarity: color band denotes cathode .Mounting position: any DIA. + .375(9.5) .335(8.5) MECHANICAL DATA .220(5.6) .187(5.0) - 0.96(24.4) MIN. .051(1.3) .043(1.1) DIA. Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25℃ ambient temperature unless otherwise specified. Single phase, half wave, 60Hz,resistive or inductive load. For capacitive load, derate current by 20% Type Number Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC blocking Voltage Maximum Average Forward Rectified Current .375"(9.5mm) lead length at TA =55°C SYMBOL 1N5408G units VRRM VRMS VDC 1000 V 700 V 1000 V IF(AV) 3.0 A IFSM 150.0 A VF 1.0 V Peak Forward Surge Current 8.3ms single half sine-wave superimposed on rated load (JEDEC method) Maximum Forward Voltage at 3.0A DC Maximum DC Reverse Current at rated DC blocking voltage @TA =25°C @TA =125°C Typical Junction Capacitance (Note 1) Typical Thermal Resistance (Note 2) Storage Temperature Operation Junction Temperature 10.0 IR 100.0 CJ R(JA) R(JC) TSTG TJ 35 20 15 pF °C/W -55 to +150 °C -55 to +150 °C Note: 1. Measured at 1.0 MHz and applied reverse voltage of 4.0Vdc 2. Thermal Resistance from Junction to Ambient at 0.375"(9.5mm)lead length, vertical P.C.Board Mounted. 1 µA 1N5408G 规格书 RATING AND CHARACTERISTIC CURVES (1N5408G) FIG.2-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE 3.0 1.5 0 INSTANEOUS FORWARD CURRENT,(A) AVERGE FORWARD RECTIFIED CURRENT,(A) 10.0 Single Phase Half Wave 60Hz Resistive or inductive Load 0 50 100 150 1.0 .1 .01 200 TJ=25℃ Pulse Width=300μs 1% Duty Cycle 0.9 .7 .5 1.1 INSTANEOUS FORWARD VOLTAGE,(V) LEAD TEMPERTURE,(℃) 1.3 FIG.4-TYPICAL REVERSE CHARACTERISTICS FIG.3-MAXIMUN NON-REPETITIVE FORWARD SURGE CURRENT 200 8.3ms Single Half Sine-Wave (JEDEC Method) 150 INSTANEOUS REVERSE CURRENT,(μA) PEAK FORWARD SURGE CURRENT,(A) 100 100 50 0 1 10 10 .1 100 TJ=25℃ 1 0 20 40 60 80 100 120 PERCENT OF RATED PEAK REVERSE VOLTAGE,(%) NUMBER OF CYCLES AT 60Hz 2 140 1N5408G Marking and packaging illustration 1、Marking SYMBOL A B C Explanation Color Band Denotes Cathode Product Name Trademark 2、Bending L DO-27 S 20±0.3 Ф1 5.2Max L 3.2~3.6 Ф2 1.2±0.1 VL=20.0*3.6 注:单位 mm 3、Packaging(B/P) OUTLINE DO-27 BOX (PCS) 200 CARTON SIZE (mm) L×W×H 450×210×265 CARTON (PCS) 10000
1N5408G(H3) 价格&库存
很抱歉,暂时无法提供与“1N5408G(H3)”相匹配的价格&库存,您可以联系我们找货
