BAT46X
BAT46X
    CBI(创基)
    SOD-523(SC-79)
    电压:100V 电流:150MA
BAT46X 数据手册
BAT46X SCHOTTKY BARRIER DIODE 62' FEATURES High breakdown voltage Low turn-on voltage z z Guard ring construction for transient protection z + MARKING: S9 The marking bar indicates the cathode Maximum Ratings @Ta=25℃ Symbol Parameter Peak repetitive peak reverse voltage VRRM Working peak reverse voltage VRWM Limit Unit 100 V DC blocking voltage current Forward continuous VIFR 150 mA Repetitive peak forward current (Note 1) @ tp < 1.0s, Duty Cycle < 50% IFRM 350 mA Non-repetitive Peak Forward surge current @ t = 8.3ms IFSM 750 mA Power dissipation PD 150 mW RθJA 667 ℃/W Tj -40 ~ +125 ℃ TSTG -55 ~ +150 ℃ Thermal resistance junction to ambient air Operating Junction Temperature Range Storage Temperature Range ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified) Parameter Reverse breakdown voltage(Note 2) Reverse voltage leakage current Forward voltage(Note 2) Diode capacitance Symbol VR IR VF CT Test Conditions IR= 100µA VR1=1.5V Min Typ Max 100 Unit V 0.3 VR2=10V 0.5 VR3=50V 1 VR4=75V 2 IF1=0.1mA IF2=10mA 0.25 0.45 IF3=250mA 1 VR=0, f=1MHz 20 VR=1V, f=1MHz 12 Notes: 1. Part mounted on FR-4 board with recommended pad layout. 2. Short duration pulse test used to minimize self-heating effect. 1 of 3 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd. µA V pF Typical Characteristics Forward Reverse Characteristics Characteristics 1000 300 (mA) 100 100 (uA) IF 00 =1 Ta 10 ℃ REVERSE CURRENT IR FORWARD CURRENT Ta=100 ℃ 5℃ =2 Ta 1 10 1 Ta=25 ℃ 0.1 0.1 0 100 200 300 400 FORWARD VOLTAGE 500 VF 600 700 0.01 800 0 10 20 (mV) 30 40 50 60 REVERSE VOLTAGE 70 VR 80 90 100 (V) Power Derating Curve Capacitance Characteristics 180 20 f=1MHz 150 (mW) CAPACITANCE BETWEEN TERMINALS CT (pF) Ta=25℃ POWER DISSIPATION PD 15 10 5 120 90 60 30 0 0 5 10 15 REVERSE VOLTAGE 20 VR 25 0 30 0 25 50 AMBIENT TEMPERATURE (V) 75 100 Ta (℃ ) 2 of 3 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd. 125     PACKAGE OUTLINE Plastic surface mounted package; 2 leads SOD-523 Dimension in Millimeters Symbol Min Max A 0.60 0.70 A1 0 0.05 B 0.75 0.85 bp 0.25 0.40 C 0.09 0.15 E 1.15 1.25 HE 1.50 1.70 3 of 3 Copyright © All right reserved Heyuan China Base Electronics Technology Co., Ltd.
BAT46X 价格&库存
很抱歉,暂时无法提供与“BAT46X”相匹配的价格&库存,您可以联系我们找货
BAT46X
  • 50+0.12140
  • 500+0.09461
  • 3000+0.07971
  • 6000+0.07074
  • 24000+0.06297
  • 51000+0.05886
库存:449
