BZT52CxxT
Zener Diode
»Features
Low Zener Impedance
Power Dissipation of 200mW
High Stability and High Reliability
SOD-523
»General Description
Case: molded plastic
Polarity: Color band denotes cathode
Package: SOD-523 Plastic Package
Epoxy UL: 94V-0
» Maximum Ratings @T =25℃ unless otherwise noted
A
Parameters
Symbol
Value
Unit
Power Dissipation
Pd
200
mW
Forward Voltage @IF=10mA
Junction temperature
Vf
0.9
Tj
150
V
Storage temperature range
Ts
-65-+150
Revision 2018
www.born-tw.com
1/5
BZT52CxxT
»Electrical Characteristics @T =25℃ unless otherwise noted
A
Zener Voltage Range
Device
Vz@Izt
Izt
Maximum Zener
Impedance
Zzt
Zzk
Izk
@Izt
@Izk
Ω
mA
Maximum
Reverse Current
Typical
Temperature
coefficent @
IZTC=mV/℃
Test
Current
IZTC
IR
VR
uA
V
Min
Max
mA
1.0
50
1.0
-3.5
600
1.0
-3.5
100
600
1.0
10
1.0
-3.5
5
95
600
1.0
5
1.0
-3.5
3.8
5
90
600
1.0
5
1.0
-3.5
3.7
4.1
5
90
600
1.0
3
1.0
-3.5
4.3
4.0
4.6
5
90
600
1.0
3
1.0
-3.5
BZT52C4V7T
4.7
4.4
5.0
5
80
500
1.0
3
2.0
-3.5
0.2
5
BZT52C5V1T
5.1
4.8
5.4
5
60
480
1.0
2
2.0
-2.7
1.2
5
BZT52C5V6T
5.6
5.2
6.0
5
40
400
1.0
1
2.0
-2.0
2.5
5
BZT52C6V2T
6.2
5.8
6.6
5
10
150
1.0
3
4.0
0.4
3.7
5
BZT52C6V8T
6.8
6.4
7.2
5
15
80
1.0
2
4.0
1.2
4.5
5
BZT52C7V5T
7.5
7.0
7.9
5
15
80
1.0
1
5.0
2.5
5.3
5
BZT52C8V2T
8.2
7.7
8.7
5
15
80
1.0
0.7
5.0
3.2
6.2
5
BZT52C9V1T
9.1
8.5
9.6
5
15
100
1.0
0.5
6.0
3.8
7.0
5
BZT52C10T
10
9.4
10.6
5
1.0
0.2
7.0
4.5
8.0
5
BZT52C11T
11
10.4
11.6
5
1.0
0.1
8.0
5.4
9.0
5
BZT52C12T
12
11.4
12.7
5
25
150
1.0
0.1
8.0
6.0
10.0
5
BZT52C13T
13
12.4
14.1
5
30
170
1.0
0.1
8.0
7.0
11.0
5
BZT52C15T
15
13.8
15.6
5
30
200
1.0
0.1
10.5
9.2
13.0
5
BZT52C16T
16
15.3
17.1
5
40
200
1.0
0.1
11.2
10.4
14.0
5
BZT52C18T
18
16.8
19.1
5
45
225
1.0
0.1
12.6
12.4
16.0
5
BZT52C20T
21.2
5
55
225
1.0
0.1
14.0
14.4
18.0
5
BZT52C22T
22
20.8
23.3
5
55
250
1.0
0.1
15.4
16.4
20.0
5
BZT52C24T
24
22.8
25.6
5
70
250
1.0
0.1
16.8
18.4
22.0
5
BZT52C27T
27
25.1
28.9
2
80
300
0.5
0.1
18.9
21.4
25.3
2
BZT52C30T
30
28.0
32.0
2
80
300
0.5
0.1
21.0
24.4
29.4
2
BZT52C33T
33
31.0
35.0
2
80
325
0.5
0.1
23.1
27.4
33.4
2
BZT52C36T
36
34.0
38.0
2
90
350
0.5
0.1
25.2
30.4
37.4
2
BZT52C39T
39
37.0
41.0
2
130
350
0.5
0.1
27.3
33.4
41.2
2
BZT52C43T
43
40.0
46.0
2
100
700
1.0
0.1
32.0
10.0
12.0
5
BZT52C47T
47
44.0
50.0
2
100
750
1.0
0.1
35.0
10.0
12.0
5
BZT52C51T
51
48.0
54.0
2
100
750
1.0
0.1
38.0
10.0
12.0
5
Nom(V)
Min(V)
Max(V)
mA
BZT52C2V4T
2.4
2.2
2.6
5
100
600
BZT52C2V7T
2.7
2.5
2.9
5
100
BZT52C3V0T
3.0
2.8
3.2
5
BZT52C3V3T
3.3
3.1
3.5
BZT52C3V6T
3.6
3.4
BZT52C3V9T
3.9
BZT52C4V3T
Revision 2018
www.born-tw.com
2/5
BZT52CxxT
»Typical Performance Characteristics((TJ = 25 °C, unless otherwise noted))
1000
TJ = 25C
IZ(AC) = 0.1 Z(DC)
f = 1 kHz
IF, FORWARD CURRENT (mA)
Z ZT , DYNAMIC IMPEDANCE ( )
1000
100
100
IZ = 1 mA
5 mA
10
150C
10
75C
3.0
10
VZ, NOMINAL ZENER VOLTAGE
80
0.4
0.5
0C
0.6
0.7
0.8
0.9
1.0
VF, FORWARD VOLTAGE (V)
1.1
1.2
60
70
Figure 2. Typical Forward Voltage
Figure 1. Effect of Zener Voltage on
Zener Impedance
1000
1000
TA = 25C
0 V BIAS
100
100
IR, LEAKAGE CURRENT
( A)
C, CAPACITANCE (pF)
25C
1.0
1.0
1 V BIAS
10
1.0
+150C
0.1
BIAS AT
50% OF VZ NOM
10
0.01
+25C
0.001
–55C
0.0001
0.00001
1.0
4.0
10
VZ, NOMINAL ZENER VOLTAGE (V)
70
Figure 3. Typical Capacitance
Revision 2018
10
40
50
Figure 4. Typical Leakage Current
www.born-tw.com
3/5
BZT52CxxT
100
100
TA = 25C
IZ , ZENER CURRENT (mA)
IZ, ZENER CURRENT (mA)
TA = 25C
10
1.0
0.1
0.01
10
1
0.1
0.01
4.0
6.0
8.0
VZ, ZENER VOLTAGE (V)
10
12
Figure 5. Zener Voltage versus Zener Current
(VZ Up to 12 V)
10
30
50
70
90
Figure 6. Zener Voltage versus Zener Current
(12 V to 75 V)
POWER DISSIPATION (%)
100
80
60
40
50
75
100
TEMPERATURE (C)
125
150
Figure 7. Steady State Power Derating
Revision 2018
www.born-tw.com
4/5
BZT52CxxT
»Package Information
SOD-523
A
Millimeters
B
D
1
2
C
K
J
Revision 2018
Inches
DIM
Min
Max
Min
Max
A
1.10
1.30
0.043
0.051
B
0.70
0.90
0.028
0.035
C
0.50
0.70
0.020
0.028
D
0.25
0.35
0.010
0.014
J
0.07
0.20
K
0.15
0.25
0.006
0.010
S
1.50
1.70
0.059
0.067
0.0028 0.0079
S
www.born-tw.com
5/5
很抱歉,暂时无法提供与“BZT52C3V3T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.38940
- 200+0.12980
- 1500+0.08118
- 3000+0.06435
- 国内价格
- 50+0.13284
- 500+0.10433
- 3000+0.08846
- 6000+0.07895
- 24000+0.07064
- 51000+0.06621
