MM5Z4V7
MM5Z4V7
    HXY(华轩阳)
    SOD-523(SC-79)
    独立式 耐压:4.7V 电流:3UA
MM5Z4V7 数据手册
HUAXUANYANG HXY MM5ZXX ELECTRONICS CO.,LTD Zener Voltage Regulators Specification Features: • Standard Zener Breakdown Voltage Range – 2.0 V to 75 V • Steady State Power Rating of 200 mW • Small Body Outline Dimensions: 0.047" x 0.032"(1.20 mm x 0.80 mm) • Low Body Height: 0.028" (0.7 mm) • ESD Rating of Class 3 (>16 kV) per Human Body Model • S- Prefix for Automotive and Other Applications Requiring Unique Site and Control Change Requirements; AEC-Q101 Qualified and PPAP Capable. 1 2 SOD-523 Package Marking and Ordering Information Pack Marking SOD-523 XX Product ID MM5ZXX 2 1 CATHODE Qty(PCS) ANODE 3000 XX=Device code, see table on page2 the marking code. The marking bar indicates the cathode. Absolute Maximum Ratings(Ta=25℃) Rating Symbol Max Unit PD 200 mW TJ, Tstg −65 to +150 °C Total Device Dissipation FR−5 Board, @ TA = 25°C Junction and Storage Temperature Range ELECTRICAL CHARACTERISTICS BZT52CXX Series (TA = 25°C unless otherwise noted, VF = 0.9 V Max. @ IF = 10 mA for all types) Parameter Symbol VZ Reverse Zener Voltage @ IZT IZT Reverse Current ZZT Maximum Zener Impedance @ IZT IZK Reverse Current ZZK Maximum Zener Impedance @ IZK IR Reverse Leakage Current @ VR VR Reverse Voltage IF Forward Current VF Forward Voltage @ IF QVZ C I IF VZ VR IR VF IZT V Maximum Temperature Coefficient of VZ Max. Capacitance @VR = 0 and f = 1 MHz Shenzhen HuaXuanYang Electronics CO.,LTD Zener Voltage Regulator www.hxymos.com HUAXUANYANG HXY MM5ZXX ELECTRONICS CO.,LTD Zener Voltage Regulators ELECTRICAL CHARACTERISTICS (TA = 25°C unless otherwise noted, VF = 0.9 V Max. @ IF = 10 mA for all types) Zener Voltage (Note 1) Zener Impedance Leakage Current QVZ (mV/k) @ IZT C @ VR = 0 f = 1 MHz @ IZT ZZT @ IZT Max mA W W mA mA Volts Min Max pF 2.0 2.4 2.7 3.0 3.3 3.6 2.09 2.6 2.9 3.2 3.5 3.8 5 5 5 5 5 5 100 100 100 100 95 90 600 1000 1000 1000 1000 1000 1.0 1.0 1.0 1.0 1.0 1.0 150 50 20 10 5 5 1.0 1.0 1.0 1.0 1.0 1.0 –3.5 −3.5 −3.5 −3.5 −3.5 −3.5 0 0 0 0 0 0 450 450 450 450 450 450 3.7 4.0 4.4 4.8 5.2 3.9 4.3 4.7 5.1 5.6 4.1 4.6 5.0 5.4 6.0 5 5 5 5 5 90 90 80 60 40 1000 1000 800 500 400 1.0 1.0 1.0 1.0 1.0 3 3 3 2 1 1.0 1.0 2.0 2.0 2.0 −3.5 −3.5 −3.5 −2.7 −2.0 −2.5 0 0.2 1.2 2.5 450 450 260 225 200 0E 0F 0G 0H 0K 5.8 6.4 7.0 7.7 8.5 6.2 6.8 7.5 8.2 9.1 6.6 7.2 7.9 8.7 9.6 5 5 5 5 5 10 15 15 15 15 100 160 160 160 160 1.0 1.0 1.0 1.0 1.0 3 2 1 0.7 0.2 4.0 4.0 5.0 5.0 7.0 0.4 1.2 2.5 3.2 3.8 3.7 4.5 5.3 6.2 7.0 185 155 140 135 130 MM5Z10V MM5Z11V MM5Z12V MM5Z13V MM5Z15V 0L 0M 0N 0P 0T 9.4 10.4 11.4 12.4 14.3 10 11 12 13.25 15 10.6 11.6 12.7 14.1 15.8 5 5 5 5 5 20 20 25 30 30 160 160 80 80 200 1.0 1.0 1.0 1.0 1.0 0.1 0.1 0.1 0.1 0.05 8.0 8.0 8.0 8.0 10.5 4.5 5.4 6.0 7.0 9.2 8.0 9.0 10 11 13 130 130 130 120 110 MM5Z16V MM5Z18V MM5Z20V MM5Z22V MM5Z24V 0U 0W 0Z 10 11 15.3 16.8 18.8 20.8 22.8 16.2 18 20 22 24.2 17.1 19.1 21.2 23.3 25.6 2 2 2 2 2 40 45 55 55 70 200 225 225 250 120 1.0 1.0 1.0 1.0 1.0 0.05 0.05 0.05 0.05 0.05 11.2 12.6 14.0 15.4 16.8 10.4 12.4 14.4 16.4 18.4 14 16 18 20 22 105 100 85 85 80 MM5Z27V MM5Z30V MM5Z33V MM5Z36V MM5Z39V 12 14 18 19 20 25.1 28 31 34 37 27 30 33 36 39 28.9 32 35 38 41 2 2 2 2 2 80 80 80 90 130 300 300 300 500 500 1.0 1.0 1.0 1.0 1.0 0.05 0.05 0.05 0.05 0.05 18.9 21.0 23.2 25.2 27.3 21.4 24.4 27.4 30.4 33.4 25.3 29.4 33.4 37.4 41.2 70 70 70 70 45 VZ (Volts) Device Marking Min Nom MM5Z2V0 MM5Z2V4 MM5Z2V7 MM5Z3V0 MM5Z3V3 MM5Z3V6 WY 00 01 02 05 06 1.91 2.2 2.5 2.8 3.1 3.4 MM5Z3V9 MM5Z4V3 MM5Z4V7 MM5Z5V1 MM5Z5V6 07 08 09 0A W9 MM5Z6V2 MM5Z6V8 MM5Z7V5 MM5Z8V2 MM5Z9V1 Device ZZK @ IZK IR @ VR 1. Zener voltage is measured with a pulse test current IZ at an ambient temperature of 25°C. Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HUAXUANYANG HXY MM5ZXX ELECTRONICS CO.,LTD Zener Voltage Regulators Typical Characteristics 1000 TJ = 25°C IZ(AC) = 0.1 IZ(DC) f = 1 kHz IF, FORWARD CURRENT (mA) Z ZT , DYNAMIC IMPEDANCE ( Ω) 1000 100 IZ = 1 mA 5 mA 10 100 150°C 10 75°C 3.0 10 VZ, NOMINAL ZENER VOLTAGE 80 0.4 Figure 1. Effect of Zener Voltage on Zener Impedance 0°C 1.0 0.6 0.7 0.8 0.9 VF, FORWARD VOLTAGE (V) 0.5 1.1 1.2 Figure 2. Typical Forward Voltage 1000 TA = 25°C 0 V BIAS 100 1 V BIAS BIAS AT 50% OF VZ NOM 10 IR, LEAKAGE CURRENT ( µA) 1000 C, CAPACITANCE (pF) 25°C 1.0 1.0 100 10 1.0 +150°C 0.1 0.01 0.001 +25°C 0.0001 –55°C 0.00001 1.0 4.0 10 VZ, NOMINAL ZENER VOLTAGE (V) Figure 3. Typical Capacitance Shenzhen HuaXuanYang Electronics CO.,LTD 70 0 10 20 30 40 50 60 VZ, NOMINAL ZENER VOLTAGE (V) 70 Figure 4. Typical Leakage Current www.hxymos.com HUAXUANYANG HXY MM5ZXX ELECTRONICS CO.,LTD Zener Voltage Regulators Typical Characteristics 100 100 TA = 25°C IZ , ZENER CURRENT (mA) I Z , ZENER CURRENT (mA) TA = 25°C 10 1.0 0.1 0.01 10 1 0.1 0.01 0 2.0 4.0 6.0 8.0 VZ, ZENER VOLTAGE (V) 10 Figure 5. Zener Voltage versus Zener Current (VZ Up to 12 V) 12 10 30 50 70 VZ, ZENER VOLTAGE (V) 90 Figure 6. Zener Voltage versus Zener Current (12 V to 75 V) POWER DISSIPATION (%) 100 80 60 40 20 0 0 25 50 75 100 TEMPERATURE (°C) 125 150 Figure 7. Steady State Power Derating Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HUAXUANYANG HXY ELECTRONICS CO.,LTD MM5ZXX Zener Voltage Regulators SOD-523 Package Outline Dimensions 6\P RO A A1 b c D E E1 E2 L  LPHQVLRQV,Q0LOOLPHWHUV 0LQ 0D[ 0.510 0.770 0.500 0.700 0.250 0.350 0.080 0.150 0.750 0.850 1.100 1.300 1.500 1.700 0.200 REF 0.010 0.070 7° REF Shenzhen HuaXuanYang Electronics CO.,LTD LPHQVLRQV,Q,QFKHV 0LQ 0D[ 0.020 0.031 0.020 0.028 0.010 0.014 0.003 0.006 0.030 0.033 0.043 0.051 0.067 0.059 0.008 REF 0.001 0.003 7° REF www.hxymos.com HUAXUANYANG HXY MM5ZXX ELECTRONICS CO.,LTD Zener Voltage Regulators Attention ■ Any and all HUA XUAN YANG ELECTRONICS products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your HUA XUAN YANG ELECTRONICS representative nearest you before using any HUA XUAN YANG ELECTRONICS products described or contained herein in such applications. ■ HUA XUAN YANG ELECTRONICS assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein. ■ Specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’s products or equipment. ■ HUA XUAN YANG ELECTRONICS CO.,LTD. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with some probability. It is possible that these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits and error prevention circuits for safe design, redundant design, and structural design. ■ In the event that any or all HUA XUAN YANG ELECTRONICS products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from the authorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of HUA XUAN YANG ELECTRONICS CO.,LTD. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. HUA XUAN YANG ELECTRONICS believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringements of intellectual property rights or other rights of third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. When designing equipment, refer to the "Delivery Specification" for the HUA XUAN YANG ELECTRONICS product that you intend to use. Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com
MM5Z4V7 价格&库存
很抱歉,暂时无法提供与“MM5Z4V7”相匹配的价格&库存,您可以联系我们找货
