MM5Z9V1
MM5Z9V1
    YONGYUTAI(永裕泰)
    SOD-523(SC-79)
    稳压二极管 独立式 耐压:9.1V 电流:0.5UA@6V
MM5Z9V1 数据手册
MM5Z9V1 Silicon Planar Zener Diodes Datasheet SILICON PLANAR ZENER DIODES PINNING Features DESCRIPTION PIN • Standard Zener Breakdown Voltage Range 9.1 V 1 Cathode 2 Anode • Steady State Power Rating of 200 mW       1 2 Top View Simplified outline SOD-523 and symbol Absolute Maximum Ratings (Ta = 25 OC) Parameter Symbol Value Unit Ptot 200 mW Tj , Tstg - 65 to + 150 Symbol Max. VF 0.9 Total Device Dissipaton Junction and Storage Temperature Range C O Characteristics at Ta = 25 OC Parameter Forward Voltage at IF = 10 mA       Type     Zener Voltage Marking Code   MM5Z9V1 1) Zener Impedance N8 at lZT   V   1) VZT (V) Unit ZZT ZZK Leakage Current at IZK IR at VR Min. Nom. Max. mA Ω Ω mA µA V 8.5 9.1 9.6 5 15 160 1 0.5 6 Tested with pulses tp = 20 ms. Power Dissipation: Ptot (mW) 300 200 100                                   0 25 0 150 100 Ambient Temperature: Ta ( C) O Derating Curve www.yongyutai.com 1 Rev.-2.0 MM5Z9V1 Silicon Planar Zener Diodes Datasheet PACKAGE OUTLINE Plastic surface mounted package; 2 leads www.yongyutai.com SOD-523 2 Rev.-2.0
MM5Z9V1 价格&库存
很抱歉,暂时无法提供与“MM5Z9V1”相匹配的价格&库存,您可以联系我们找货
MM5Z9V1
  • 50+0.10887
  • 500+0.08554
  • 3000+0.06934
  • 6000+0.06156
  • 24000+0.05476
  • 51000+0.05120
库存:2790
