BAS521
High Voltage Switching Diode
2
FEATURES
Ultra small plastic SMD package
High continuous reverse voltage: 300V
Repetitive peak forward current: 250 mA
1.Cathode
2.Anode
1
High switching speed: max. 50ns
■ Simplified outline(SOD-523)
Top View
APPLICATIONS
High speed switching.
High voltage switching.
MAXIMUM RATING @ Ta=25℃ unless otherwise specified
Parameter
Repetitive peak reverse voltage
Continuous reverse voltage
Continuous forward current
Repetitive forward current
Ts≤90°C; Note 1
tp=1ms
Non-repetitive peak forward surge current
tp=1ms; square wave; Tj=25°C prior to surge
Total power dissipation
Ts≤90°C; Note 1
Junction temperature
Storage And operating ambient temperature
Symbol
Limits
Unit
VRRM
300
V
VR
300
V
IF
250
mA
IFRM
1
A
IFSM
4.5
A
Ptot
500
mW
Tj
150
Tstg, Tamb
-65 to +150
Note
1. Ts is the temperature at the soldering point of the cathode tab.
■ Marking
Marking
www.slkormicro.com
L4
1
Rev.1 -- 09 June 2017
BAS521
ELECTRICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified
Parameter
Symbol
Conditions
Min.
Typ.
breakdown voltage
VBR
IR=100uA
300
340
Forward voltage
VF
IF=100mA
0.95
1.1
V
VR=250V
30
150
nA
Reverse current
IR
40
100
μA
VR=250V,TJ=150 ℃
Diode capacitance
Reverse recovery time
Max.
Unit
V
Cd
VR=0,f=1MHz
0.4
5
pF
trr
when switched from IF=30
mA to IR=30mA; RL=100W;
measured at IR=3mA
16
50
ns
TYPICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified
www.slkormicro.com
2
BAS521
www.slkormicro.com
3
BAS521
PACKAGE OUTLINE
Plastic surface mounted package
SOD-523
SOD-523
Dim
Min
Max
A
1.10
1.30
B
0.70
0.90
C
0.50
0.70
D
0.25
0.35
E
0.15
0.25
J
0.05
0.15
K
1.50
1.70
All Dimensions in mm
SOLDERING FOOTPRINT
Unit: mm
www.slkormicro.com
4
很抱歉,暂时无法提供与“BAS521”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.35750
- 200+0.11990
- 1500+0.07458
- 3000+0.05929
