BZT52C3V6T
BZT52C3V6T
    YONGYUTAI(永裕泰)
    SOD-523(SC-79)
    独立式 耐压:3.6V 电流:10UA@1V
BZT52C3V6T 数据手册
BZT52CxxT Series Silicon Planar Zener Diodes Datasheet SILICON PLANAR ZENER DIODES PINNING Features PIN • Standard Zener Breakdown Voltage Range 2.0 V to 75 V DESCRIPTION 1 Cathode 2 Anode • Steady State Power Rating of 200 mW 1       2 Top View Simplified outline SOD-523 and symbol Absolute Maximum Ratings (Ta = 25 OC) Parameter Total Device Dissipaton Junction and Storage Temperature Range Symbol Value Unit Ptot 200 mW Tj , Tstg - 65 to + 150 Symbol Max. VF 0.9 C O Characteristics at Ta = 25 OC Parameter Forward Voltage at IF = 10 mA www.yongyutai.com   1 Unit   V   Rev.-2.0 BZT52CxxT Series Silicon Planar Zener Diodes Datasheet BZT52C2V0T THRU BZT52C75T       Type   Zener Voltage Marking Code   1) VZT (V) Zener Impedance at lZT ZZT ZZK Leakage Current at IZK IR at VR Min. Nom. Max. mA Ω Ω mA µA V BZT52C2V0T RD 1.8 2.0 2.15 5 100 - - 120 0.5 BZT52C2V2T RE 2.08 2.2 2.33 5 100 - - 120 0.7 BZT52C2V4T Z7 2.2 2.4 2.6 5 100 1000 1 120 1 BZT52C2V7T A8 2.5 2.7 2.9 5 100 1000 1 120 1 BZT52C3V0T B8 2.8 3.0 3.2 5 100 1000 1 50 1 BZT52C3V3T C8 3.1 3.3 3.5 5 95 1000 1 20 1 BZT52C3V6T D8 3.4 3.6 3.8 5 90 1000 1 10 1 BZT52C3V9T E8 3.7 3.9 4.1 5 90 1000 1 5 1 BZT52C4V3T F8 4 4.3 4.6 5 90 1000 1 5 1 BZT52C4V7T G8 4.4 4.7 5 5 80 800 1 2 1 BZT52C5V1T H8 4.8 5.1 5.4 5 60 500 1 2 1.5 BZT52C5V6T I8 5.2 5.6 6 5 40 200 1 1 2.5 BZT52C6V2T J8 5.8 6.2 6.6 5 10 100 1 1 3 BZT52C6V8T K8 6.4 6.8 7.2 5 15 160 1 0.5 3.5 BZT52C7V5T L8 7 7.5 7.9 5 15 160 1 0.5 4 BZT52C8V2T M8 7.7 8.2 8.7 5 15 160 1 0.5 5 BZT52C9V1T N8 8.5 9.1 9.6 5 15 160 1 0.5 6 BZT52C10T O8 9.4 10 10.6 5 20 160 1 0.1 7 BZT52C11T P8 10.4 11 11.6 5 20 160 1 0.1 8 BZT52C12T Q8 11.4 12 12.7 5 25 80 1 0.1 9 BZT52C13T R8 12.4 13 14.1 5 30 80 1 0.1 10 BZT52C15T S8 14.3 15 15.8 5 30 80 1 0.1 11 BZT52C16T T8 15.3 16 17.1 2 40 80 1 0.1 12 BZT52C18T U8 16.8 18 19.1 2 45 80 1 0.1 13 BZT52C20T V8 18.8 20 21.2 2 55 100 1 0.1 15 BZT52C22T W8 20.8 22 23.3 2 55 100 1 0.1 17 BZT52C24T X8 22.8 24 25.6 2 70 120 1 0.1 19 BZT52C27T Y8 25.1 27 28.9 2 80 300 1 0.1 21 BZT52C30T Z8 28 30 32 2 80 300 1 0.1 23 BZT52C33T A9 31 33 35 2 80 300 1 0.1 25 BZT52C36T B9 34 36 38 2 90 500 1 0.1 27 BZT52C39T C9 37 39 41 2 130 500 1 2 30 BZT52C43T D9 40 43 46 1 150 500 1 2 33 BZT52C47T E9 44 47 50 1 170 500 1 2 36 BZT52C51T F9 48 51 54 1 180 500 1 1 39 BZT52C56T G9 52 56 60 1 200 500 1 1 43 BZT52C62T H9 58 62 66 1 215 500 1 0.2 47 BZT52C68T I9 64 68 72 1 240 500 1 0.2 52 BZT52C75T J9 70 75 79 1 255 500 1 0.2 57 1) Tested with pulses tp = 20 ms. www.yongyutai.com 2 Rev.-2.0 BZT52CxxT Series Silicon Planar Zener Diodes Datasheet   BZT52C2V0T THRU BZT52C75T Power Dissipation: Ptot (mW) 300 200 100                                   0 25 0 150 100 Ambient Temperature: Ta ( C) O Derating Curve www.yongyutai.com 3 Rev.-2.0 BZT52CxxT Series Silicon Planar Zener Diodes Datasheet PACKAGE OUTLINE Plastic surface mounted package; 2 leads www.yongyutai.com SOD-523 4 Rev.-2.0
BZT52C3V6T 价格&库存
很抱歉,暂时无法提供与“BZT52C3V6T”相匹配的价格&库存,您可以联系我们找货
BZT52C3V6T
  • 50+0.10563
  • 500+0.08230
  • 3000+0.06934
  • 6000+0.06156
  • 24000+0.05476
  • 51000+0.05120
库存:471
