BZX584C4V7
BZX584C4V7
    LGE(鲁光)
    SOD-523(SC-79)
    独立式 耐压:4.7V 电流:3UA@2.0V
BZX584C4V7 数据手册
SMT-Type Zener Diode BZX584C2V0 - BZX584C75 FEATURES • • • • Large selection of zener voltages: 2.0V ~ 75V Tight voltage tolerance: ±5% for C-series Ultra low-profile package well suited for automated assembly MSL Class 1 compatible APPLICATIONS • • General voltage regulation Mobile & handheld systems SOD-523 ORDERING INFORMATION Part Number BZX584C2V0 - BZX584C75 Marking Package See Electrical Characteristics SOD-523 MAXIMUM RATING (@ TA = 25°C unless otherwise specified) Parameter Symbol Value Forward Voltage @ IF=10mA VF 0.9 V Power Dissipation (Collector) PC 150 mW RθJA 834 °C/W Junction Temperature Range TJ -55 ~ +150 °C Storage Temperature Range TSTG -65 ~ +150 °C Thermal Resistance (Junction-to-Ambient) Unit Note: These ratings are limiting values above which the serviceability of the diodes may be impaired. Revision:20170701-P1 ht t p : // www.lgesemi .c o m mail:lge@lgesemi.com SMT-Type Zener Diode BZX584C2V0 - BZX584C75 ELECTRICAL CHARACTERISTICS (@ TA = 25°C unless otherwise specified) Part Number BZX584C2V0 BZX584C2V2 BZX584C2V4 BZX584C2V7 BZX584C3V0 BZX584C3V3 BZX584C3V6 BZX584C3V9 BZX584C4V3 BZX584C4V7 BZX584C5V1 BZX584C5V6 BZX584C6V2 BZX584C6V8 BZX584C7V5 BZX584C8V2 BZX584C9V1 BZX584C10 BZX584C11 BZX584C12 BZX584C13 BZX584C15 BZX584C16 BZX584C18 BZX584C20 BZX584C22 BZX584C24 BZX584C27 BZX584C30 BZX584C33 BZX584C36 BZX584C39 BZX584C43 BZX584C47 BZX584C51 BZX584C56 BZX584C62 BZX584C68 BZX584C75 Revision:20170701-P2 Marking Code Z10 Z19 Z11 Z12 Z13 Z14 Z15 Z16 Z17 Z1 Z2 Z3 Z4 Z5 Z6 Z7 Z8 Z9 Y1 Y2 Y3 Y4 Y5 Y6 Y7 Y8 Y9 Y10 Y11 Y12 Y13 Y14 Y15 Y16 Y17 Y18 Y19 Y20 Y21 Zener Voltage VZ (V) Min. Typ. Max. 1.90 2.09 2.28 2.57 2.85 3.14 3.42 3.71 4.09 4.47 4.85 5.32 5.89 6.46 7.13 7.79 8.65 9.50 10.45 11.40 12.35 14.25 15.20 17.10 19.00 20.90 22.80 25.65 28.50 31.35 34.20 37.05 40.85 44.65 48.45 53.20 58.90 64.60 71.25 2.00 2.20 2.40 2.70 3.00 3.30 3.60 3.90 4.30 4.70 5.10 5.60 6.20 6.80 7.50 8.20 9.10 10.00 11.00 12.00 13.00 15.00 16.00 18.00 20.00 22.00 24.00 27.00 30.00 33.00 36.00 39.00 43.00 47.00 51.00 56.00 62.00 68.00 75.00 2.10 2.31 2.52 2.84 3.15 3.47 3.78 4.10 4.52 4.94 5.36 5.88 6.51 7.14 7.88 8.61 9.56 10.50 11.55 12.60 13.65 15.75 16.80 18.90 21.00 23.10 25.20 28.35 31.50 34.65 37.80 40.95 45.15 49.35 53.55 58.80 65.10 71.40 78.75 ht t p : // @ IZT (mA) 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 2 2 2 2 2 2 2 2 2 2 2 2 Maximum Zener Impedance ZZT (Ω) @ IZK ZZK (Ω) @ IZT (mA) 100 600 1.0 100 600 1.0 100 600 1.0 100 600 1.0 95 600 1.0 95 600 1.0 90 600 1.0 90 600 1.0 90 600 1.0 80 500 1.0 60 480 1.0 40 400 1.0 10 150 1.0 15 80 1.0 15 80 1.0 15 80 1.0 15 100 1.0 20 150 1.0 20 150 1.0 25 150 1.0 30 170 1.0 30 200 1.0 40 200 1.0 45 225 1.0 55 225 1.0 55 250 1.0 70 250 1.0 80 300 0.5 80 300 0.5 80 325 0.5 0.5 90 350 130 350 0.5 150 375 0.5 170 375 0.5 180 400 0.5 200 400 0.5 215 423 0.5 240 447 0.5 255 470 0.5 www.lgesemi .c o m Temperature Coefficient @ IZT TC (mV/°C) Min. Max. -3.5 -3.5 -3.5 -3.5 -3.5 -3.5 -3.5 -3.5 -3.5 -3.5 -2.7 -2.0 0.4 1.2 2.5 3.2 3.8 4.5 5.4 6.0 7.0 9.2 10.4 12.4 14.4 16.4 18.4 21.4 24.4 27.4 30.4 33.4 10.0 10.0 10.0 10.0 10.0 10.0 10.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.2 1.2 2.5 3.7 4.5 5.3 6.2 7.0 8.0 9.0 10.0 11.0 13.0 14.0 16.0 18.0 20.0 22.0 25.3 29.4 33.4 37.4 41.2 12.0 12.0 12.0 12.0 12.0 12.0 12.0 Maximum Reverse @ VR Current (V) IR (µA) 150.000 150.000 50.000 20.000 10.000 5.000 5.000 3.000 3.000 3.000 2.000 1.000 3.000 2.000 1.000 0.700 0.500 0.200 0.100 0.100 0.100 0.100 0.100 0.100 0.100 0.100 0.100 0.100 0.100 0.100 0.100 0.100 0.100 0.100 0.100 0.045 0.045 0.045 0.045 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 2.0 2.0 2.0 4.0 4.0 5.0 5.0 6.0 7.0 8.0 8.0 8.0 10.5 11.2 12.6 14.0 15.4 16.8 18.9 21.0 23.1 25.2 27.3 30.1 32.9 35.7 39.2 43.4 47.6 52.5 mail:lge@lgesemi.com SMT-Type Zener Diode BZX584C2V0 - BZX584C75 TYPICAL CHARACTERISTICS (@ TA = 25°C unless otherwise specified) 20 2V0 2V4 2V7 3V0 IZ, ZENER CURRENT (mA) PD, POWER DISSIPATION (mW) 200 150 100 50 15 3V3 3V6 3V9 4V3 10 4V7 5V1 5V6 6V2 6V8 5 7V5 0 0 0 25 50 75 125 100 150 0 4 6 8 V Z, ZENER VOLTAGE (V) 2 T A, AMBIENT TEMPERATURE (°C) Fig. 2 Typical Zener Breakdown Characteristics Fig. 1 Power Derating Curve 30 TJ = 25°C 10 10 10 IZ, ZENER CURRENT (mA) IZ, ZENER CURRENT (mA) 12 15 20 18 Test Current IZ 2mA 22 10 27 Test Current IZ 5mA 0 0 33 10 20 30 36 40 Fig. 3 Typical Zener Breakdown Characteristics ht t p : // 6 4 2 VZ, ZENER VOLTAGE (V) Revision:20170701-P3 8 0 0 10 20 30 40 50 60 70 80 VZ , ZENER VOLTAGE (V) 90 100 Fig. 4 Typical Zener Breakdown Characteristics www.lgesemi .c o m mail:lge@lgesemi.com SMT-Type Zener Diode BZX584C2V0 - BZX584C75 PACKAGE OUTLINE (Unit: mm) Plastic surface mounted package SOD-523 Dimension Min. Max. A 1.10 1.30 B 0.70 0.90 C 0.50 0.70 D 0.25 0.35 E 0.15 0.25 J 0.05 0.15 K 1.50 1.70 MOUNTING PAD LAYOUT (Unit: mm) PACKAGE INFORMATION Part Number Package Shipping Quantity BZX584C2V0 - BZX584C75 SOD-523 3000pcs / Tape & Reel Revision:20170701-P4 ht t p : // www.lgesemi .c o m mail:lge@lgesemi.com
BZX584C4V7 价格&库存
很抱歉,暂时无法提供与“BZX584C4V7”相匹配的价格&库存,您可以联系我们找货
