RB520S-30
RB520S-30
    MDD(辰达半导体)
    SOD-523(SC-79)
    电压:30V 电流:200MA
RB520S-30 数据手册
RB520S-30 SOD-523 Plastic-Encapulate Diodes RB520S-30 SCHOTTKY BARRIER DIODES FEATURES  Small surface mounting type  Low reverse current and low forward voltage  High reliability SOD-523 Cathode bar Marking B Mechanical Data Case : SOD-523 Terminals : Solderable per MIL-STD-750,Method 2026 Polarity : Polarity symbol marking on body Mounting Position : Any Maximum Ratings and Electrical Characteristics, Single Diode @Ta=25℃ Symbo Limit Unit Peak Reverse Voltage VRM 30 V DC Blocking Voltage VR 30 V Maximum Average Rectified Output Current IO 200 mA Non-Repetitive Peak Forward Surge Current @ t=8.3us IFSM 1 A Power Dissipation Pd 200 mW RθJA 667 ℃/W Junction Temperature Tj 125 ℃ Storage Temperature TSTG -55~+125 ℃ Parameter Thermal Resistance Junction to Ambient ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified) Parameter Symbol Min Typ Max Unit Conditions Forward voltage 1) VF 0.60 V IF=200mA Reverse current 2) IR 1 μA VR=10V Notes Pulse width ≤380 uS, Duty cycle < 2%. Pulse test ,tp≤5ms. The above data are for reference only. 1) 2) DN:T20814A0 http://www.microdiode.com Rev:2020A0 Page :1 RB520S-30 Typical Characterisitics (TA=25℃ unless otherwise noted) Fig.2 Typical Instaneous Reverse Characteristics Fig.1 Power Derating Curve 100 Ins taneous Reverse Current (uA) 250 Power Dissipation PD (mW) 200 150 100 50 10 1 0.1 Ta=25°C 0.01 0 0 25 75 50 100 125 150 175 5 10 15 20 25 30 35 40 Instaneous Reverse Voltage (V) Ambient Temperature Ta (°C) Fig.3 Typical Forward Characteristic Forward Current IF (mA) 200 100 10 5° C =2 Ta 1.0 0.1 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 2.0 Forward Voltage VF (V) The curve above is for reference only. http://www.microdiode.com Rev:2020A0 Page :2 RB520S-30 Outlitne Drawing SOD-523 Package Outline Dimensions 6\P RO A A1 b c D E E1 E2 L Κ LPHQVLRQV,Q0LOOLPHWHUV 0LQ 0D[ 0.510 0.770 0.500 0.700 0.250 0.350 0.080 0.150 0.750 0.850 1.100 1.300 1.500 1.700 0.200 REF 0.010 0.070 7° REF LPHQVLRQV,Q,QFKHV 0D[ 0LQ 0.020 0.031 0.020 0.028 0.010 0.014 0.003 0.006 0.030 0.033 0.043 0.051 0.059 0.067 0.008 REF 0.001 0.003 7° REF Suggested Pad Layout Note: 1.Controlling dimension:in/millimeters. 2.General tolerance: ±0.05mm. 3.The pad layout is for reference purposes only. PACKAGE SPECIFICATIONS Package Reel Size SOD-523 Reel DIA. (mm) Q'TY/Reel (pcs) Box Size (mm) QTY/Box (pcs) Carton Size (mm) Q'TY/Carton (pcs) 178 3000 183×188×80 45,000 386×265×215 180,000 7' http://www.microdiode.com Rev:2020A0 Page : 3
RB520S-30 价格&库存
很抱歉,暂时无法提供与“RB520S-30”相匹配的价格&库存,您可以联系我们找货
RB520S-30
  • 10+0.11524
  • 100+0.08978
  • 300+0.07564
  • 3000+0.06716
  • 6000+0.05983
  • 9000+0.05584
库存:1289
