SD103AX
SD103AX
    AM(安美)
    SOD-523(SC-79)
    电压:40V 电流:350MA
SD103AX 数据手册
Schottky Diode 肖特基二极管 Small Signal Schottky DIODE / DATA SHEET SD103AX ◇ ◇ ◇ ◇ ◇ ◇ Low Forward Voltage Drop SOD523 Micro SMD package RoHS compliant / Green EMC Matte Tin (Sn) Lead finish Cathode Band / Device marking Surface Mount Package Ideally Suited for Automatic Insertion Device Marking Code S4 .. SD103AX Maximum Ratings (Ta = 25 ℃) Symbol Parameter Value Units VRRM Peak Repetive Reverse Voltage 40 V VRWM Working Peak Reverse Voltage 40 V VR DC Blocking Voltage 40 V VR(RMS) RMS Reverse Voltage 28 V IFM Forward Continuous Current 350 mA IFSM Non-Repetitive Peak Forward Surge Current 2.0 A ( @t=8..3ms ) PD Power Dissipation 200 mW TJ Junction Temperature 125 ℃ TSTG Storage Temperature -55 to +150 ℃ Rθ JA Thermal Resistance From Junction To Ambient 625 ℃/W Electrical Characteristics (Ta = 25 ℃) Symbol Parameter Conditions Min Max 40 Units VBR Reverse Voltage IF = 100uA VF Forward Voltage IF = 20mA 0.37 V IF = 200mA 0.60 V V IR Reverse current VR= 30V 5 μA CT Capacitance VR = 0V, f = 1MHz 50 pF trr Reverse Recovery Time IF = IR = 50mA, RL = 100Ω 4 ns Document Number:8010030 Revision:21-Apr-28 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn ~1~ Schottky Diode 肖特基二极管 Ordering Information Device Package Shipping SD103AX SOD523 Tape & Reel 8000pcs /7” Reel Tape wide Emboss pitch Tape specification 8 mm 4 mm Conductive Notes Package Dimensions NOTICE AM’S PRODUCTS ARE NOT AUTHORIZED FOR USE AS COMPONENTS IN ANY LIFE SUPPORT DEVICES OR SYSTEMS. AM reserve the right to make modifications, enhancements, improvements, corrections or other changes without further notice to any product herein. AM does not assume any liability arising out of the application or use of any product described herein. Document Number:8010030 Revision:21-Apr-28 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn ~2~
SD103AX 价格&库存
很抱歉,暂时无法提供与“SD103AX”相匹配的价格&库存,您可以联系我们找货
