BAT54M5
BAT54M5
    AM(安美)
    SOD-523(SC-79)
    电压:30V 电流:200MA
BAT54M5 数据手册
Schottky Diode 肖特基二极管 Small Signal Schottky DIODE / DATA SHEET BAT54M5 ◇ ◇ ◇ ◇ ◇ ◇ Low Forward Voltage Drop SOD523 Micro SMD package RoHS compliant / Green EMC Matte Tin (Sn) Lead finish Cathode Band / Device marking Surface Mount Package Ideally Suited for Automatic Insertion Device Marking Code BAT54M5 JV Maximum Ratings (Ta = 25 ℃) Symbol Parameter Value Units VRRM Peak Repetive Reverse Voltage 30 V VRWM Working Peak Reverse Voltage 30 V VR DC Blocking Voltage 30 V IFM Forward Continuous Current 200 mA IFSM Peak forward current 9t=1us) 600 mA IFRM Repetitive peak forward current 300 mA PD Power Dissipation 200 mW TJ Junction Temperature -55 to +125 ℃ TSTG Storage Temperature -55 to +150 ℃ Rθ JA Thermal Resistance From Junction To Ambient 635 ℃/W Electrical Characteristics (Ta = 25 ℃) Symbol Parameter Conditions Min Max 30 Units VBR Reverse Voltage IF = 10uA VF Forward Voltage IF = 0.1mA 0.24 V IF = 1.0mA 0.32 V IF = 10mA 0.40 V IF = 30mA 0.50 V IF = 100mA 0.80 V V IR Reverse current VR= 25V 2 μA CT Capacitance VR = 1V, f = 1MHz 10 pF trr Reverse Recovery Time Irr = 10mA,IR = 10mA~1mA 5 ns Document Number:8010030 Revision:21-Apr-28 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn ~1~ Schottky Diode 肖特基二极管 Ordering Information Device Package Shipping BAT54M5 SOD523 Tape & Reel 8000pcs /7” Reel Tape wide Emboss pitch Tape specification 8 mm 4 mm Conductive Notes Package Dimensions NOTICE AM’S PRODUCTS ARE NOT AUTHORIZED FOR USE AS COMPONENTS IN ANY LIFE SUPPORT DEVICES OR SYSTEMS. AM reserve the right to make modifications, enhancements, improvements, corrections or other changes without further notice to any product herein. AM does not assume any liability arising out of the application or use of any product described herein. Document Number:8010030 Revision:21-Apr-28 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn ~2~
BAT54M5 价格&库存
很抱歉,暂时无法提供与“BAT54M5”相匹配的价格&库存,您可以联系我们找货
BAT54M5
  • 50+0.10035
  • 500+0.07819
  • 1500+0.06587
  • 8000+0.05849
  • 24000+0.05202
  • 48000+0.04864
库存:2738
