HXY
RB521S-30
ELECTRONICS CO.,LTD
SCHOTTKY BARRIER DIODE
HUAXUANYANG
FEATURES
Small surface mounting type.
Low reverse current and low forward voltage.
High reliability.
Package Marking and Ordering Information
Product ID
Pack
Marking
RB521S-30
SOD-523
C
Qty(PCS)
SOD-523
3000
MAXIMUM RATINGS (Ta=25℃ unless otherwise noted)
Symbol
VR
Io
IFSM
Pd
RΘJA
TJ
TSTG
Parameter
Value
30
Unit
200
mA
1000
mA
Power Dissipation
150
mW
Thermal Resistance From Junction To Ambient
667
℃/W
Operation Junction Temperature Range
-40~+125
Storage Temperature Range
-55~+150
DC reverse voltage
Mean rectifying current
Non-repetitive
Current@8.3mS
Peak
Forward
Surge
V
ELECTRICAL CHARACTERISTICS(Ta=25℃ unless otherwise noted)
Symbol
Parameter
Test conditions
IR
Reverse voltage leakage
current
VF(1)
VF(2)
Forward voltage
Shenzhen HuaXuanYang Electronics CO.,LTD
Min
Typ
Max
Unit
VR=10V
30
µA
IF=10mA
0.35
V
IF=200mA
0.50
V
www.hxymos.com
HXY
RB521S-30
ELECTRONICS CO.,LTD
HUAXUANYANG
TypicalCharacteristics
www.hxymos.com
HXY
RB521S-30
ELECTRONICS CO.,LTD
HUAXUANYANG
SOD-523 Package Outline Dimensions
6\P RO
A
A1
b
c
D
E
E1
E2
L
LPHQVLRQV,Q0LOOLPHWHUV
0LQ
0D[
0.510
0.770
0.500
0.700
0.250
0.350
0.080
0.150
0.750
0.850
1.100
1.300
1.500
1.700
0.200 REF
0.010
0.070
7° REF
LPHQVLRQV,Q,QFKHV
0LQ
0D[
0.020
0.031
0.020
0.028
0.010
0.014
0.003
0.006
0.030
0.033
0.043
0.051
0.059
0.067
0.008 REF
0.001
0.003
7° REF
www.hxymos.com
HXY
RB521S-30
ELECTRONICS CO.,LTD
HUAXUANYANG
Attention
■ Any and all HUA XUAN YANG ELECTRONICS products described or contained herein do not have specifications that can handle
applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications
whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your HUA XUAN YANG
ELECTRONICS representative nearest you before using any HUA XUAN YANG ELECTRONICS products described or contained herein
in such applications.
■ HUA XUAN YANG ELECTRONICS assumes no responsibility for equipment failures that result from using products at values that
exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products
specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein.
■ Specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein stipulate the performance,
characteristics, and functions of the described products in the independent state, and are not guarantees of the performance,
characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and
states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the
■ HUA XUAN YANG ELECTRONICS CO.,LTD. strives to supply high-quality high-reliability products. However, any and all semiconductor
products fail with some probability. It is possible that these probabilistic failures could
give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other
property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures
include but are not limited to protective circuits and error prevention circuits for safe design, redundant design, and structural design.
■ In the event that any or all HUA XUAN YANG ELECTRONICS products(including technical data, services) described or contained herein
are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the
export license from the authorities concerned in accordance with the above law.
■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including
photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of HUA
■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production.
HUA XUAN YANG ELECTRONICS believes information herein is accurate and reliable, but no guarantees are made or implied regarding
its use or any infringements of intellectual property rights or other rights of third parties.
■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc.
When designing equipment, refer to the "Delivery Specification" for the HUA XUAN YANG ELECTRONICS product that you intend to use.
www.hxymos.com
很抱歉,暂时无法提供与“RB521S-30”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.09809
- 500+0.07808
- 3000+0.06546
- 6000+0.05879
- 24000+0.05304
- 51000+0.04987
