RB520S-30
RB520S-30
    HXY(华轩阳)
    SOD-523(SC-79)
    电压:30V 电流:200MA
RB520S-30 数据手册
HXY RB520S-30 ELECTRONICS CO.,LTD SCHOTTKY BARRIER DIODE HUAXUANYANG FEATURES Small surface mounting type. Low reverse current. High reliability. Package Marking and Ordering Information Product ID Pack Marking RB520S-30 SOD-523 B Qty(PCS) SOD-523 3000 MAXIMUM RATINGS (Ta=25℃ unless otherwise noted) Symbol VR Io IFSM Pd RΘJA TJ TSTG Parameter Value 30 Unit 200 mA 1000 mA Power Dissipation 150 mW Thermal Resistance From Junction To Ambient 667 ℃/W Operation Junction Temperature Range -40~+125 ℃ Storage Temperature Range -55~+150 ℃ DC reverse voltage Mean rectifying current Non-repetitive Current@8.3mS Peak Forward Surge V ELECTRICAL CHARACTERISTICS(Ta=25℃ unless otherwise noted) Symbol Parameter Test conditions IR Reverse voltage leakage current VF Forward voltage Shenzhen HuaXuanYang Electronics CO.,LTD Min Typ Max Unit VR=10V 1 µA IF=200mA 0.60 V www.hxymos.com HXY RB520S-30 ELECTRONICS CO.,LTD SCHOTTKY BARRIER DIODE HUAXUANYANG TypicalCharacteristics Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HXY RB520S-30 ELECTRONICS CO.,LTD SCHOTTKY BARRIER DIODE HUAXUANYANG SOD-523 Package Outline Dimensions 6\P RO A A1 b c D E E1 E2 L  LPHQVLRQV,Q0LOOLPHWHUV 0LQ 0D[ 0.510 0.770 0.500 0.700 0.250 0.350 0.080 0.150 0.750 0.850 1.100 1.300 1.500 1.700 0.200 REF 0.010 0.070 7° REF Shenzhen HuaXuanYang Electronics CO.,LTD LPHQVLRQV,Q,QFKHV 0LQ 0D[ 0.020 0.031 0.020 0.028 0.010 0.014 0.003 0.006 0.030 0.033 0.043 0.051 0.059 0.067 0.008 REF 0.001 0.003 7° REF www.hxymos.com HXY RB520S-30 ELECTRONICS CO.,LTD SCHOTTKY BARRIER DIODE HUAXUANYANG Attention ■ Any and all HUA XUAN YANG ELECTRONICS products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your HUA XUAN YANG ELECTRONICS representative nearest you before using any HUA XUAN YANG ELECTRONICS products described or contained herein in such applications. ■ HUA XUAN YANG ELECTRONICS assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein. ■ Specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’s products or equipment. ■ HUA XUAN YANG ELECTRONICS CO.,LTD. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with some probability. It is possible that these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits and error prevention circuits for safe design, redundant design, and structural design. ■ In the event that any or all HUA XUAN YANG ELECTRONICS products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from the authorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of HUA XUAN YANG ELECTRONICS CO.,LTD. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. HUA XUAN YANG ELECTRONICS believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringements of intellectual property rights or other rights of third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. When designing equipment, refer to the "Delivery Specification" for the HUA XUAN YANG ELECTRONICS product that you intend to use. Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com
