� �D�
宏迦橙
BZX584C2V4 THRU BZX584C43
SURFACE MOUNT ZENER DIODES
Features
SOD-523 SURFACE MOUNT SILICON ZENER DIODES
www.ichjc.com
Zener Diode
2.4 to 43 Volts
Power Dissipation
150 Milliwatts
•Low Zener Impedance
•Power Dissipation of 150mW
•High Stability and High Reliability
•Meets MSL level 1, per J-STD-020, LF maximum peak of 260℃
Applications
SOD-523
Zener diode is generally used as reference voltage sources in regulated power
supplies or as protective diode in overvoltage protection circuits.
Mechanical Data
•Case: SOD-523
Molding compound meets UL 94V-0 flammability rating, RoHS-compliant,
halogen-free
•Terminals: Solder plated, solderable per MIL-STD-750,Method 2026
•Polarity: Cathode line denotes the cathode end
Function Diagram
1
XX
2
Maximum Ratings (Ta=25℃ Unless otherwise specified)
PARAMETER
SYMBOL
UNIT
VALUE
Forward Voltage @ IF=10mA
VF
V
0.9
Power Dissipation
PD
mW
150
Storage Temperature
Tstg
-55 ~+150
Typical Thermal Resistance
RθJ-A
℃ /W
833
Junction Temperature
Tj
Electrical Parameter
SYMBOL
Reverse zener voltage @ IZT
ZZT
Maximum Zener Impedance @ IZT
ZZK
Maximum Zener Impedance @ IZK
VR
Reverse voltage
IZK
IR
IF
VF
Revision:ZD-JAN.2024-A1
-55 ~+150
PARAMETER
VZ
IZT
IF
I
Reverse current
Reverse Current
Reverse leakage current @ VR
VZ VR
IR
IZT
VF
V
Forward current
Forward voltage @ IF
Zhuhai Hongjiacheng Technology co., Ltd
1 of 4
� �D�
宏迦橙
www.ichjc.com
Electrical Characteristics (Ta=25℃ Unless otherwise noted)
Type
Number
Marking
BZX584C2V4
Z11
BZX584C3V0
Z13
BZX584C2V7
BZX584C3V3
BZX584C3V6
BZX584C3V9
BZX584C4V3
BZX584C4V7
BZX584C5V1
BZX584C5V6
BZX584C6V2
BZX584C6V8
BZX584C7V5
BZX584C8V2
BZX584C9V1
BZX584C10
BZX584C11
BZX584C12
BZX584C13
BZX584C15
BZX584C16
BZX584C18
BZX584C20
BZX584C22
BZX584C24
Z12
Z14
Z15
Z16
Z17
Z1
Z2
Z3
Z4
Z5
Z6
Z7
Z8
Z9
Y6
Y7
Y8
Y9
Y10
BZX584C33
Y12
BZX584C36
BZX584C39
BZX584C43
Y11
Y13
Y14
Y15
100
5
600
95
5
2.5
2.7
2.9
100
2.8
3.1
3.4
3.7
4.0
4.4
4.8
5.2
5.8
6.4
7.0
7.7
8.5
9.4
12.4
Y5
ZZK@IZK
(mA)
Y3
Y4
ZZT@IZT
Max.
2.2
11.4
13.8
15.3
16.8
18.8
20.8
22.8
25.1
28
31
34
37
40
2.4
3.0
3.3
3.6
3.9
4.3
4.7
5.1
5.6
6.2
6.8
7.5
8.2
9.1
2.6
3.2
3.5
3.8
4.1
4.6
5.0
5.4
6.0
6.6
7.2
7.9
8.7
9.6
10
10.6
12
12.7
11
13
15
16
18
24
27
30
33
36
39
43
11.6
14.1
15.6
17.1
19.1
21.2
23.3
25.6
28.9
32
35
38
41
46
Zener Impedance
IZT
Nom.
10.4
Y2
VZ(V)
Min.
Y1
BZX584C27
BZX584C30
Nominal Zener Voltage
95
90
90
90
80
60
40
10
15
15
15
15
30
30
40
45
55
55
70
80
80
80
90
130
100
5
5
5
5
5
5
5
5
5
5
5
5
(Ω)
600
600
600
600
600
600
500
480
400
150
80
80
80
5
100
5
150
5
5
5
5
5
5
5
5
5
2
2
2
2
2
2
150
150
170
200
200
225
225
250
250
300
300
325
350
350
700
IZK
Leakage Current
IR@VR
Typical
Temperature
coefficent
@ IZTC(mV/℃ )
Admissible
Zener
Current
(mA)
IR(μA)
VR(V)
Min.
Max.
IZM ( mA)
1.0
-3.5
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
50
10
5
5
3
3
3
2
1
3
2
1
1.0
0.7
1.0
0.2
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
0.5
0.5
0.5
0.5
0.5
1.0
0.5
0.1
0.1
0.1
1.0
1.0
1.0
1.0
1.0
1.0
2.0
-3.5
-3.5
-3.5
-3.5
-3.5
-3.5
4.0
2.5
4.0
5.0
5.0
6.0
7.0
8.0
8.0
8.0
1.2
3.2
3.8
4.5
5.4
6.0
0.1
0.1
0.1
0.1
11.2
14.0
15.4
16.8
18.9
21.0
23.1
25.2
27.3
32.0
1.2
3.7
4.5
5.3
6.2
7.0
8.0
9.0
7.0
10.0
13.0
9.2
14.4
0.1
12.6
0.1
-2
0.1
0.1
2.0
10.4
0.1
10.5
0.1
0.1
0.1
16.4
18.4
21.4
24.4
27.4
30.4
33.4
10.0
10.0
11.0
14.0
16.0
18.0
20.0
22.0
25.3
29.4
33.4
37.4
41.2
12.0
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
2
2
2
2
2
5
2 of 4
� �D�
宏迦橙
www.ichjc.com
Ratings And Characteristics Curves (Ta=25℃ Unless otherwise specified)
50
T a =25℃
Pulsed
P D =150mW
ZenerCurrentIZ(mA)
1
2
4
3
5
7
6
8
ZenerVoltageVZ(V)
11
0.1
10
LeakagecurrentIR(μA)
TemperatureCoeffcientθVZ (mV/℃)
V Z @I ZT
25
35
43
33
30
24
27
30
40
45
50
Pulsed
1
0.1
0.01
10
5
T a =100℃
1E-3
8
12
16
28
NominalZenerVoltageVZ(V)
32
36
40
44
1E-
4
CapacitanceC(pF)
10
1
1VBias
Fig.5 Typical Capacitance
10
15
30
35
40
45
T a =25℃
I Z(AC) =0.1I Z(DC)
f=1Kz
I Z =1mA
100
10
DynamicImpedanceZZT(Ω)
0VBias
BiasAt
50%Of V ZNom
5
1000
T a =25℃
f=1MHz
100
T a =25℃
Fig.4 Typical Leakage Current
Fig.3 Temperature Coefficients
1
25
ZenerVoltageVZ(V)
10
30
-5
TypicalT a Values
ForBZX584CXXXSeries
35
15
Fig.2 Zener Characteristics ( 11v to 43V )
Fig. 1 Zener Characteristics ( VZ Up to 10V )
40
18
10
15
10
9
1
0.5
1
11
12
13
9.1
8.2
6.8
7.5
6.2
5.6
5.1
4.7
2.4
10
P D =150mW
16
ZenerCurrentIZ(mA)
10
39
T a =25℃
Pulsed
36
100
100
I Z =5mA
10
1
1
10
100
Fig.6 Effect of Zener Voltage on Zener Impedance
3 of 4
� �D�
宏迦橙
www.ichjc.com
Ordering Information
PACKAGE
PACKAGE CODE
SOD-523
R1
UNIT WEIGHT(g)
REEL(pcs)
0.002
BOX(pcs)
3000
Package Outline Dimensions (SOD-523)
45000
Symbol
CathodeBand
B E
A
D
F
C
CARTON(pcs)
180000
Millimeters
Y
Dimensions
A
1.10
1.30
0.043
0.051
B
0.25
0.35
0.010
0.014
C
1.50
1.70
0.059
0.067
D
0.50
0.70
0.020
0.027
E
0.70
0.90
0.027
0.035
F
0.05
0.20
0.002
0.008
Symbol
Y
Z
Millimeters
Dimensions
Min.
Max.
0.65
0.75
0.55
1.37
Min
Inches
Max
X
X
7"
Min
Suggested Pad Layout
Z
DELIVERY MODE
Min.
Inches
Max
Max.
0.65
0.022
0.026
1.47
0.054
0.058
0.026
0.029
4 of 4
很抱歉,暂时无法提供与“BZX584C15”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.16060
- 200+0.12971
- 600+0.11265
- 3000+0.09774
- 9000+0.08889
- 21000+0.08403
