BZX584C5V6
BZX584C5V6
    HONGJIACHENG(宏嘉诚)
    SOD-523(SC-79)
    独立式 耐压:5.6V 电流:1UA@2V
BZX584C5V6 数据手册
� �D� 宏迦橙 BZX584C2V4 THRU BZX584C43 SURFACE MOUNT ZENER DIODES Features SOD-523 SURFACE MOUNT SILICON ZENER DIODES www.ichjc.com Zener Diode 2.4 to 43 Volts Power Dissipation 150 Milliwatts •Low Zener Impedance •Power Dissipation of 150mW •High Stability and High Reliability •Meets MSL level 1, per J-STD-020, LF maximum peak of 260℃ Applications SOD-523 Zener diode is generally used as reference voltage sources in regulated power supplies or as protective diode in overvoltage protection circuits. Mechanical Data •Case: SOD-523 Molding compound meets UL 94V-0 flammability rating, RoHS-compliant, halogen-free •Terminals: Solder plated, solderable per MIL-STD-750,Method 2026 •Polarity: Cathode line denotes the cathode end Function Diagram 1 XX 2 Maximum Ratings (Ta=25℃ Unless otherwise specified) PARAMETER SYMBOL UNIT VALUE Forward Voltage @ IF=10mA VF V 0.9 Power Dissipation PD mW 150 Storage Temperature Tstg ℃ -55 ~+150 Typical Thermal Resistance RθJ-A ℃ /W 833 Junction Temperature Tj Electrical Parameter SYMBOL Reverse zener voltage @ IZT ZZT Maximum Zener Impedance @ IZT ZZK Maximum Zener Impedance @ IZK VR Reverse voltage IZK IR IF VF Revision:ZD-JAN.2024-A1 -55 ~+150 PARAMETER VZ IZT ℃ IF I Reverse current Reverse Current Reverse leakage current @ VR VZ VR IR IZT VF V Forward current Forward voltage @ IF Zhuhai Hongjiacheng Technology co., Ltd 1 of 4 � �D� 宏迦橙 BZX584C2V4 THRU BZX584C43 www.ichjc.com SURFACE MOUNT ZENER DIODES Electrical Characteristics (Ta=25℃ Unless otherwise noted) Type Number Marking BZX584C2V4 Z11 BZX584C3V0 Z13 BZX584C2V7 BZX584C3V3 BZX584C3V6 BZX584C3V9 BZX584C4V3 BZX584C4V7 BZX584C5V1 BZX584C5V6 BZX584C6V2 BZX584C6V8 BZX584C7V5 BZX584C8V2 BZX584C9V1 BZX584C10 BZX584C11 BZX584C12 BZX584C13 BZX584C15 BZX584C16 BZX584C18 BZX584C20 BZX584C22 BZX584C24 Z12 Z14 Z15 Z16 Z17 Z1 Z2 Z3 Z4 Z5 Z6 Z7 Z8 Z9 Y6 Y7 Y8 Y9 Y10 BZX584C33 Y12 BZX584C36 BZX584C39 BZX584C43 Y11 Y13 Y14 Y15 Revision:ZD-JAN.2024-A1 100 5 600 95 5 2.5 2.7 2.9 100 2.8 3.1 3.4 3.7 4.0 4.4 4.8 5.2 5.8 6.4 7.0 7.7 8.5 9.4 12.4 Y5 ZZK@IZK (mA) Y3 Y4 ZZT@IZT Max. 2.2 11.4 13.8 15.3 16.8 18.8 20.8 22.8 25.1 28 31 34 37 40 2.4 3.0 3.3 3.6 3.9 4.3 4.7 5.1 5.6 6.2 6.8 7.5 8.2 9.1 2.6 3.2 3.5 3.8 4.1 4.6 5.0 5.4 6.0 6.6 7.2 7.9 8.7 9.6 10 10.6 12 12.7 11 13 15 16 18 20 22 24 27 30 33 36 39 43 11.6 14.1 15.6 17.1 19.1 21.2 23.3 25.6 28.9 32 35 38 41 46 Zener Impedance IZT Nom. 10.4 Y2 VZ(V) Min. Y1 BZX584C27 BZX584C30 Nominal Zener Voltage 95 90 90 90 80 60 40 10 15 15 15 15 20 20 25 30 30 40 45 55 55 70 80 80 80 90 130 100 5 5 5 5 5 5 5 5 5 5 5 5 (Ω) 600 600 600 600 600 600 500 480 400 150 80 80 80 5 100 5 150 5 5 5 5 5 5 5 5 5 2 2 2 2 2 2 150 150 170 200 200 225 225 250 250 300 300 325 350 350 700 IZK Leakage Current IR@VR Typical Temperature coefficent @ IZTC(mV/℃ ) Admissible Zener Current (mA) IR(μA) VR(V) Min. Max. IZM ( mA) 1.0 20 1.0 -3.5 0 5 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 50 10 5 5 3 3 3 2 1 3 2 1 1.0 0.7 1.0 0.2 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 0.5 0.5 0.5 0.5 0.5 1.0 Zhuhai Hongjiacheng Technology co., Ltd 0.5 0.1 0.1 0.1 1.0 1.0 1.0 1.0 1.0 1.0 2.0 -3.5 -3.5 -3.5 -3.5 -3.5 -3.5 4.0 2.5 4.0 5.0 5.0 6.0 7.0 8.0 8.0 8.0 1.2 3.2 3.8 4.5 5.4 6.0 0.1 0.1 0.1 0.1 11.2 14.0 15.4 16.8 18.9 21.0 23.1 25.2 27.3 32.0 1.2 3.7 4.5 5.3 6.2 7.0 8.0 9.0 7.0 10.0 13.0 9.2 14.4 0.1 0 2.5 12.6 0.1 0 0.4 -2 0.1 0.1 0 2.0 2.0 10.4 0.1 0 0.2 10.5 0.1 0 -2.7 0.1 0.1 0 12.4 16.4 18.4 21.4 24.4 27.4 30.4 33.4 10.0 10.0 11.0 14.0 16.0 18.0 20.0 22.0 25.3 29.4 33.4 37.4 41.2 12.0 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 2 2 2 2 2 5 2 of 4 � �D� 宏迦橙 BZX584C2V4 THRU BZX584C43 www.ichjc.com SURFACE MOUNT ZENER DIODES Ratings And Characteristics Curves (Ta=25℃ Unless otherwise specified) 50 T a =25℃ Pulsed P D =150mW ZenerCurrentIZ(mA) 1 2 4 3 5 7 6 8 ZenerVoltageVZ(V) 11 0.1 10 LeakagecurrentIR(μA) TemperatureCoeffcientθVZ (mV/℃) V Z @I ZT 25 20 15 35 43 33 30 20 22 24 27 30 40 45 50 Pulsed 1 0.1 0.01 10 5 T a =100℃ 1E-3 0 0 4 8 12 16 20 24 28 NominalZenerVoltageVZ(V) 32 36 40 44 1E- 4 0 1000 CapacitanceC(pF) 10 1 1VBias NominalZenerVoltageVZ(V) Fig.5 Typical Capacitance 10 15 20 25 30 NominalZenerVoltageVZ(V) 35 40 45 T a =25℃ I Z(AC) =0.1I Z(DC) f=1Kz I Z =1mA 100 10 Revision:ZD-JAN.2024-A1 DynamicImpedanceZZT(Ω) 0VBias BiasAt 50%Of V ZNom 5 1000 T a =25℃ f=1MHz 100 T a =25℃ Fig.4 Typical Leakage Current Fig.3 Temperature Coefficients 1 25 ZenerVoltageVZ(V) 10 30 -5 20 100 TypicalT a Values ForBZX584CXXXSeries 35 15 Fig.2 Zener Characteristics ( 11v to 43V ) Fig. 1 Zener Characteristics ( VZ Up to 10V ) 40 18 10 15 10 9 1 0.5 1 11 12 13 9.1 8.2 6.8 7.5 6.2 5.6 5.1 4.7 2.4 10 P D =150mW 16 ZenerCurrentIZ(mA) 10 39 T a =25℃ Pulsed 36 100 100 I Z =5mA 10 1 1 10 NominalZenerVoltageVZ(V) 100 Fig.6 Effect of Zener Voltage on Zener Impedance Zhuhai Hongjiacheng Technology co., Ltd 3 of 4 � �D� 宏迦橙 BZX584C2V4 THRU BZX584C43 www.ichjc.com SURFACE MOUNT ZENER DIODES Ordering Information PACKAGE PACKAGE CODE SOD-523 R1 UNIT WEIGHT(g) REEL(pcs) 0.002 BOX(pcs) 3000 Package Outline Dimensions (SOD-523) 45000 Symbol CathodeBand B E A D F C CARTON(pcs) 180000 Millimeters Y Revision:ZD-JAN.2024-A1 Dimensions A 1.10 1.30 0.043 0.051 B 0.25 0.35 0.010 0.014 C 1.50 1.70 0.059 0.067 D 0.50 0.70 0.020 0.027 E 0.70 0.90 0.027 0.035 F 0.05 0.20 0.002 0.008 Symbol Y Z Millimeters Dimensions Min. Max. 0.65 0.75 0.55 1.37 Zhuhai Hongjiacheng Technology co., Ltd Min Inches Max X X 7" Min Suggested Pad Layout Z DELIVERY MODE Min. Inches Max Max. 0.65 0.022 0.026 1.47 0.054 0.058 0.026 0.029 4 of 4
BZX584C5V6 价格&库存
很抱歉,暂时无法提供与“BZX584C5V6”相匹配的价格&库存,您可以联系我们找货
BZX584C5V6
  • 20+0.12345
  • 200+0.09662
  • 600+0.08175
  • 3000+0.07281
  • 9000+0.06513
  • 21000+0.06095
库存:68126
