RB520S30
RB520S30
    AM(安美)
    SOD-523(SC-79)
    电压:30V 电流:200MA 停产
RB520S30 数据手册
RB520S30 SURFACE MOUNT SCHOTTKY DIODES VOLTAGE 30 Volts 200 mA CURRENT FEATURES • Extremely Hish Switching Speed • Surface mount package ideally suited for autmatic insertion • In compliance with EU RoHS 2002/95/EC directives MECHANICAL DATA • Case: SOD-523, Plastic • Terminals: Solderable per MIL-STD-750, Method 2026 • Appox Weight : 0.008 gram • Marking : 20 ABSOLUTE RATINGS PA RA M E TE R S ym b o l Value Units Peak Reverse Voltage VR 30 V Maximum Forward Current IO 0.2 A I FSM 1 A T J,T STG -5 5 to + 1 2 5 oC Peak Forward Surge Current 1000ms Single half sine-wave superimposed on rate load (JEDEC method) O p e r a t i n g J u n c t i o n a n d S t o r a g e Te m p e r a t u r e R a n g e ELECTRICAL CHARACTERISTICS ( TJ = 25OC unless otherwise noted ) PA RA M E TE R S ym b o l Te s t C o n d i t i o n M IN . T YP. MA X . U ni t s V R= 1 0 V - - 1 .0 µA R e ve r s e L e a k a g e C ur r e nt I F o rwa rd Vo lta g e V F1 I F=2 0 mA - - 0.40 V F o rwa rd Vo lta g e V F2 I F=2 0 0 mA - - 0.60 V To t a l C a p a c i t a n c e CJ V R= 0 V , F = 1 M H z - 30 - pF Document Number:810526 Revision:18-Oct-19 R 安徽安美半导体有限公司 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn 1 RB520S30 SURFACE MOUNT SCHOTTKY DIODES RATING AND CHARACTERISTIC CURVES 100 0.35 AVERAGE FORWARD RECIFIED CURRENT AMPERES CAPACITANCE, pF T J = 25 OC f = 1.0MHz Vsig = 50mVp-p 10 0.25 0.20 0.15 0.10 0.05 0 1 0.1 0 20 40 60 80 100 120 140 160 180 100 10 1 SINGLE PHASE, HALF-WAVE, 60Hz RESISTIVE OR INDUCTIVE LOAD P.C.B MOUNTED ON 0.3 x 0.3" (8.0 x 8.0 mm)COPPER PAD AREAS 0.30 O LEAD TEMPERATURE, C REVERSE VOLTAGE, VOLTS FIG.2 MAXIMUM AVERAGE FORWARD CURRENT DERATING FIG.1 TYPICAL JUNCTION CAPACITANCE 1000 INSTANTANEOUS FORWARD CURRENT, AMPERES INVSTANTANEOUS REVERSE CURRENT, MICROAMPERES 1.0 T J =125 OC 100 T J =75 OC 10 1 O T J =25 C 0.1 O T A =25 C 0.01 0 10 20 30 40 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 INSTANTANEOUS FORWARD VOLTAGE VOLTS Reverse Voltage, VOLTS Fig.3 Typical Reverse Characteristics FORWARD SURGE CURRENT, AMPERES pk (HALF-SING WAVE) 0.1 FIG.4 TYPICAL FORWARD CHARACTERISTICS 1.4 1.2 1.0 0.8 0.6 0.4 0.2 1 2 4 6 8 10 20 40 60 80 100 NUMBER OF CYCLES AT 60Hz FIG.5 MAXIMUM NON-REPEITIVE SURGE CURRENT Document Number:810526 Revision:18-Oct-19 安徽安美半导体有限公司 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn 2 RB520S30 SURFACE MOUNT SCHOTTKY DIODES MOUNTING PAD LAYOUT ORDER INFORMATION • Packing information T/R - 12K per 13" plastic Reel T/R - 5K per 7" plastic Reel Document Number:810526 Revision:18-Oct-19 安徽安美半导体有限公司 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn 3
RB520S30 价格&库存
很抱歉,暂时无法提供与“RB520S30”相匹配的价格&库存,您可以联系我们找货
