MM5Z2V2B~MM5Z39B
Silicon Planar Zener Diodes
PINNING
Features
• Total power dissipation: max. 200 mW
• Small plastic package suitable for
surface mounted design
• High reliability
PIN
DESCRIPTION
1
Cathode
2
Anode
2
1
Top View
Simplified outline SOD-523 and symbol
Absolute Maximum Ratings (Ta = 25℃)
Parameter
Power Dissipation
Junction Temperature
Storage Temperature Range
Symbol
Value
Unit
Ptot
200
mW
Tj
150
TStg
- 55 to + 150
Symbol
Max.
Unit
RθJA
625
℃/W
Thermal Characteristics
Parameter
Thermal Resistance Junction to Ambient
1)
1)
Device mounted on FR-4 substrate PC board, 2oz copper, with minimum recommended pad layout.
1/4
Dated : 05/08/2021 Rev : 02
MM5Z2V2B~MM5Z39B
Characteristics at Ta = 25℃ (VF = 0.9 V Max. at IF = 10 mA)
Type
Marking
Code
Zener Voltage Range 1)
lZT
for
Dynamic Impedance 2)
VZT
ZZT (Max.)
at IZT
Reverse Leakage Current
IR (Max.)
at VR
MM5Z2V2B
RM
mA
5
V
2.1...2.4
Ω
100
mA
5
μA
120
V
0.7
MM5Z2V4B
RN
5
2.3…2.65
100
5
120
1
MM5Z2V7B
RP
5
2.65…2.95
110
5
120
1
MM5Z3V0B
RR
5
2.95…3.25
120
5
50
1
MM5Z3V3B
RX
5
3.25…3.55
120
5
MM5Z3V6B
RY
5
3.6…3.845
100
5
10
1
MM5Z3V9B
JY
5
3.89…4.16
100
5
5
1
MM5Z4V3B
JZ
5
4.17…4.43
100
5
5
1
MM5Z4V7B
KA
5
4.55…4.75
100
5
2
1
MM5Z5V1B
KB
5
4.98…5.2
80
5
2
1.5
MM5Z5V6B
KC
5
5.49…5.73
60
5
1
2.5
MM5Z6V2B
KD
5
6.06…6.33
60
5
1
3
MM5Z6V8B
KE
5
6.65…6.93
40
5
0.5
3.5
MM5Z7V5B
KF
5
7.28…7.6
30
5
0.5
4
MM5Z8V2B
KH
5
8.02…8.36
30
5
0.5
5
MM5Z9V1B
KJ
5
8.85…9.23
30
5
0.5
6
MM5Z10B
KK
5
9.77…10.21
30
5
0.1
7
MM5Z11B
KM
5
10.76…11.22
30
5
0.1
8
MM5Z12B
KN
5
11.74…12.24
30
5
0.1
9
MM5Z13B
KP
5
12.91…13.49
37
5
0.1
10
MM5Z15B
KR
5
14.34…14.98
42
5
0.1
11
MM5Z16B
KX
5
15.85…16.51
50
5
0.1
12
KY
5
17.56…18.35
65
5
0.1
13
MM5Z20B
KZ
5
19.52…20.39
85
5
0.1
15
MM5Z22B
RZ
5
21.54…22.47
100
5
0.1
17
MM5Z24B
XA
5
23.72…24.78
120
5
0.1
19
MM5Z27B
XB
5
26.19…27.53
150
5
0.1
21
MM5Z30B
XC
5
29.19…30.69
200
5
0.1
23
MM5Z33B
XD
5
32.15…33.79
250
5
0.1
25
MM5Z36B
XE
5
35.07…36.87
300
5
0.1
27
MM5Z39B
XF
5
37…41
100
5
2
30
MM5Z18B
1)
VZ is tested with pulses (20 ms).
2)
ZZT is measured at IZ by given a very small A.C. current signal.
2/4
MM5Z2V2B~MM5Z39B
Electrical Characteristics Curves
Fig 2. Zener Characteristics Curve
Zener Current (mA)
Fig 1. Forward Characteristics Curve
Zener Voltage (V)
Fig 4. Power Derating Curve
Fig 3. Zener Characteristics Curve
Zener Current (mA)
Power Dissipation (mW)
250
200
150
100
50
50
75
100
125
150
Ambient Temperature (℃)
Zener Voltage (V)
3/4
MM5Z2V2B~MM5Z39B
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SOD-523
ALL ROUND
C
A
HE
D
bp
E
A
A
bp
C
D
E
HE
V
0.70
0.60
0.4
0.3
0.135
0.100
1.25
1.15
0.85
0.75
1.7
1.5
0.1
UNIT
mm
5
O
Recommended Soldering Footprint
1.7
0.6
0.8
Packing information
Package
SOD-523
Pitch
Tape Width
Reel Size
(mm)
mm
inch
mm
inch
8
4 ± 0.1
0.157 ± 0.004
178
7
Per Reel Packing Quantity
4,000
Marking information
" ** " = Part No
" III " = Cathode line
Font type: Arial
4/4
很抱歉,暂时无法提供与“MM5Z33B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.14224
- 200+0.10952
- 600+0.09137
