RB520S-40
RB520S-40
    XCH(旭昌辉)
    SOD-523(SC-79)
    电压:40V 电流:0.2A
RB520S-40 数据手册
RB520S-40 Schottky Barrier Diode Specification Features: ƒ ƒ ƒ ƒ ƒ ƒ ƒ ƒ Absolute Maximum Ratings Symbol PD TSTG Flat Lead SOD-523 Small Outline Plastic Package Extremely Small SOD-523 Package Surface Device Type Mounting RoHS Compliant Green EMC Matte Tin(Sn) Lead Finish Band Indicates Cathode TA = 25°C unless otherwise noted Parameter Power Dissipation Storage Temperature Range Value Units 200 mW -55 to +125 °C +125 °C TJ Operating Junction Temperature VR Reverse Voltage 40 V Average Forward Current 200 mA IF(AV) Low Forward Voltage Drop These ratings are limiting values above which the serviceability of the diode may be impaired. Electrical Characteristics Symbol TA = 25°C unless otherwise noted Parameter Limits Test Condition Min BV Breakdown Voltage IR=10µA IR Reverse Leakage Current VR=10V VF Forward Voltage TCBAT42WS, IF=200mA Unit Max 40 Volts 1 µA 0.6 Volts Page 1 of 4 RB520S-40 Typical Performance Characteristics Total Capacitance Forward Voltage vs Ambient Temperature Page 2 of 4 RB520S-40 Reverse Current vs Reverse VoltageReverse Page 3 of 4 RB520S-40 PACKAGE OUTLINE Plastic surface mounted package; 2 leads ∠ALL ROUND A C A P E HE N N e E D 底视图 bottom view L A e C D E HE N L max 0.77 0.35 0.15 1.30 0.99 1.70 min 0.51 0.25 0.08 1.10 0.75 1.50 0.35 ref 0.2 ref R0.1 ALL ROUND max 30 14 6 51 39 67 min 20 10 3 43 30 59 14 ref 8.0 ref R4.0 ALL ROUND UNIT mm ∠ P 10°±1° mil Marking The recommended mounting pad size Type number RB520S-40 3B 0.7 (28) 0.6 (24) Marking code 1.42 (56) Unit: mm (mil) Page 4 of 4
RB520S-40 价格&库存
很抱歉,暂时无法提供与“RB520S-40”相匹配的价格&库存,您可以联系我们找货
RB520S-40
  • 20+0.10925
  • 200+0.08511
  • 600+0.07169
  • 3000+0.06365
  • 9000+0.05671
  • 21000+0.05291
库存:2499
