SD103AX
PINNING
SCHOTTKY BARRIER RECTIFIERS
PIN
FEATURES
• Low Forward Voltage Drop
• Fast Switching Time
DESCRIPTION
1
Cathode
2
Anode
• Surface Mount Package Ideally
Suited for Automated Insertion
2
• Lead, Halogen and Antimony Free,
RoHS Compliant "Green" Device
1
Top View
Simplified outline SOD-523 and symbol
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Symbols
SD103AX
Units
V RRM
V RWM
40
V
V R(RMS)
28
V
IF
200
mA
Non-Repetitive Peak Forward Surge Current @t = 8.3ms
I FSM
0.5
A
Power dissipation
PD
200
mW
V BR
40(Min)
V
V
Parameter
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
VR
DC Blocking Voltage
RMS Reverse Voltage
Forward Continuous Current
Reverse Breakdown Voltage
I R = 100μA
Forward Voltage
I F =1.0 mA
I F =5.0mA
I F =20mA
I F =200mA
VF
0.27 (Typ)
0.32 (Typ)
0.37 (Max)
0.60 (Max)
V R =30V
IR
5.0(Max)
uA
CT
50
pF
Junction Temperature
Tj
125
°C
Storage Temperature
T stg
-55 ~ +150
°C
Peak Reverse Current
Typical Junction Capacitance
www.yongyutai.com
V R =4V,f=1MHz
PAGE 1
SD103AX
Fig.2 Typical Instaneous Reverse
Characteristics
250
200
150
100
50
75
50
100
125
150
175
Instaneous Reverse Current ( u A)
Power Dissipation P D (m W )
Fig.1 Power Derating Curve
100
10
1
T a =25°C
0.1
0.01
Junction Capacitance C T ( pF)
Forward Current I F (mA)
T
=2
a
C
5°
1.0
15
30
35
40
Fig.4 Typical Junction Capacitance
Fig.3 Typical Forward Characteristic
10
10
Instaneous Reverse Voltage (V)
Ambient Temperature T a (°C)
200
100
5
1000
T J=25°C
f=1MHz
100
10
1
0.1
0.6
0.8 1.0 1.2 1.4 1.6 1.8 2.0
Forward Voltage V F (V)
www.yongyutai.com
0.1
1.0
10
100
Reverse Voltage V R (V)
PAGE 2
SD103AX
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SOD-523
∠ALL ROUND
A
C
A
P
E
HE
N
N
e
E
D
底视图
bottom view
L
A
e
C
D
E
HE
N
L
max
0.77
0.35
0.15
1.30
0.99
1.70
min
0.51
0.25
0.08
1.10
0.75
1.50
0.35
ref
0.2
ref
R0.1
ALL
ROUND
max
30
14
6
51
39
67
min
3
43
30
59
14
ref
8.0
ref
R4.0
ALL
ROUND
UNIT
mm
P
10°±1°
mil
The recommended mounting pad size
0.7
(28)
0.6
(24)
1.42
(56)
www.yongyutai.com
Unit: mm
(mil)
PAGE 3
很抱歉,暂时无法提供与“SD103AX”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.09472
- 500+0.07431
- 1500+0.06297
- 8000+0.05616
- 24000+0.05022
- 48000+0.04709
