MM5Z3V9B
MM5Z3V9B
    ST(先科)
    SOD-523(SC-79)
    5UA
MM5Z3V9B 数据手册
MM5Z2V2B~MM5Z39B Silicon Planar Zener Diodes PINNING Features • Total power dissipation: max. 200 mW • Small plastic package suitable for surface mounted design • High reliability PIN DESCRIPTION 1 Cathode 2 Anode 2 1 Top View Simplified outline SOD-523 and symbol Description Silicon planar Zener diode in a small plastic SMD SOD-523 package Absolute Maximum Ratings (Ta = 25 OC) Parameter Power Dissipation Junction Temperature Storage Temperature Range Symbol Value Unit Ptot 200 mW Tj 150 ℃ TStg - 55 to + 150 ℃ Symbol Max. Unit RthA 635 ℃/W VF 0.9 V Characteristics at Ta = 25 OC Parameter Thermal Resistance Junction to Ambient Air Forward Voltage at IF = 10 mA 1/3 ® Dated : 18/03/2020 Rev : 01 MM5Z2V2B~MM5Z39B Characteristics at Ta = 25 OC Type Marking Code Zener Voltage Range 1) lZT for Dynamic Impedance 2) VZT ZZT (Max.) at IZT Reverse Leakage Current IR (Max.) at VR MM5Z2V2B RM mA 5 V 2.1...2.4 Ω 100 mA 5 μA 120 V 0.7 MM5Z2V4B RN 5 2.3…2.65 100 5 120 1 MM5Z2V7B RP 5 2.65…2.95 110 5 120 1 MM5Z3V0B RR 5 2.95…3.25 120 5 50 1 MM5Z3V3B RX 5 3.25…3.55 120 5 20 1 MM5Z3V6B RY 5 3.6…3.845 100 5 10 1 MM5Z3V9B JY 5 3.89…4.16 100 5 5 1 MM5Z4V3B JZ 5 4.17…4.43 100 5 5 1 MM5Z4V7B KA 5 4.55…4.75 100 5 2 1 MM5Z5V1B KB 5 4.98…5.2 80 5 2 1.5 MM5Z5V6B KC 5 5.49…5.73 60 5 1 2.5 MM5Z6V2B KD 5 6.06…6.33 60 5 1 3 MM5Z6V8B KE 5 6.65…6.93 40 5 0.5 3.5 MM5Z7V5B KF 5 7.28…7.6 30 5 0.5 4 MM5Z8V2B KH 5 8.02…8.36 30 5 0.5 5 MM5Z9V1B KJ 5 8.85…9.23 30 5 0.5 6 MM5Z10B KK 5 9.77…10.21 30 5 0.1 7 MM5Z11B KM 5 10.76…11.22 30 5 0.1 8 MM5Z12B KN 5 11.74…12.24 30 5 0.1 9 MM5Z13B KP 5 12.91…13.49 37 5 0.1 10 MM5Z15B KR 5 14.34…14.98 42 5 0.1 11 MM5Z16B KX 5 15.85…16.51 50 5 0.1 12 MM5Z18B KY 5 17.56…18.35 65 5 0.1 13 MM5Z20B KZ 5 19.52…20.39 85 5 0.1 15 MM5Z22B RZ 5 21.54…22.47 100 5 0.1 17 MM5Z24B XA 5 23.72…24.78 120 5 0.1 19 MM5Z27B XB 5 26.19…27.53 150 5 0.1 21 MM5Z30B XC 5 29.19…30.69 200 5 0.1 23 MM5Z33B XD 5 32.15…33.79 250 5 0.1 25 MM5Z36B XE 5 35.07…36.87 300 5 0.1 27 MM5Z39B XF 5 37…41 100 5 2 30 1) VZ is tested with pulses (20 ms). 2) ZZT is measured at IZ by given a very small A.C. current signal. 2/3 ® Dated : 18/03/2020 Rev : 01 MM5Z2V2B~MM5Z39B PACKAGE OUTLINE Plastic surface mounted package; 2 leads SOD-523 ALL ROUND C A ∠ HE D bp E A A bp C D E HE V 0.70 0.60 0.4 0.3 0.135 0.100 1.25 1.15 0.85 0.75 1.7 1.5 0.1 UNIT mm ∠ 5 O Recommended Soldering Footprint 1.7 0.6 0.8 Packing information Package SOD-523 Pitch Tape Width Reel Size (mm) mm inch mm inch 8 4 ± 0.1 0.157 ± 0.004 178 7 Per Reel Packing Quantity 4,000 Marking information " ** " = Part No " III " = Cathode line Font type: Arial ** 3/3 ® Dated : 18/03/2020 Rev : 01
MM5Z3V9B 价格&库存
很抱歉,暂时无法提供与“MM5Z3V9B”相匹配的价格&库存,您可以联系我们找货
MM5Z3V9B
  • 20+0.13457
  • 200+0.10487
  • 600+0.08835
库存:3153
