1SS389
1SS389
    MSKSEMI(美森科)
    SOD-523(SC-79)
    电压:10V 电流:100MA
1SS389 数据手册
1SS389 Product specification 1SS389 FEATURES  High Speed  Small Package  High Reliability  Low Forward Voltage Reference News PACKAGE OUTLINE PIN CONFIGURATION Marking S4 SOD-523 MAXIMUM RATINGS ( Ta=25℃ unless otherwise noted ) Symbol Parameter Value Unit VR DC Blocking Voltage 10 V IO Continuous Forward Current 100 mA IFM Peak Forward Current 200 mA IFSM Non-repetitive Peak Forward Surge Current @t=8.3ms 1 A PD Power Dissipation 150 mW Thermal Resistance From Junction To Ambient 667 ℃/W Operating Junction Temperature Range -40~+125 ℃ Storage Temperature Range -55~+150 ℃ RθJA Tj Tstg ELECTRICAL CHARACTERISTICS(Ta=25℃ unless otherwise specified) Parameter Symbol Test conditions Min Reverse voltage V(BR) Reverse current IR Max Unit 20 μA IF=5mA 0.3 V IF=100mA 0.5 VR=0V,f=1MHz 40 IR=100μA Total capacitance Copyright© Msksemi Incorporated VF Ctot Typ VR=10V IF=1mA Forward voltage 10 V 0.18 pF www.msksemi.com 1SS389 Forward Characteristics Reverse Characteristics 1000 100 Pulsed (uA) REVERSE CURRENT IR a =1 T= a 2 5℃ 00 ℃ 10 T FORWARD CURRENT IF (mA) Pulsed 1 0.1 0.0 0.1 0.2 0.3 FORWARD VOLTAGE VF 0.4 Ta=100℃ 100 10 1 0.1 0.5 Ta=25℃ 0 2 Capacitance Characteristics 6 VR 8 10 100 125 (V) Power Derating Curve 200 50 Ta=25℃ f=1MHz 40 POWER DISSIPATION PD (mW) CAPACITANCE BETWEEN TERMINALS CT (pF) 4 REVERSE VOLTAGE (V) 30 20 150 100 50 10 0 0 2 4 6 REVERSE VOLTAGE VR (V) Copyright© Msksemi Incorporated 8 10 0 0 25 50 75 AMBIENT TEMPERATURE Ta (℃) www.msksemi.com 1SS389 PACKAGE MECHANICAL DATA 6\PERO A A1 b c D E E1 E2 L  'LPHQVLRQV,Q0LOOLPHWHUV 0LQ 0D[ 0.510 0.770 0.500 0.700 0.250 0.350 0.080 0.150 0.750 0.850 1.100 1.300 1.500 1.700 0.200 REF 0.010 0.070 7° REF 'LPHQVLRQV,Q,QFKHV 0LQ 0D[ 0.020 0.031 0.020 0.028 0.010 0.014 0.003 0.006 0.030 0.033 0.043 0.051 0.059 0.067 0.008 REF 0.001 0.003 7° REF Note: 1.Controlling dimension:in millimeters. 2.General tolerance:±0.05mm. 3.The pad layout is for reference purposes only. REEL SPECIFICATION P/N 1SS389 Copyright© Msksemi Incorporated PKG QTY SOD-523 3000 www.msksemi.com 1SS389 Attention ■ Any and all MSKSEMI Semiconductor products described or contained herein do not handle applications that require extremely high levels of reliability, such as life-support have specifications that can systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you before using any MSKSEMI Semiconductor products described or contained herein in such applications. ■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein. ■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment. ■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design. ■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from theauthorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of MSKSEMI Semiconductor. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI Semiconductor productthat you intend to use. Copyright© Msksemi Incorporated www.msksemi.com
1SS389 价格&库存
很抱歉,暂时无法提供与“1SS389”相匹配的价格&库存,您可以联系我们找货
1SS389
  • 20+0.15708
  • 200+0.12238
  • 600+0.10309
  • 3000+0.09153
  • 9000+0.08144
  • 21000+0.07610
库存:151
1SS389
  • 10+0.04220
  • 100+0.03890
库存:4633
