SMT-Type Zener Diode
BZX584C2V0 - BZX584C75
FEATURES
Large selection of zener voltages: 2.0V ~ 75V
Tight voltage tolerance: ±5% for C-series
Ultra low-profile package well suited for automated assembly
MSL Class 1 compatible
APPLICATIONS
General voltage regulation
Mobile & handheld systems
SOD-523
ORDERING INFORMATION
Part Number
Marking
Package
See Electrical Characteristics
SOD-523
MAXIMUM RATING (@ TA = 25°C unless otherwise specified)
Parameter
Symbol
Value
Forward Voltage @ IF=10mA
VF
0.9
V
Power Dissipation (Collector)
PC
150
mW
RθJA
834
°C/W
Junction Temperature Range
TJ
-55 ~ +150
°C
Storage Temperature Range
TSTG
-65 ~ +150
°C
Thermal Resistance (Junction-to-Ambient)
Unit
Note: These ratings are limiting values above which the serviceability of the diodes may be impaired.
Revision:20170701-P1
ht t p : //
www.lgesemi .c o m
mail:lge@lgesemi.com
ELECTRICAL CHARACTERISTICS (@ TA = 25°C unless otherwise specified)
Part
Number
BZX584C2V0
BZX584C2V2
BZX584C2V4
BZX584C2V7
BZX584C3V0
BZX584C3V3
BZX584C3V6
BZX584C3V9
BZX584C4V3
BZX584C4V7
BZX584C5V1
BZX584C5V6
BZX584C6V2
BZX584C6V8
BZX584C7V5
BZX584C8V2
BZX584C9V1
BZX584C10
BZX584C11
BZX584C12
BZX584C13
BZX584C15
BZX584C16
BZX584C18
BZX584C20
BZX584C22
BZX584C24
BZX584C27
BZX584C30
BZX584C33
BZX584C36
BZX584C39
BZX584C43
BZX584C47
BZX584C51
BZX584C56
BZX584C62
BZX584C68
BZX584C75
Revision:20170701-P2
Marking
Code
Z10
Z19
Z11
Z12
Z13
Z14
Z15
Z16
Z17
Z1
Z2
Z3
Z4
Z5
Z6
Z7
Z8
Z9
Y1
Y2
Y3
Y4
Y5
Y6
Y7
Y8
Y9
Y10
Y11
Y12
Y13
Y14
Y15
Y16
Y17
Y18
Y19
Y20
Y21
Zener Voltage
VZ (V)
Min.
Typ.
Max.
1.90
2.09
2.28
2.57
2.85
3.14
3.42
3.71
4.09
4.47
4.85
5.32
5.89
6.46
7.13
7.79
8.65
9.50
10.45
11.40
12.35
14.25
15.20
17.10
19.00
20.90
22.80
25.65
28.50
31.35
34.20
37.05
40.85
44.65
48.45
53.20
58.90
64.60
71.25
2.00
2.20
2.40
2.70
3.00
3.30
3.60
3.90
4.30
4.70
5.10
5.60
6.20
6.80
7.50
8.20
9.10
10.00
11.00
12.00
13.00
15.00
16.00
18.00
20.00
22.00
24.00
27.00
30.00
33.00
36.00
39.00
43.00
47.00
51.00
56.00
62.00
68.00
75.00
2.10
2.31
2.52
2.84
3.15
3.47
3.78
4.10
4.52
4.94
5.36
5.88
6.51
7.14
7.88
8.61
9.56
10.50
11.55
12.60
13.65
15.75
16.80
18.90
21.00
23.10
25.20
28.35
31.50
34.65
37.80
40.95
45.15
49.35
53.55
58.80
65.10
71.40
78.75
ht t p : //
@ IZT
(mA)
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
2
2
2
2
2
2
2
2
2
2
2
2
Maximum Zener
Impedance
ZZT (Ω)
@ IZK
ZZK (Ω)
@ IZT
(mA)
100
600
1.0
100
600
1.0
100
600
1.0
100
600
1.0
95
600
1.0
95
600
1.0
90
600
1.0
90
600
1.0
90
600
1.0
80
500
1.0
60
480
1.0
40
400
1.0
10
150
1.0
15
80
1.0
15
80
1.0
15
80
1.0
15
100
1.0
1.0
1.0
25
150
1.0
30
170
1.0
30
200
1.0
40
200
1.0
45
225
1.0
55
225
1.0
55
250
1.0
70
250
1.0
80
300
0.5
80
300
0.5
80
325
0.5
0.5
90
350
130
350
0.5
150
375
0.5
170
375
0.5
180
400
0.5
200
400
0.5
215
423
0.5
240
447
0.5
255
470
0.5
www.lgesemi .c o m
Temperature
Coefficient
@ IZT
TC (mV/°C)
Min.
Max.
-3.5
-3.5
-3.5
-3.5
-3.5
-3.5
-3.5
-3.5
-3.5
-3.5
-2.7
-2.0
0.4
1.2
2.5
3.2
3.8
4.5
5.4
6.0
7.0
9.2
10.4
12.4
14.4
16.4
18.4
21.4
24.4
27.4
30.4
33.4
10.0
10.0
10.0
10.0
10.0
10.0
10.0
0.0
0.0
0.0
0.0
0.0
0.0
0.0
0.0
0.0
0.2
1.2
2.5
3.7
4.5
5.3
6.2
7.0
8.0
9.0
10.0
11.0
13.0
14.0
16.0
18.0
20.0
22.0
25.3
29.4
33.4
37.4
41.2
12.0
12.0
12.0
12.0
12.0
12.0
12.0
Maximum
Reverse @ VR
Current
(V)
IR (µA)
150.000
150.000
50.000
20.000
10.000
5.000
5.000
3.000
3.000
3.000
2.000
1.000
3.000
2.000
1.000
0.700
0.500
0.200
0.100
0.100
0.100
0.100
0.100
0.100
0.100
0.100
0.100
0.100
0.100
0.100
0.100
0.100
0.100
0.100
0.100
0.045
0.045
0.045
0.045
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
2.0
2.0
2.0
4.0
4.0
5.0
5.0
6.0
7.0
8.0
8.0
8.0
10.5
11.2
12.6
14.0
15.4
16.8
18.9
21.0
23.1
25.2
27.3
30.1
32.9
35.7
39.2
43.4
47.6
52.5
TYPICAL CHARACTERISTICS (@ TA = 25°C unless otherwise specified)
2V0
2V4
2V7
3V0
IZ, ZENER CURRENT (mA)
PD, POWER DISSIPATION (mW)
200
150
100
50
15
3V3
3V6
3V9
4V3
10
4V7
5V1
5V6
6V2
6V8
5
7V5
50
75
125
100
150
6
8
V Z, ZENER VOLTAGE (V)
2
T A, AMBIENT TEMPERATURE (°C)
Fig. 2 Typical Zener Breakdown Characteristics
Fig. 1 Power Derating Curve
30
TJ = 25°C
10
10
10
12
15
Test Current IZ
2mA
22
10
27
Test Current IZ
5mA
10
36
40
Fig. 3 Typical Zener Breakdown Characteristics
ht t p : //
6
4
2
VZ, ZENER VOLTAGE (V)
Revision:20170701-P3
8
30 40 50 60 70 80
VZ , ZENER VOLTAGE (V)
90 100
Fig. 4 Typical Zener Breakdown Characteristics
www.lgesemi .c o m
PACKAGE OUTLINE (Unit: mm)
Plastic surface mounted package
SOD-523
Dimension
Min.
Max.
A
1.10
1.30
B
0.70
0.90
C
0.50
0.70
D
0.25
0.35
E
0.15
0.25
J
0.05
0.15
K
1.50
1.70
MOUNTING PAD LAYOUT (Unit: mm)
PACKAGE INFORMATION
Part Number
Package
Shipping Quantity
SOD-523
3000pcs / Tape & Reel
Revision:20170701-P4
ht t p : //
www.lgesemi .c o m
很抱歉,暂时无法提供与“BZX584C18”相匹配的价格&库存,您可以联系我们找货
