MM5Z4V7AWT
MM5Z4V7AWT
    JINGDAO(晶导微电子)
    SOD-523(SC-79)
    耐压:4.7V 电流:2UA@1V
MM5Z4V7AWT 数据手册
山东晶导微电子股份有限公司 Jingdao Microelectronics co.LTD MM5Z2V4AWT THRU MM5Z75AWT PINNING Silicon Planar Zener Diodes PIN DESCRIPTION FEATURES 1 Cathode • Total power dissipation: Max. 200mW. • Wide zener reverse voltage range 2.4V to 75V. • Small plastic package suitable for surface mounted design. • Tolerance approximately ±5% 2 Anode 2 1 Top View Simplified outline SOD-523 and symbol Absolute Maximum Ratings And Characteristics (Ta = 25 °C) Symbol Value Unit Power Dissipation P tot 200 mW Forward Voltage at I F = 10mA VF 0.9 V T j , T stg -55 ~ +150 °C Parameter Operating and Storage Temperature Range Fig.1 Maximum Continuous Power Derating 0.30 Power Dissipation ( W ) 0.25 0.20 0.15 0.10 0.05 0.0 25 50 75 100 125 150 175 T A , Temperature (°C) 2021.11 SOD-523-W-MM5Z2V4AWT THRU MM5Z75AWT 200mW Page 1 of 3 山东晶导微电子股份有限公司 Jingdao Microelectronics co.LTD MM5Z2V4AWT THRU MM5Z75AWT Characteristics at Ta = 25°C Zener Voltage Range (1) Type Marking V ZT(at I ZT) Min(V) MM5Z2V4AWT Z7 Nom(V) 2.3 2.4 Reverse Current Zener Impedance Z ZT(at I ZT) I ZT Z ZK IR at V R (V) (mA) Max (Ω) I ZT (mA) Max (Ω) I ZK (mA) 2.5 5 100 5 1000 1 120 1 Max(V) Max(μA) MM5Z2V7AWT A8 2.6 2.7 2.8 5 100 5 1000 1 120 1 MM5Z3V0AWT B8 2.9 3 3.2 5 100 5 1000 1 50 1 MM5Z3V3AWT C8 3.1 3.3 3.5 5 95 5 1000 1 20 1 MM5Z3V6AWT D8 3.4 3.6 3.8 5 90 5 1000 1 10 1 MM5Z3V9AWT E8 3.7 3.9 4.1 5 90 5 1000 1 5 1 MM5Z4V3AWT F8 4.1 4.3 4.5 5 90 5 1000 1 5 1 MM5Z4V7AWT G8 4.5 4.7 4.9 5 80 5 800 1 2 1 MM5Z5V1AWT H8 4.8 5.1 5.4 5 60 5 500 1 2 1.5 MM5Z5V6AWT I8 5.3 5.6 5.9 5 40 5 200 1 1 2.5 5 10 5 100 1 1 3 15 5 160 1 0.5 3.5 MM5Z6V2AWT J8 5.9 6.2 6.5 MM5Z6V8AWT K8 6.5 6.8 7.1 5 MM5Z7V5AWT L8 7.1 7.5 7.9 5 15 5 160 1 0.5 4 MM5Z8V2AWT M8 7.8 8.2 8.6 5 15 5 160 1 0.5 5 MM5Z9V1AWT N8 8.6 9.1 9.6 5 15 5 160 1 0.5 6 MM5Z10AWT O8 9.5 10 10.5 5 20 5 160 1 0.1 7 MM5Z11AWT P8 10.5 11 11.6 5 20 5 160 1 0.1 8 MM5Z12AWT Q8 11.4 12 12.6 5 25 5 80 1 0.1 9 MM5Z13AWT R8 12.6 13.25 13.9 5 30 5 80 1 0.1 10 MM5Z15AWT S8 14.3 15 15.8 5 30 5 80 1 0.1 11 MM5Z16AWT T8 15.4 16.2 17.0 2 40 2 80 1 0.1 12 MM5Z18AWT U8 17.1 18 18.9 2 45 2 80 1 0.1 13 MM5Z20AWT V8 19.0 20 21.0 2 55 2 100 1 0.1 15 MM5Z22AWT W8 20.9 22 23.1 2 55 2 100 1 0.1 17 MM5Z24AWT X8 23.0 24.2 25.4 2 70 2 120 1 0.1 19 MM5Z27AWT Y8 25.7 27 28.4 2 80 2 300 1 0.1 21 MM5Z30AWT Z8 28.5 30 31.5 2 80 2 300 1 0.1 23 MM5Z33AWT A9 31.4 33 34.7 2 80 2 300 1 0.1 25 MM5Z36AWT B9 34.2 36 37.8 2 90 2 500 1 0.1 27 MM5Z39AWT C9 37.1 39 41.0 2 130 2 500 1 2 30 MM5Z43AWT D9 40.9 43 45.2 1 150 1 500 1 2 33 MM5Z47AWT E9 44.7 47 49.4 1 170 1 500 1 2 36 MM5Z51AWT F9 48.5 51 53.6 1 180 1 500 1 1 39 MM5Z56AWT G9 53.2 56 58.8 1 200 1 500 1 1 43 MM5Z62AWT H9 58.9 62 65.1 1 215 1 500 1 0.2 47 MM5Z68AWT I9 64.6 68 71.4 1 240 1 500 1 0.2 52 MM5Z75AWT J9 71.3 75 78.8 1 255 1 500 1 0.2 57 (1) V ZT is tested with pulses (20 ms) (2) A:±5% 2021.11 www.sdjingdao.com Page 2 of 3 山东晶导微电子股份有限公司 Jingdao Microelectronics co.LTD MM5Z2V4AWT THRU MM5Z75AWT PACKAGE OUTLINE Plastic surface mounted package; 2 leads SOD-523 ∠ALL ROUND A C A P E HE N N e E D 底视图 bottom view L A e C D E HE N L max 0.77 0.35 0.15 1.30 0.99 1.70 min 0.51 0.25 0.08 1.10 0.75 1.50 0.35 ref 0.2 ref R0.1 ALL ROUND max 30 14 6 51 39 67 min 20 10 3 43 30 59 14 ref 8.0 ref R4.0 ALL ROUND UNIT mm P ∠ 10°±1° mil The recommended mounting pad size 0.7 (28) 0.6 (24) 1.42 (56) 2021.11 Unit: mm (mil) Page 3 of 3
MM5Z4V7AWT 价格&库存
很抱歉,暂时无法提供与“MM5Z4V7AWT”相匹配的价格&库存,您可以联系我们找货
