� �D�
宏迦橙
RB521S-30
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
www.ichjc.com
Features
SOD-523
•High Current Capability
•Low Forward Voltage Drop
•Low IR
•Meets MSL level 1, per J-STD-020, LF maximum peak of 260℃
Applications
The device is a single rectifier offering low VF and excellent high
temperature stability.
Mechanical Data
•Case: SOD-523
Molding compound meets UL 94V-0 flammability rating, RoHS-compliant,
halogen-free
•Terminals: Solder plated, solderable per MIL-STD-750,Method 2026
•Polarity: Cathode line denotes the cathode end
Maximum Ratings (Ta=25℃ Unless otherwise specified)
PARAMETER
SYMBOL
UNIT
VALUE
Maximum Repetitive Peak Reverse Voltage
VRRM
V
30
Maximum average forward rectified current
IF(AV)
mA
200
Power Dissipation
PD
mW
150
Tj
Maximum DC blocking Voltage
VDC
Non-repetitive Peak Forward Surge Current
@ t=8.3ms Half-sine wave
V
IFSM
A
Storage temperature
Tstg
Typical Thermal Resistance
RθJ-A
Junction temperature
Electrical Characteristics (Ta=25℃ Unless otherwise specified)
PARAMETER
Maximum forward voltage
Maximum reverse current
Revision:SBD-May.2023-A0
TEST CONDITIONS
IF=10mA
IF=200mA
VR=10V
30
SYMBOL
UNIT
VF
V
IR
μA
1 of 3
1.0
-50 ~+150
℃ /W
667
125
Min
Typ
Max
0.50
Zhuhai Hongjiacheng Technology co., Ltd
0.35
30.0
www.ichjc.com
� �D�
宏迦橙
RB521S-30
www.ichjc.com
Ratings And Characteristics Curves (Ta=25℃ Unless otherwise specified)
1000
1000
100
INSTANTANEOUSREVERSECURRENT(μA)
FORWARDCURRENTIF(mA)
100
Ta=100°C
10
10
Ta=25°C
1
0.1
0.01
Ta=100°C
100
200
300
400
500
FORWARDVOLTAGEVF(mV)
0.1
600
Ta=25°C
1
Fig.1 Typical Instaneous Forward Characteristics
100
10
15
30
Fig.2 Typical Reverse Characteristics
200
Ta=25℃
f=1MHz
CAPACITANCEBETWEENTERMINALSCT(pF)
5
PERCENTOFRATEDPEAKREVERSEVOLTAGE(%)
POWERDISSIPATIONP(mW)
D
150
100
10
50
1
10
REVERSEVOLTAGEVR(V)
15
Fig.3 Typical Junction Capacitance
50
75
100
AMBIENTTEMPERATURETa(℃)
125
150
Fig.4 Power Derating Curve
2 of 3
www.ichjc.com
� �D�
宏迦橙
RB521S-30
www.ichjc.com
Ordering Information
PACKAGE
PACKAGE CODE
UNIT WEIGHT(g)
REEL(pcs)
BOX(pcs)
CARTON(pcs)
DELIVERY MODE
SOD-523
R1
0.002
3000
45000
180000
7"
Package Outline Dimensions (SOD-523)
Symbol
CathodeBand
B E
A
D
F
C
Dimensions
Millimeters
A
Min
1.10
Max
1.30
0.044
0.052
B
0.25
0.35
0.01
0.014
C
1.50
1.70
0.06
0.068
D
0.50
0.70
0.02
0.028
E
0.70
0.90
0.028
0.036
F
0.05
0.20
0.002
0.008
Suggested Pad Layout
J
K
J
Symbol
M
J
K
M
3 of 3
Dimensions
Millimeters
Min.
Max.
1.10
0.60
0.80
Min
Inches
Min.
0.023
0.031
Inches
Max
Max.
0.042
www.ichjc.com
很抱歉,暂时无法提供与“RB521S-30”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.12507
- 500+0.10347
- 3000+0.08198
- 6000+0.07474
- 24000+0.06858
- 51000+0.06524
