RB521S-40
RB521S-40
    HONGJIACHENG(宏嘉诚)
    SOD-523(SC-79)
    电压:40V 电流:0.2A
RB521S-40 数据手册
� �D� 宏迦橙 RB521S-40 SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER www.ichjc.com Features SOD-523 •High Current Capability •Low Forward Voltage Drop •Low IR •Meets MSL level 1, per J-STD-020, LF maximum peak of 260℃ Applications The device is a single rectifier offering low VF and excellent high temperature stability. Mechanical Data •Case: SOD-523 Molding compound meets UL 94V-0 flammability rating, RoHS-compliant, halogen-free •Terminals: Solder plated, solderable per MIL-STD-750,Method 2026 •Polarity: Cathode line denotes the cathode end Maximum Ratings (Ta=25℃ Unless otherwise specified) PARAMETER SYMBOL UNIT VALUE Maximum Repetitive Peak Reverse Voltage VRRM V 40 Maximum DC blocking Voltage VDC Non-Repetitive Peak reverse voltage VRM Maximum RMS Voltage V VRMS 45 V 28 V 40 Maximum average forward rectified current IF(AV) mA 200 Power Dissipation PD mW 150 Tj ℃ Non-repetitive Peak Forward Surge Current @ t=8.3ms Half-sine wave IFSM A Storage temperature Tstg Typical Thermal Resistance RθJ-A PARAMETER TEST CONDITIONS SYMBOL UNIT Maximum forward voltage IF=100mA VF V IR μA Junction temperature Electrical Characteristics (Ta=25℃ Unless otherwise specified) Maximum reverse current Revision:SBD-May.2023-A0 IF=10mA IF=200mA VR=10V VR=40V 1 of 3 1.0 ℃ -50 ~+150 ℃ /W 667 125 Min Typ Max 0.31 - 0.45 0.16 0.41 Zhuhai Hongjiacheng Technology co., Ltd - - - - - - 0.30 0.54 20 90 www.ichjc.com � �D� 宏迦橙 RB521S-40 SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER www.ichjc.com Ratings And Characteristics Curves (Ta=25℃ Unless otherwise specified) 1000 200 FORWARDCURRENTIF(mA) Ta=100°C 100 10 Ta=100°C 10 Ta=25°C 1 0.1 INSTANTANEOUSREVERSECURRENT(μA) 100 0 100 200 300 FORWARDVOLTAGEVF(mV) 400 0.1 500 Ta=25°C 1 0 Fig.1 Typical Instaneous Forward Characteristics 100 15 20 100 25 30 Ta=25℃ f=1MHz CAPACITANCEBETWEENTERMINALSCT(pF) Ta=25℃ f=1MHz CAPACITANCEBETWEENTERMINALSCT(pF) 10 Fig.2 Typical Reverse Characteristics 10 1 5 PERCENTOFRATEDPEAKREVERSEVOLTAGE(%) 10 0 5 10 15 20 REVERSEVOLTAGEVR(V) 25 1 30 0 5 Fig.3 Typical Junction Capacitance Revision:SBD-May.2023-A0 10 15 20 REVERSEVOLTAGEVR(V) 25 30 Fig.4 Power Derating Curve 2 of 3 Zhuhai Hongjiacheng Technology co., Ltd www.ichjc.com � �D� 宏迦橙 RB521S-40 SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER www.ichjc.com Ordering Information PACKAGE PACKAGE CODE UNIT WEIGHT(g) REEL(pcs) BOX(pcs) CARTON(pcs) DELIVERY MODE SOD-523 R1 0.002 3000 45000 180000 7" Package Outline Dimensions (SOD-523) Symbol CathodeBand B E A D F C Dimensions Millimeters A Min 1.10 Max 1.30 0.044 0.052 B 0.25 0.35 0.01 0.014 C 1.50 1.70 0.06 0.068 D 0.50 0.70 0.02 0.028 E 0.70 0.90 0.028 0.036 F 0.05 0.20 0.002 0.008 Suggested Pad Layout J K J Symbol M J K M Revision:SBD-May.2023-A0 3 of 3 Dimensions Millimeters Min. Max. - 1.10 0.60 0.80 Zhuhai Hongjiacheng Technology co., Ltd Min Inches Min. - 0.023 - 0.031 - Inches Max Max. - 0.042 - www.ichjc.com
RB521S-40 价格&库存
很抱歉,暂时无法提供与“RB521S-40”相匹配的价格&库存,您可以联系我们找货
