MM5Z2V2B~MM5Z39B
Silicon Planar Zener Diodes
PINNING
Features
• Total power dissipation: max. 200 mW
• Small plastic package suitable for
surface mounted design
• High reliability
PIN
DESCRIPTION
1
Cathode
2
Anode
2
1
Top View
Simplified outline SOD-523 and symbol
Description
Silicon planar Zener diode in a small plastic
SMD SOD-523 package
Absolute Maximum Ratings (Ta = 25 OC)
Parameter
Power Dissipation
Junction Temperature
Storage Temperature Range
Symbol
Value
Unit
Ptot
200
mW
Tj
150
TStg
- 55 to + 150
Symbol
Max.
Unit
RthA
635
℃/W
VF
0.9
V
Characteristics at Ta = 25 OC
Parameter
Thermal Resistance Junction to Ambient Air
Forward Voltage
at IF = 10 mA
1/3
Dated : 18/03/2020 Rev : 01
MM5Z2V2B~MM5Z39B
Type
Marking
Code
Zener Voltage Range 1)
lZT
for
Dynamic Impedance 2)
VZT
ZZT (Max.)
at IZT
Reverse Leakage Current
IR (Max.)
at VR
MM5Z2V2B
RM
mA
5
V
2.1...2.4
Ω
100
mA
5
μA
120
V
0.7
MM5Z2V4B
RN
5
2.3…2.65
100
5
120
1
MM5Z2V7B
RP
5
2.65…2.95
110
5
120
1
MM5Z3V0B
RR
5
2.95…3.25
120
5
50
1
MM5Z3V3B
RX
5
3.25…3.55
120
5
MM5Z3V6B
RY
5
3.6…3.845
100
5
10
1
MM5Z3V9B
JY
5
3.89…4.16
100
5
5
1
MM5Z4V3B
JZ
5
4.17…4.43
100
5
5
1
MM5Z4V7B
KA
5
4.55…4.75
100
5
2
1
MM5Z5V1B
KB
5
4.98…5.2
80
5
2
1.5
MM5Z5V6B
KC
5
5.49…5.73
60
5
1
2.5
MM5Z6V2B
KD
5
6.06…6.33
60
5
1
3
MM5Z6V8B
KE
5
6.65…6.93
40
5
0.5
3.5
MM5Z7V5B
KF
5
7.28…7.6
30
5
0.5
4
MM5Z8V2B
KH
5
8.02…8.36
30
5
0.5
5
MM5Z9V1B
KJ
5
8.85…9.23
30
5
0.5
6
MM5Z10B
KK
5
9.77…10.21
30
5
0.1
7
MM5Z11B
KM
5
10.76…11.22
30
5
0.1
8
MM5Z12B
KN
5
11.74…12.24
30
5
0.1
9
MM5Z13B
KP
5
12.91…13.49
37
5
0.1
10
MM5Z15B
KR
5
14.34…14.98
42
5
0.1
11
MM5Z16B
KX
5
15.85…16.51
50
5
0.1
12
MM5Z18B
KY
5
17.56…18.35
65
5
0.1
13
MM5Z20B
KZ
5
19.52…20.39
85
5
0.1
15
MM5Z22B
RZ
5
21.54…22.47
100
5
0.1
17
MM5Z24B
XA
5
23.72…24.78
120
5
0.1
19
MM5Z27B
XB
5
26.19…27.53
150
5
0.1
21
MM5Z30B
XC
5
29.19…30.69
200
5
0.1
23
MM5Z33B
XD
5
32.15…33.79
250
5
0.1
25
MM5Z36B
XE
5
35.07…36.87
300
5
0.1
27
MM5Z39B
XF
5
37…41
100
5
2
30
1)
VZ is tested with pulses (20 ms).
2)
ZZT is measured at IZ by given a very small A.C. current signal.
2/3
MM5Z2V2B~MM5Z39B
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SOD-523
ALL ROUND
C
A
HE
D
bp
E
A
A
bp
C
D
E
HE
V
0.70
0.60
0.4
0.3
0.135
0.100
1.25
1.15
0.85
0.75
1.7
1.5
0.1
UNIT
mm
5
O
Recommended Soldering Footprint
1.7
0.6
0.8
Packing information
Package
SOD-523
Pitch
Tape Width
Reel Size
(mm)
mm
inch
mm
inch
8
4 ± 0.1
0.157 ± 0.004
178
7
Per Reel Packing Quantity
4,000
Marking information
" ** " = Part No
" III " = Cathode line
Font type: Arial
3/3
很抱歉,暂时无法提供与“MM5Z22B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.13997
- 200+0.11178
- 600+0.09612
