MM5Z18B
MM5Z18B
    ST(先科)
    SOD-523(SC-79)
MM5Z18B 数据手册
MM5Z2V2B~MM5Z39B Silicon Planar Zener Diodes PINNING Features • Total power dissipation: max. 200 mW • Small plastic package suitable for surface mounted design • High reliability PIN DESCRIPTION 1 Cathode 2 Anode 2 1 Top View Simplified outline SOD-523 and symbol Absolute Maximum Ratings (Ta = 25℃) Parameter Power Dissipation Junction Temperature Storage Temperature Range Symbol Value Unit Ptot 200 mW Tj 150 ℃ TStg - 55 to + 150 ℃ Symbol Max. Unit RθJA 625 ℃/W Thermal Characteristics Parameter Thermal Resistance Junction to Ambient 1) 1) Device mounted on FR-4 substrate PC board, 2oz copper, with minimum recommended pad layout. 1/4 ® Dated : 05/08/2021 Rev : 02 MM5Z2V2B~MM5Z39B Characteristics at Ta = 25℃ (VF = 0.9 V Max. at IF = 10 mA) Type Marking Code Zener Voltage Range 1) lZT for Dynamic Impedance 2) VZT ZZT (Max.) at IZT Reverse Leakage Current IR (Max.) at VR MM5Z2V2B RM mA 5 V 2.1...2.4 Ω 100 mA 5 μA 120 V 0.7 MM5Z2V4B RN 5 2.3…2.65 100 5 120 1 MM5Z2V7B RP 5 2.65…2.95 110 5 120 1 MM5Z3V0B RR 5 2.95…3.25 120 5 50 1 MM5Z3V3B RX 5 3.25…3.55 120 5 20 1 MM5Z3V6B RY 5 3.6…3.845 100 5 10 1 MM5Z3V9B JY 5 3.89…4.16 100 5 5 1 MM5Z4V3B JZ 5 4.17…4.43 100 5 5 1 MM5Z4V7B KA 5 4.55…4.75 100 5 2 1 MM5Z5V1B KB 5 4.98…5.2 80 5 2 1.5 MM5Z5V6B KC 5 5.49…5.73 60 5 1 2.5 MM5Z6V2B KD 5 6.06…6.33 60 5 1 3 MM5Z6V8B KE 5 6.65…6.93 40 5 0.5 3.5 MM5Z7V5B KF 5 7.28…7.6 30 5 0.5 4 MM5Z8V2B KH 5 8.02…8.36 30 5 0.5 5 MM5Z9V1B KJ 5 8.85…9.23 30 5 0.5 6 MM5Z10B KK 5 9.77…10.21 30 5 0.1 7 MM5Z11B KM 5 10.76…11.22 30 5 0.1 8 MM5Z12B KN 5 11.74…12.24 30 5 0.1 9 MM5Z13B KP 5 12.91…13.49 37 5 0.1 10 MM5Z15B KR 5 14.34…14.98 42 5 0.1 11 MM5Z16B KX 5 15.85…16.51 50 5 0.1 12 KY 5 17.56…18.35 65 5 0.1 13 MM5Z20B KZ 5 19.52…20.39 85 5 0.1 15 MM5Z22B RZ 5 21.54…22.47 100 5 0.1 17 MM5Z24B XA 5 23.72…24.78 120 5 0.1 19 MM5Z27B XB 5 26.19…27.53 150 5 0.1 21 MM5Z30B XC 5 29.19…30.69 200 5 0.1 23 MM5Z33B XD 5 32.15…33.79 250 5 0.1 25 MM5Z36B XE 5 35.07…36.87 300 5 0.1 27 MM5Z39B XF 5 37…41 100 5 2 30 MM5Z18B 1) VZ is tested with pulses (20 ms). 2) ZZT is measured at IZ by given a very small A.C. current signal. 2/4 ® Dated : 05/08/2021 Rev : 02 MM5Z2V2B~MM5Z39B Electrical Characteristics Curves Fig 2. Zener Characteristics Curve Zener Current (mA) Fig 1. Forward Characteristics Curve Zener Voltage (V) Fig 4. Power Derating Curve Fig 3. Zener Characteristics Curve Zener Current (mA) Power Dissipation (mW) 250 200 150 100 50 0 0 25 50 75 100 125 150 Ambient Temperature (℃) Zener Voltage (V) 3/4 ® Dated : 05/08/2021 Rev : 02 MM5Z2V2B~MM5Z39B PACKAGE OUTLINE Plastic surface mounted package; 2 leads SOD-523 ALL ROUND C A ∠ HE D bp E A A bp C D E HE V 0.70 0.60 0.4 0.3 0.135 0.100 1.25 1.15 0.85 0.75 1.7 1.5 0.1 UNIT mm ∠ 5 O Recommended Soldering Footprint 1.7 0.6 0.8 Packing information Package SOD-523 Pitch Tape Width Reel Size (mm) mm inch mm inch 8 4 ± 0.1 0.157 ± 0.004 178 7 Per Reel Packing Quantity 4,000 Marking information " ** " = Part No " III " = Cathode line Font type: Arial ** 4/4 ® Dated : 05/08/2021 Rev : 02
MM5Z18B 价格&库存
很抱歉,暂时无法提供与“MM5Z18B”相匹配的价格&库存,您可以联系我们找货
