TCMM5Z3V3
TCMM5Z3V3
    TC(德昌)
    SOD-523(SC-79)
    齐纳/稳压二极管 3.3V SOD-523(SC-79)
TCMM5Z3V3 数据手册
® SEMICOND UC TOR 200mW SOD-523 SURFACE MOUNT Green Product Very Small Outline Flat Lead Plastic Package Zener Voltage Regulators Absolute Maximum Ratings Symbol TA = 25°C unless otherwise noted Parameter Units 200 mW TSTG Storage Temperature Range -55 to +150 °C TOPR Operating Temperature Range -55 to +150 °C PD Power Dissipation Value These ratings are limiting values above which the serviceability of the diode may be impaired. SOD-523 Flat Lead Specification Features: ƒ ƒ ƒ ƒ ƒ ƒ ƒ ƒ Wide Zener Voltage Range Selection, 2.0V to 75V Flat Lead SOD-523 Small Outline Plastic Package Extremely Small SOD-523 Package Anode Cathode Surface Device Type Mounting ELECTRICAL SYMBOL RoHS Compliant Green EMC Matte Tin(Sn) Lead Finish Band Indicates Cathode Electrical Characteristics Device Type Device Marking TCMM5Z2V0 TCMM5Z2V2 TCMM5Z2V4 TCMM5Z2V7 TCMM5Z3V0 TCMM5Z3V3 TCMM5Z3V6 TCMM5Z3V9 TCMM5Z4V3 TCMM5Z4V7 TCMM5Z5V1 TCMM5Z5V6 TCMM5Z6V2 TCMM5Z6V8 TCMM5Z7V5 TCMM5Z8V2 TCMM5Z9V1 TCMM5Z10V TCMM5Z11V TCMM5Z12V TCMM5Z13V TCMM5Z15V TCMM5Z16V 5± 5⊥ 50 51 52 53 54 55 56 57 58 59 5A 5B 5C 5D 5E 5F 5G 5H 5J 5K 5L TA = 25°C unless otherwise noted VZ @ IZT (Volts) Min Nom Max 1.90 2.09 2.2 2.5 2.8 3.1 3.4 3.7 4.0 4.4 4.8 5.2 5.8 6.4 7.0 7.7 8.5 9.4 10.4 11.4 12.4 14.3 15.3 2.0 2.2 2.4 2.7 3.0 3.3 3.6 3.9 4.3 4.7 5.1 5.6 6.2 6.8 7.5 8.2 9.1 10 11 12 13 15 16 2.10 2.31 2.6 2.9 3.2 3.5 3.8 4.1 4.6 5.0 5.4 6.0 6.6 7.2 7.9 8.7 9.6 10.6 11.6 12.7 14.1 15.8 17.1 IZT (mA) ZZT @ IZT (Ω) Max IZK (mA) ZZK @ IZK (Ω) Max IR @ VR (μA) Max VR (Volts) 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 100 100 100 100 100 95 90 90 90 80 60 40 10 15 15 15 15 20 20 25 30 30 40 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 564 564 1000 1000 1000 1000 1000 1000 1000 800 500 200 100 160 160 160 160 160 160 80 80 80 80 120 120 50 20 10 5 5 3 3 3 2 1 3 2 1 0.7 0.2 0.1 0.1 0.1 0.1 0.05 0.05 0.5 0.7 1 1 1 1 1 1 1 2 2 2 4 4 5 5 7 8 8 8 8 10.5 11.2 Number: DB-004 December 2014, Revision G Page 1 TCMM5Z2V0 through TCMM5Z75V TAK CHEONG TAK CHEONG ® SEMICOND UC TOR Electrical Characteristics Device Type Device Marking TA = 25°C unless otherwise noted VZ @ IZT (Volts) Min Nom Max TCMM5Z18V 5M 16.8 18 19.1 TCMM5Z20V 5N 18.8 20 21.2 TCMM5Z22V 5P 20.8 22 23.3 TCMM5Z24V 5R 22.8 24 25.6 TCMM5Z27V 5S 25.1 27 28.9 TCMM5Z30V 5T 28 30 32 TCMM5Z33V 5U 31 33 35 TCMM5Z36V 5V 34 36 38 TCMM5Z39V 5X 37 39 41 TCMM5Z43V 5Y 40 43 46 TCMM5Z47V 5Z 44 47 50 TCMM5Z51V 5− 48 51 54 TCMM5Z56V 5= 52 56 60 TCMM5Z62V 5≡ 58 62 66 TCMM5Z68V 5> 64 68 72 TCMM5Z75V 5< 70 75 79 VF Forward Voltage = 1 V Maximum @ IF = 10 mA for all types Notes: 1. 2. 3. IZT (mA) ZZT @ IZT (Ω) Max IZK (mA) ZZK @ IZK (Ω) Max IR @ VR (μA) Max VR (Volts) 5 5 5 5 2 2 2 2 2 2 2 2 2 2 2 2 45 55 55 70 80 80 80 90 130 150 170 180 200 215 240 255 1 1 1 1 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 80 100 100 120 300 300 300 500 500 500 500 500 500 500 500 500 0.05 0.05 0.05 0.05 0.05 0.05 0.05 0.05 0.05 0.05 0.05 0.05 0.05 0.05 0.05 0.05 12.6 14 15.4 16.8 18.9 21 23.2 25.2 27.3 30.1 32.9 35.7 39.2 43.4 47.6 52.5 The Zener Voltage (VZ) is tested under pulse condition of 10mS. For detailed information on price, availability and delivery of nominal zener voltages between the voltages shown and tighter voltage tolerances, contact your nearest Tak Cheong Electronics representative. The zener impedance is derived from the 60-cycle ac voltage, which results when an ac current having an rms value equal to 10% of the dc zener current (IZT or IZK) is superimposed to IZT or IZK. Number: DB-004 December 2014, Revision G Page 2 TAK CHEONG ® SEMICOND UC TOR RATING AND CHARACTERISTIC CURVES Fig.2 EFFECT OF ZENER VOLTAGE ON ZENER IMPEDANCE Fig.1 TYPICAL FORWARD VOLTAGE POWER PASSIPATION,mW 250 200 150 100 50 0 0 25 50 75 100 125 150 175 200 TEMPERATURE [℃ ] Fig.3 POWER DISSIPATION VS. AMBIENT TEMP. Fig.5 ZENER BREAKDOWN CHARACTERISTICS Fig.4 TYPICAL CAPACITANCE Fig.6 ZENER BREAKDOWN CHARACTERISTICS Number: DB-004 December 2014, Revision G Page 3 TAK CHEONG ® SEMICOND UC TOR Fig.7 TYPICAL LEAKGE CURRENT Flat Lead SOD-523 Package Outline Note: Dimensions are exclusive of Burrs, Mold Flash & Tie Bar extrusions. Number: DB-004 December 2014, Revision G Page 4 TAK CHEONG ® DISC LA I MER NOTIC E NOTICE The information presented in this document is for reference only. Tak Cheong reserves the right to make changes without notice for the specification of the products displayed herein. The product listed herein is designed to be used with ordinary electronic equipment or devices, and not designed to be used with equipment or devices which require high level of reliability and the malfunction of with would directly endanger human life (such as medical instruments, transportation equipment, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety devices), Tak Cheong Semiconductor Co., Ltd., or anyone on its behalf, assumes no responsibility or liability for any damagers resulting from such improper use of sale. This publication supersedes & replaces all information reviously supplied. For additional information, please visit our website http://www.takcheong.com, or consult your nearest Tak Cheong’s sales office for further assistance. Number: DB-100 April 14, 2008 / A
TCMM5Z3V3 价格&库存
很抱歉,暂时无法提供与“TCMM5Z3V3”相匹配的价格&库存,您可以联系我们找货
TCMM5Z3V3
  • 20+0.13565
  • 200+0.10563
  • 600+0.08900
库存:2527
