MM5Z5V6
MM5Z5V6
    GOODWORK(固得沃克)
    SOD-523(SC-79)
    ZENER齐纳二极管广泛用于电源电路,用于稳压和过压保护,电源储能、工控电路、通讯设备、智能控制
MM5Z5V6 数据手册
MM5Z2V0~MM5Z75 SILICON PLANAR ZENER DIODES ∠ ALL ROUND     A Features         C     • Standard Zener Breakdown Voltage Range         HE   2.0 V to 75 V D • Steady State Power Rating of 200 mW   2 Anode E Cathode   bp DESCRIPTION 1 A     PINNING PIN                           1 2 Top View   Simplified outline SOD-523 and symbol UNIT mm Absolute Maximum Ratings (Ta = 25 OC) Parameter Total Device Dissipaton Junction and Storage Temperature Range   A bp C D E HE 0.70 0.60 0.4 0.3 0.135 0.100 1.25 1.15 0.85 0.75 1.7 1.5 ∠ V 0.1 Symbol Value Unit Ptot 200 mW Tj , Tstg - 65 to + 150 Symbol Max. Unit VF 0.9 V O   5 O C Characteristics at Ta = 25 OC Parameter Forward Voltage at IF = 10 mA REV 1.0 2020 JAN PAGE:1/3 MM5Z2V0~MM5Z75 Zener Impedance Zener Voltage 1) Type Marking Code VZT (V) at lZT ZZT ZZK Leakage Current at IZK IR at VR Min. Nom. Max. mA Ω Ω mA µA V - - 120 0.5 MM5Z2V0 WY 1.8 2.0 2.15 5 100 MM5Z2V2 RE 2.08 2.2 2.33 5 100 - - 120 0.7 MM5Z2V4 00 2.2 2.4 2.6 5 100 1000 1 120 1 MM5Z2V7 01 2.5 2.7 2.9 5 100 1000 1 120 1 MM5Z3V0 02 2.8 3.0 3.2 5 100 1000 1 50 1 MM5Z3V3 05 3.1 3.3 3.5 5 95 1000 1 20 1 MM5Z3V6 06 3.4 3.6 3.8 5 90 1000 1 10 1 MM5Z3V9 07 3.7 3.9 4.1 5 90 1000 1 5 1 MM5Z4V3 08 4 4.3 4.6 5 90 1000 1 5 1 MM5Z4V7 09 4.4 4.7 5 5 80 800 1 2 1 MM5Z5V1 0A 4.8 5.1 5.4 5 60 500 1 2 1.5 MM5Z5V6 0C 5.2 5.6 6 5 40 200 1 1 2.5 MM5Z6V2 0E 5.8 6.2 6.6 5 10 100 1 1 3 MM5Z6V8 0F 6.4 6.8 7.2 5 15 160 1 0.5 3.5 MM5Z7V5 0G 7 7.5 7.9 5 15 160 1 0.5 4 MM5Z8V2 0H 7.7 8.2 8.7 5 15 160 1 0.5 5 MM5Z9V1 0K 8.5 9.1 9.6 5 15 160 1 0.5 6 MM5Z10 0L 9.4 10 10.6 5 20 160 1 0.1 7 MM5Z11 0M 10.4 11 11.6 5 20 160 1 0.1 8 MM5Z12 0N 11.4 12 12.7 5 25 80 1 0.1 9 MM5Z13 0P 12.4 13 14.1 5 30 80 1 0.1 10 MM5Z15 0T 14.3 15 15.8 5 30 80 1 0.1 11 MM5Z16 0U 15.3 16 17.1 2 40 80 1 0.1 12 MM5Z18 0W 16.8 18 19.1 2 45 80 1 0.1 13 MM5Z20 0Z 18.8 20 21.2 2 55 100 1 0.1 15 MM5Z22 10 20.8 22 23.3 2 55 100 1 0.1 17 MM5Z24 11 22.8 24 25.6 2 70 120 1 0.1 19 MM5Z27 12 25.1 27 28.9 2 80 300 1 0.1 21 MM5Z30 14 28 30 32 2 80 300 1 0.1 23 MM5Z33 18 31 33 35 2 80 300 1 0.1 25 MM5Z36 19 34 36 38 2 90 500 1 0.1 27 MM5Z39 20 37 39 41 2 130 500 1 2 30 MM5Z43 21 40 43 46 1 150 500 1 2 33 MM5Z47 1A 44 47 50 1 170 500 1 2 36 MM5Z51 1C 48 51 54 1 180 500 1 1 39 MM5Z56 1D 52 56 60 1 200 500 1 1 43 MM5Z62 1E 58 62 66 1 215 500 1 0.2 47 MM5Z68 1F 64 68 72 1 240 500 1 0.2 52 MM5Z75 1G 70 75 79 1 255 500 1 0.2 57 1) Tested with pulses tp = 20 ms. REV 1.0 2020 JAN PAGE:2/3 RATING AND VHARACTERISTIC CURVES( MM5Z 2V0 THRU MM5Z 75 ) Power Dissipation: Ptot (mW) 300 200 100 0 0 25 100 150 Ambient Temperature: Ta ( C) O Derating Curve REV 1.0 2020 JAN PAGE:3/3
MM5Z5V6 价格&库存
很抱歉,暂时无法提供与“MM5Z5V6”相匹配的价格&库存,您可以联系我们找货
MM5Z5V6
  • 50+0.11286
  • 500+0.08794
  • 3000+0.07408
  • 6000+0.06577
  • 30000+0.05859
  • 45000+0.05468
库存:2634
