BZX584C4V7
BZX584C4V7
    MSKSEMI(美森科)
    SOD-523(SC-79)
    ESD(静电放电)、TVS(瞬态电压抑制器)、TSS(半导体放电管)、MOV(压敏电阻)、GDT(气体放电管)、PLED(保护发光二极管)
BZX584C4V7 数据手册
BZX584C2V4-BZX584C43 Product specification BZX584C2V4-BZX584C43 Reference News FEATURES  Planar Die Construction  150mW Power Dissipation  Zener Voltages from 2.4V - 39V  Ultra-Small Surface Mount Package Power PACKAGE OUTLINE Dissipation PIN CONFIGURATION SOD-523 Maximum Ratings(Ta=25 ℃ unless otherwise specified) Characteristic Symbol Value Unit VF 0.9 V Power Dissipation PD 150 mW Thermal Resistance from Junction to Ambient Rθ JA 833 ℃/W Junction Temperature Tj 150 ℃ Storage Temperature Tstg Forward Voltage @IF=10mA Copyright© Msksemi Incorporated -55~+150 ℃ www.msksemi.com BZX584C2V4-BZX584C43 ELECTRICAL CHARACTERISTICS T a =25 unless otherwise specified Maximum Zener Impedance Zener Voltage Range (Note 2) Type Type Number Code VZ@ IZT Maximum Typical temperature Reverse coefficient Current @ IZT (Note 3) IZT Nom(V) Min(V) Max(V) (mA) ZZT@ IZT ZZK@ IZK (Ω) mV/°C IR VR (mA) (μA) (V) Min Max BZX584C2V4 Z11 2.4 2.20 2.60 5 100 600 1.0 50 1.0 -3.5 0 BZX584C2V7 Z12 2.7 2.5 2.9 5 100 600 1.0 20 1.0 -3.5 0 BZX584C3V0 Z13 3.0 2.8 3.2 5 95 600 1.0 10 1.0 -3.5 0 BZX584C3V3 Z14 3.3 3.1 3.5 5 95 600 1.0 5 1.0 -3.5 0 BZX584C3V6 Z15 3.6 3.4 3.8 5 90 600 1.0 5 1.0 -3.5 0 BZX584C3V9 Z16 3.9 3.7 4.1 5 90 600 1.0 3 1.0 -3.5 0 BZX584C4V3 Z17 4.3 4.0 4.6 5 90 600 1.0 3 1.0 -3.5 0 BZX584C4V7 Z1 4.7 4.4 5.0 5 80 500 1.0 3 2.0 -3.5 0.2 BZX584C5V1 Z2 5.1 4.8 5.4 5 60 480 1.0 2 2.0 -2.7 1.2 BZX584C5V6 Z3 5.6 5.2 6.0 5 40 400 1.0 1 2.0 -2.0 2.5 BZX584C6V2 Z4 6.2 5.8 6.6 5 10 150 1.0 3 4.0 0.4 3.7 BZX584C6V8 Z5 6.8 6.4 7.2 5 15 80 1.0 2 4.0 1.2 4.5 BZX584C7V5 Z6 7.5 7.0 7.9 5 15 80 1.0 1 5.0 2.5 5.3 BZX584C8V2 Z7 8.2 7.7 8.7 5 15 80 1.0 0.7 5.0 3.2 6.2 BZX584C9V1 Z8 9.1 8.5 9.6 5 15 100 1.0 0.5 6.0 3.8 7.0 BZX584C10 Z9 10 9.4 10.6 5 20 150 1.0 0.2 7.0 4.5 8.0 BZX584C11 Y1 11 10.4 11.6 5 20 150 1.0 0.1 8.0 5.4 9.0 BZX584C12 Y2 12 11.4 12.7 5 25 150 1.0 0.1 8.0 6.0 10.0 BZX584C13 Y3 13 12.4 14.1 5 30 170 1.0 0.1 8.0 7.0 11.0 BZX584C15 Y4 15 13.8 15.6 5 30 200 1.0 0.1 10.5 9.2 13.0 BZX584C16 Y5 16 15.3 17.1 5 40 200 1.0 0.1 11.2 10.4 14.0 BZX584C18 Y6 18 16.8 19.1 5 45 225 1.0 0.1 12.6 12.4 16.0 BZX584C20 Y7 20 18.8 21.2 5 55 225 1.0 0.1 14.0 14.4 18.0 BZX584C22 Y8 22 20.8 23.3 5 55 250 1.0 0.1 15.4 16.4 20.0 BZX584C24 Y9 24 22.8 25.6 5 70 250 1.0 0.1 16.8 18.4 22.0 BZX584C27 Y10 27 25.1 28.9 2 80 300 0.5 0.1 18.9 21.4 25.3 BZX584C30 Y11 30 28.0 32.0 2 80 300 0.5 0.1 21.0 24.4 29.4 BZX584C33 Y12 33 31.0 35.0 2 80 325 0.5 0.1 23.1 27.4 33.4 BZX584C36 Y13 36 34.0 38.0 2 90 350 0.5 0.1 25.2 30.4 37.4 BZX584C39 Y14 39 37.0 41.0 2 130 350 0.5 0.1 27.3 33.4 41.2 BZX584C43 Y15 43 40.0 46.0 2 100 700 1 0.1 32 10 12 Notes: 1. Valid provided that device terminals are kept at ambient temperature. 2.Tested with pulses, period=5ms,pulse width =300μs. 3. f = 1 kHz. Copyright© Msksemi Incorporated www.msksemi.com BZX584C2V4-BZX584C43 Zener Characteristics(VZ Up to 10 V) Zener Characteristics(11 V to 43 V) 100 50 43 39 36 33 27 30 10 10 24 9.1 9 1 20 22 8.2 7.5 6.2 6.8 5.1 5.6 4.7 8 PD =150mW 10 11 12 13 IZ, ZENER CURRENT (mA) Pulsed 10 2.4 IZ, ZENER CURRENT (mA) Ta =25℃ PD =150mW Pulsed 15 16 18 Ta =25℃ 1 0.5 1 2 3 4 5 6 7 0.1 10 11 15 20 VZ, ZENER VOLTAGE (V) Temperature Coefficients 45 50 10 25 20 VZ @ IZT 15 10 5 1 0.1 0.01 Ta=100℃ 1E-3 0 Ta=25℃ 0 4 8 12 16 20 24 32 28 36 40 1E-4 44 0 5 VZ, NOMINAL ZENER VOLTAGE (V) 10 15 20 25 30 40 35 45 VZ, NOMINAL ZENER VOLTAGE (V) Effect of Zener Voltage on Zener Impedance Typical Capacitance 1000 1000 Ta=25℃ Ta=25℃ f=1MHz ZZT, DYNAMIC IMPEDANCE(Ω) 100 1V BIAS BIAS AT 50% OF VZ NOM 10 1 10 IZ(AC)=0.1IZ(DC) IZ=1mA 0V BIAS C, CAPACITANCE (pF) 40 Pulsed FOR BZX584CXXX SERIES 30 1 35 TYPICAL Ta VALUES 35 -5 30 Typical Leakage Current 100 IR, LEAKAGE CURRENT (uA) θVZ, TEMPERATURE COEFFICIENT (mV/℃) 40 25 VZ, ZENER VOLTAGE (V) 100 VZ, NOMINAL ZENER VOLTAGE (V) f=1kHz 100 IZ=5mA 10 1 1 10 100 VZ, NOMINAL ZENER VOLTAGE (V) Power Derating Curve 150 POWER DISSIPATION PD (mW) 200 100 50 0 0 25 50 75 AMBIENT TEMPERATURE Copyright© Msksemi Incorporated 100 Ta 125 150 (℃ ) www.msksemi.com BZX584C2V4-BZX584C43 PACKAGE MECHANICAL DATA Symbol A A1 b c D E E1 E2 L 0 Dimensions In Millimeters Min 0.510 0.500 0.250 0.080 0.750 1 100 1.500 0.200 REF 0.010 7° REF Max 0.770 0.700 0.350 0. 150 0.850 1 300 1.700 0.070 Dimensions In Inches Min 0.020 0.020 0.010 0.003 0.030 0 043 0.059 0.008 REF 0.001 7 ° REF Max 0.031 0.028 0.014 0.006 0.033 0 051 0.067 0.003 Suggested Pad Layout Note: 1.Controlling dimension:in millimeters. 2.General tolerance:±0.05mm. 3.The pad layout is for reference purposes only. REEL SPECIFICATION P/N PKG QTY BZX584C2V4-BZX584C43 SOD-523 3000 Copyright© Msksemi Incorporated www.msksemi.com BZX584C2V4-BZX584C43 Attention ■ Any and all MSKSEMI Semiconductor products described or contained herein do not handle applications that require extremely high levels of reliability, such as life-support have specifications that can systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you before using any MSKSEMI Semiconductor products described or contained herein in such applications. ■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein. ■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment. ■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design. ■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from theauthorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of MSKSEMI Semiconductor. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI Semiconductor productthat you intend to use. Copyright© Msksemi Incorporated www.msksemi.com
BZX584C4V7 价格&库存
很抱歉,暂时无法提供与“BZX584C4V7”相匹配的价格&库存,您可以联系我们找货
BZX584C4V7
  • 50+0.11494
  • 500+0.09015
  • 1500+0.07638
  • 8000+0.06537
  • 24000+0.05821
  • 48000+0.05435
库存:2821
