� �D�
宏迦橙
BAS516
FAST SWITHING DIODES
www.ichjc.com
Features
SOD-523
•VR=75V
•IF(AV)=250mA
•Power Dissipation of 150mW
•Fast switching speed
•Meets MSL level 1, per J-STD-020, LF maximum peak of 260℃
Applications
For use in low voltage high frequency circuit signals.
Mechanical Data
•Case: SOD-523
Molding compound meets UL 94V-0 flammability rating, RoHS-compliant,
halogen-free
•Terminals: Solder plated, solderable per MIL-STD-750,Method 2026
•Polarity: Cathode line denotes the cathode end
Maximum Ratings (Ta=25℃ Unless otherwise specified)
PARAMETER
SYMBOL
UNIT
VALUE
Maximum repetitive peak reverse voltage
VRRM
V
75
Reverse Breakdown voltage @IR=100μA
V(BR)R
Repetitive peak forward current
IFRM
Non-Repetitive Peak Reverse Voltage
VRM
Maximum RMS Voltage
VRMS
Maximum Average Forward Rectified Current
Non-Repetitive Peak forward surge current @tp=1.0μs
Non-Repetitive Peak forward surge current @tp=1.0s
Power Dissipation
IFSM
A
Pd
mW
Tj
Typical thermal resistance
RθJ-A
Maximum instantaneous forward voltage
TEST CONDITIONS
IF=1mA
IF=10mA
IF=50mA
IF=150mA
Reverse Leakage Current
Total capacitance
Maxinum reverse recovery time
Revision:SD-May.2023-A0
2..0
1.0
150
℃ /W
833
-55 ~+150
SYMBOL
UNIT
VF
V
VR=0V,f=1MHz
CT
1 of 3
500
-55 ~+150
IR1
IF=IR=10mA,Irr=0.1×IR, RL=100Ω
250
VR=25V
VR=75V
75
mA
Electrical Characteristics (Ta=25℃ Unless otherwise specified)
PARAMETER
75
V
mA
Tstg
100
V
IF(AV)
Storage temperature
Junction temperature
V
nA
IR2
μA
Trr
ns
Zhuhai Hongjiacheng Technology co., Ltd
pF
Min
Max
0.715
1.00
0.855
1.25
30.0
1.0
1.0
4.0
www.ichjc.com
� �D�
宏迦橙
BAS516
www.ichjc.com
Ratings And Characteristics Curves (Ta=25℃ Unless otherwise specified)
1000
100
10000
1000
Ta=100°C
10
Ta=100°C
REVERSECURRENTI(nA)
R
FORWARDCURRENTIF(mA)
100
Ta=25°C
100
1
Ta=25°C
10
0.1
0.01
0.0
0.2
0.4
0.6
0.8
1.0
FORWARDVOLTAGEVF(V)
1
1.2
Fig.1 Typical Instaneous Forward Characteristics
1.1
200
Ta=25℃
f=1MHz
CAPACITANCEBETWEENTERMINALSCT(pF)
75
50
Fig.2 Typical Reverse Characteristics
1.0
POWERDISSIPATIONP(mW)
D
150
0.9
100
0.8
0.7
25
REVERSEVOLTAGEVR(V)
50
10
REVERSEVOLTAGEVR(V)
15
Fig.3 Typical Junction Capacitance
50
75
100
AMBIENTTEMPERATURETa(℃)
125
150
Fig.4 Power Derating Curve
2 of 3
www.ichjc.com
� �D�
宏迦橙
BAS516
www.ichjc.com
Ordering Information
PACKAGE
PACKAGE CODE
UNIT WEIGHT(g)
REEL(pcs)
BOX(pcs)
CARTON(pcs)
DELIVERY MODE
SOD-523
R1
0.002
3000
45000
180000
7"
Package Outline Dimensions (SOD-523)
Symbol
CathodeBand
B E
A
D
F
C
Dimensions
Millimeters
A
Min
1.10
Max
1.30
0.044
0.052
B
0.25
0.35
0.01
0.014
C
1.50
1.70
0.06
0.068
D
0.50
0.70
0.02
0.028
E
0.70
0.90
0.028
0.036
F
0.05
0.20
0.002
0.008
Suggested Pad Layout
J
K
J
Symbol
M
J
K
M
3 of 3
Dimensions
Millimeters
Min.
Max.
1.10
0.60
0.80
Min
Inches
Min.
0.023
0.031
Inches
Max
Max.
0.042
www.ichjc.com
很抱歉,暂时无法提供与“BAS516”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.10217
- 500+0.08435
- 3000+0.07355
- 6000+0.06761
- 24000+0.06243
- 51000+0.05962
