� �D�
宏迦橙
1SS400
FAST SWITHING DIODES
www.ichjc.com
Features
SOD-523
•VR=80V
•IF(AV)=100mA
•Power Dissipation of 150mW
•Fast switching speed
•Meets MSL level 1, per J-STD-020, LF maximum peak of 260℃
Applications
For use in low voltage high frequency circuit signals.
Mechanical Data
•Case: SOD-523
Molding compound meets UL 94V-0 flammability rating, RoHS-compliant,
halogen-free
•Terminals: Solder plated, solderable per MIL-STD-750,Method 2026
•Polarity: Cathode line denotes the cathode end
Maximum Ratings (Ta=25℃ Unless otherwise specified)
PARAMETER
SYMBOL
UNIT
VALUE
Maximum repetitive peak reverse voltage
VRRM
V
80
Reverse Breakdown voltage @IR=100μA
V(BR)R
Forward Continuous Current
IFM
Non-Repetitive Peak Reverse Voltage
VRM
Maximum RMS Voltage
V
VRMS
Maximum Average Forward Rectified Current
90
V
80
V
80
IF(AV)
mA
100
Non-repetitive Peak Forward Surge Current @ t=8.3ms Halfsine wave
IFSM
A
2.0
Storage temperature
Tstg
Typical thermal resistance
RθJ-A
Power Dissipation
Junction temperature
mA
Pd
mW
Tj
225
150
-55 ~+150
℃ /W
833
150
Electrical Characteristics (Ta=25℃ Unless otherwise specified)
PARAMETER
TEST CONDITIONS
SYMBOL
UNIT
Min
Max
Reverse Leakage Current
VR=80V
IR
μA
0.1
Trr
ns
Maximum instantaneous forward voltage
Total capacitance
Maxinum reverse recovery time
Revision:SD-May.2023-A0
IF=100mA
VR=0V,f=1MHz
IF=IR=10mA,Irr=0.1×IR,
RL=100Ω
1 of 3
VF
CT
Zhuhai Hongjiacheng Technology co., Ltd
V
pF
1.2
3.0
4.0
www.ichjc.com
� �D�
宏迦橙
1SS400
www.ichjc.com
Ratings And Characteristics Curves (Ta=25℃ Unless otherwise specified)
100
1000
REVERSECURRENTI(nA)
R
10
FORWARDCURRENTIF(mA)
Ta=100°C
Ta=100°C
Ta=25°C
100
1
0.1
0.01
Ta=25°C
10
0.0
0.2
0.4
0.6
0.8
1.0
FORWARDVOLTAGEVF(V)
1
1.2
Fig.1 Typical Instantaneous Forward Characterics
1.2
60
80
200
Ta=25℃
f=1MHz
CAPACITANCEBETWEENTERMINALSCT(pF)
40
REVERSEVOLTAGEVR(V)
Fig.2 Typical Reverse Characteristics
1.1
POWERDISSIPATIONP(mW)
D
150
1.0
100
0.9
0.8
10
REVERSEVOLTAGEVR(V)
15
Fig.3 Typical Junction Capacitance
50
75
100
AMBIENTTEMPERATURETa(℃)
125
150
Fig.4 Power Derating Curve
2 of 3
www.ichjc.com
� �D�
宏迦橙
1SS400
www.ichjc.com
Ordering Information
PACKAGE
PACKAGE CODE
UNIT WEIGHT(g)
REEL(pcs)
BOX(pcs)
CARTON(pcs)
DELIVERY MODE
SOD-523
R1
0.002
3000
45000
180000
7"
Package Outline Dimensions (SOD-523)
Symbol
CathodeBand
B E
A
D
F
C
Dimensions
Millimeters
A
Min
1.10
Max
1.30
0.044
0.052
B
0.25
0.35
0.01
0.014
C
1.50
1.70
0.06
0.068
D
0.50
0.70
0.02
0.028
E
0.70
0.90
0.028
0.036
F
0.05
0.20
0.002
0.008
Suggested Pad Layout
J
K
J
Symbol
M
J
K
M
3 of 3
Dimensions
Millimeters
Min.
Max.
1.10
0.60
0.80
Min
Inches
Min.
0.023
0.031
Inches
Max
Max.
0.042
www.ichjc.com
很抱歉,暂时无法提供与“1SS400”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.09861
- 50+0.08154
- 150+0.07204
- 500+0.06642
- 3000+0.06146
- 6000+0.05876
