MM5Z20V
MM5Z20V
    XCH(旭昌辉)
    SOD-523(SC-79)
    耐压:20V 电流:0.05UA@14V
MM5Z20V 数据手册
MM5Z2V0 THRU MM5Z75V Zener Voltage Regulators Specification Features: ƒ ƒ ƒ ƒ ƒ ƒ ƒ ƒ Absolute Maximum Ratings Symbol Flat Lead SOD-523 Small Outline Plastic Package Extremely Small SOD-523 Package Surface Device Type Mounting RoHS Compliant Green EMC Matte Tin(Sn) Lead Finish Band Indicates Cathode TA = 25°C unless otherwise noted Parameter Power Dissipation Value Units 200 mW TSTG Storage Temperature Range -55 to +150 °C TOPR Operating Temperature Range -55 to +150 °C PD Wide Zener Voltage Range Selection, 2.0V to 75V These ratings are limiting values above which the serviceability of the diode may be impaired. Electrical Characteristics Device Type MM5Z2V0 MM5Z2V2 MM5Z2V4 MM5Z2V7 MM5Z3V0 MM5Z3V3 MM5Z3V6 MM5Z3V9 MM5Z4V3 MM5Z4V7 MM5Z5V1 MM5Z5V6 MM5Z6V2 MM5Z6V8 MM5Z7V5 MM5Z8V2 MM5Z9V1 MM5Z10V MM5Z11V MM5Z12V MM5Z13V MM5Z15V MM5Z16V Device Marking 5± 5⊥ 50 51 52 53 54 55 56 57 58 59 5A 5B 5C 5D 5E 5F 5G 5H 5J 5K 5L TA = 25°C unless otherwise noted VZ @ IZT (Volts) Min Nom Max 1.90 2.09 2.2 2.5 2.8 3.1 3.4 3.7 4.0 4.4 4.8 5.2 5.8 6.4 7.0 7.7 8.5 9.4 10.4 11.4 12.4 14.3 15.3 2.0 2.2 2.4 2.7 3.0 3.3 3.6 3.9 4.3 4.7 5.1 5.6 6.2 6.8 7.5 8.2 9.1 10 11 12 13 15 16 2.10 2.31 2.6 2.9 3.2 3.5 3.8 4.1 4.6 5.0 5.4 6.0 6.6 7.2 7.9 8.7 9.6 10.6 11.6 12.7 14.1 15.8 17.1 IZT (mA) ZZT @ IZT (Ω) Max IZK (mA) ZZK @ IZK (Ω) Max IR @ VR (μA) Max VR (Volts) 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 100 100 100 100 100 95 90 90 90 80 60 40 10 15 15 15 15 20 20 25 30 30 40 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 564 564 1000 1000 1000 1000 1000 1000 1000 800 500 200 100 160 160 160 160 160 160 80 80 80 80 120 120 50 20 10 5 5 3 3 3 2 1 3 2 1 0.7 0.2 0.1 0.1 0.1 0.1 0.05 0.05 0.5 0.7 1 1 1 1 1 1 1 2 2 2 4 4 5 5 7 8 8 8 8 10.5 11.2 Page 1 of 4 MM5Z2V0 THRU MM5Z75V Electrical Characteristics Device Type Device Marking TA = 25°C unless otherwise noted VZ @ IZT (Volts) Min Nom Max MM5Z18V 5M 16.8 18 19.1 MM5Z20V 5N 18.8 20 21.2 MM5Z22V 5P 20.8 22 23.3 MM5Z24V 5R 22.8 24 25.6 MM5Z27V 5S 25.1 27 28.9 MM5Z30V 5T 28 30 32 MM5Z33V 5U 31 33 35 MM5Z36V 5V 34 36 38 MM5Z39V 5X 37 39 41 MM5Z43V 5Y 40 43 46 MM5Z47V 5Z 44 47 50 MM5Z51V 5− 48 51 54 MM5Z56V 5= 52 56 60 58 62 66 MM5Z62V 5≡ MM5Z68V 5> 64 68 72 MM5Z75V 5< 70 75 79 VF Forward Voltage = 1 V Maximum @ IF = 10 mA for all types Notes: 1. 2. 3. IZT (mA) ZZT @ IZT (Ω) Max IZK (mA) ZZK @ IZK (Ω) Max IR @ VR (μA) Max VR (Volts) 5 5 5 5 2 2 2 2 2 2 2 2 2 2 2 2 45 55 55 70 80 80 80 90 130 150 170 180 200 215 240 255 1 1 1 1 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 80 100 100 120 300 300 300 500 500 500 500 500 500 500 500 500 0.05 0.05 0.05 0.05 0.05 0.05 0.05 0.05 0.05 0.05 0.05 0.05 0.05 0.05 0.05 0.05 12.6 14 15.4 16.8 18.9 21 23.2 25.2 27.3 30.1 32.9 35.7 39.2 43.4 47.6 52.5 The Zener Voltage (VZ) is tested under pulse condition of 10mS. For detailed information on price, availability and delivery of nominal zener voltages between the voltages shown and tighter voltage tolerances, contact your nearest Tak Cheong Electronics representative. The zener impedance is derived from the 60-cycle ac voltage, which results when an ac current having an rms value equal to 10% of the dc zener current (IZT or IZK) is superimposed to IZT or IZK. Page 2 of 4 MM5Z2V0 THRU MM5Z75V RATING AND CHARACTERISTIC CURVES Fig.2 EFFECT OF ZENER VOLTAGE ON ZENER IMPEDANCE Fig.1 TYPICAL FORWARD VOLTAGE POWER PASSIPATION,mW 250 200 150 100 50 0 0 25 50 75 100 125 150 175 200 TEMPERATURE [℃ ] Fig.3 POWER DISSIPATION VS. AMBIENT TEMP. Fig.5 ZENER BREAKDOWN CHARACTERISTICS Fig.4 TYPICAL CAPACITANCE Fig.6 ZENER BREAKDOWN CHARACTERISTICS Page 3 of 4 MM5Z2V0 THRU MM5Z75V Fig.7 TYPICAL LEAKGE CURRENT Flat Lead SOD-523 Package Outline Note: Dimensions are exclusive of Burrs, Mold Flash & Tie Bar extrusions. Page 4 of 4
MM5Z20V 价格&库存
很抱歉,暂时无法提供与“MM5Z20V”相匹配的价格&库存,您可以联系我们找货
MM5Z20V
  • 20+0.14872
  • 200+0.11664
  • 600+0.09882
  • 3000+0.08813
  • 9000+0.07884
  • 21000+0.07388
库存:1965
