BZX584B15
BZX584B15
    SLKOR(萨科微)
    SOD-523(SC-79)
    独立式 耐压:15V
BZX584B15 数据手册
BZX584B2V4-BZX584B39 Plastic-Encapsulate Diode ZENER DIODE PINNING DESCRIPTION PIN FEATURES z Planar Die Construction z 150mW Power Dissipation z Zener Voltages from 2.4 – 39V 1 Cathode 2 Anode   1 2       Top View Simplified outline SOD-523 and symbol SOD-523 MAXIMUM RATINGS(Ta=25℃ unless otherwise specified ) Characteristic Symbol Value Unit VF 0.9 V PD 150 mW RθJA 833 ℃/W JunctionTemperature TJ 150 ℃ Storage Temperature TSTG Forward Voltage @IF=10mA Power Dissipation (Note 1) Thermal Resistance from Junction to Ambient www.slkormicro.com 1 -55~+150  ℃ BZX584B2V4-BZX584B39 ELECTRICAL CHARACTERISTICS Ta=25℃ unless otherwise specified Typical Maximum Zener Impedance (Note 3) Zener Voltage Range (Note 2) Type Number Type Code Maximum Reverse Current Temperature Coefficent @IZT=5 mA mV/°C VZ@IZT IZT Nom(V) Min(V) Max(V) mA ZZT@IZT ZZK@IZK Ω IZK IR VR mA μA V Min Max BZX584B2V4 2V1 2.4 2.35 2.45 5 100 600 1.0 50 1.0 -3.5 0 BZX584B2V7 2V2 2.7 2.65 2.75 5 100 600 1.0 20 1.0 -3.5 0 BZX584B3V0 2V3 3 2.94 3.06 5 95 600 1.0 10 1.0 -3.5 0 BZX584B3V3 2V4 3.3 3.23 3.37 5 95 600 1.0 5 1.0 -3.5 0 BZX584B3V6 2V5 3.6 3.53 3.67 5 90 600 1.0 5 1.0 -3.5 0 BZX584B3V9 2V6 3.9 3.82 3.98 5 90 600 1.0 3 1.0 -3.5 0 BZX584B4V3 2V7 4.3 4.21 4.39 5 90 600 1.0 3 1.0 -3.5 0 BZX584B4V7 2Z1 4.7 4.61 4.79 5 80 500 1.0 3 2.0 -3.5 0.2 BZX584B5V1 2Z2 5.1 5.00 5.20 5 60 480 1.0 2 2.0 -2.7 1.2 BZX584B5V6 2Z3 5.6 5.49 5.71 5 40 400 1.0 1 2.0 -2.0 2.5 BZX584B6V2 2Z4 6.2 6.08 6.32 5 10 150 1.0 3 4.0 0.4 3.7 BZX584B6V8 2Z5 6.8 6.66 6.94 5 15 80 1.0 2 4.0 1.2 4.5 BZX584B7V5 2Z6 7.5 7.35 7.65 5 15 80 1.0 1 5.0 2.5 5.3 BZX584B8V2 2Z7 8.2 8.04 8.36 5 15 80 1.0 0.7 5.0 3.2 6.2 BZX584B9V1 2Z8 9.1 8.92 9.28 5 15 100 1.0 0.5 6.0 3.8 7.0 BZX584B10 2Z9 10 9.80 10.20 5 20 150 1.0 0.2 7.0 4.5 8.0 BZX584B11 2Y1 11 10.78 11.22 5 20 150 1.0 0.1 8.0 5.4 9.0 BZX584B12 2Y2 12 11.76 12.24 5 25 150 1.0 0.1 8.0 6.0 10.0 BZX584B13 2Y3 13 12.74 13.26 5 30 170 1.0 0.1 8.0 7.0 11.0 BZX584B15 2Y4 15 14.70 15.30 5 30 200 1.0 0.1 10.5 9.2 13.0 BZX584B16 2Y5 16 15.68 16.32 5 40 200 1.0 0.1 11.2 10.4 14.0 BZX584B18 2Y6 18 17.64 18.36 5 45 225 1.0 0.1 12.6 12.4 16.0 BZX584B20 2Y7 20 19.60 20.40 5 55 225 1.0 0.1 14.0 14.4 18.0 BZX584B22 2Y8 22 21.56 22.44 5 55 250 1.0 0.1 15.4 16.4 20.0 BZX584B24 2Y9 24 23.52 24.48 5 70 250 1.0 0.1 16.8 18.4 22.0 BZX584B27 2X1 27 26.46 27.54 2 80 300 0.5 0.1 18.9 21.4 25.3 BZX584B30 2X2 30 29.40 30.60 2 80 300 0.5 0.1 21.0 24.4 29.4 BZX584B33 2X3 33 32.34 33.66 2 80 325 0.5 0.1 23.1 27.4 33.4 BZX584B36 2X4 36 35.28 36.72 2 90 350 0.5 0.1 25.2 30.4 37.4 BZX584B39 2X5 39 38.22 39.78 2 130 350 0.5 0.1 27.3 33.4 41.2 Notes: 1. Valid provided that device terminals are kept at ambient temperature. 2. Tested with pulses, period=5ms,pulse width =300μs. 3. f=1kHz. www.slkormicro.com 2 BZX584B2V4-BZX584B39 Typical Characteristics Notes: Our company currently provide 5.1 V - 20 V products only Zener Characteristics(VZ 5.1V to 20 V) θVZ, TEMPERATURE COEFFICIENT (mV/℃) Ta =25℃ Pulsed PD =150mW 20 18 16 15 13 11 12 10 9.1 7.5 8.2 6.2 6.8 5.1 10 5.6 IZ, ZENER CURRENT (mA) Temperature Coefficients 20 100 1 0.5 TYPICAL Ta VALUES FOR BZX584BXXX SERIES 15 VZ @ IZT 10 5 0 4 6 8 10 12 14 16 18 20 22 4 6 8 VZ, ZENER VOLTAGE (V) 12 14 16 18 20 22 Typical Capacitance Typical Leakage Current 0.1 10 VZ, NOMINAL ZENER VOLTAGE (V) 1000 Ta=25℃ Pulsed C, CAPACITANCE (pF) IR, LEAKAGE CURRENT (uA) f=1MHz 0.01 Ta=100℃ 1E-3 0V BIAS 100 1V BIAS 10 BIAS AT 50% OF VZ NOM Ta=25℃ 1E-4 1 4 6 8 10 12 14 16 18 20 22 4 6 8 10 12 14 16 18 20 22 VZ, NOMINAL ZENER VOLTAGE (V) VZ, NOMINAL ZENER VOLTAGE (V) Power Derating Curve Effect of Zener Voltage on Zener Impedance 1000 200 Ta=25℃ (mW) f=1kHz 150 PD 100 10 POWER DISSIPATION ZZT, DYNAMIC IMPEDANCE(Ω) IZ(AC)=0.1IZ(DC) IZ=5mA 100 50 IZ=1mA 1 0 4 6 8 10 12 14 16 18 20 22 VZ, NOMINAL ZENER VOLTAGE (V) www.slkormicro.com 0 25 50 75 AMBIENT TEMPERATURE 3 100 Ta 125 (℃ ) 150 BZX584B2V4-BZX584B39 PACKAGE OUTLINE Plastic surface mounted package; 2 leads SOD-523 Dimension in Millimeters Symbol www.slkormicro.com Min Max A 0.60 0.70 A1 0 0.05 B 0.75 0.85 bp 0.25 0.40 C 0.09 0.15 E 1.15 1.25 HE 1.50 1.70 4
BZX584B15 价格&库存
很抱歉,暂时无法提供与“BZX584B15”相匹配的价格&库存,您可以联系我们找货
BZX584B15
  • 20+0.09111
  • 200+0.07226
  • 600+0.06176
  • 2000+0.05541
  • 8000+0.04996
  • 16000+0.04705
库存:172
