MM5Z2V0 THRU MM5Z75V
Zener Voltage Regulators
Specification Features:
Absolute Maximum Ratings
Symbol
Flat Lead SOD-523 Small Outline Plastic Package
Extremely Small SOD-523 Package
Surface Device Type Mounting
RoHS Compliant
Green EMC
Matte Tin(Sn) Lead Finish
Band Indicates Cathode
TA = 25°C unless otherwise noted
Parameter
Power Dissipation
Value
Units
200
mW
TSTG
Storage Temperature Range
-55 to +150
°C
TOPR
Operating Temperature Range
-55 to +150
°C
PD
Wide Zener Voltage Range Selection, 2.0V to 75V
These ratings are limiting values above which the serviceability of the diode may be impaired.
Electrical Characteristics
Device
Type
MM5Z2V0
MM5Z2V2
MM5Z2V4
MM5Z2V7
MM5Z3V0
MM5Z3V3
MM5Z3V6
MM5Z3V9
MM5Z4V3
MM5Z4V7
MM5Z5V1
MM5Z5V6
MM5Z6V2
MM5Z6V8
MM5Z7V5
MM5Z8V2
MM5Z9V1
MM5Z10V
MM5Z11V
MM5Z12V
MM5Z13V
MM5Z15V
MM5Z16V
Device
Marking
5±
5⊥
50
51
52
53
54
55
56
57
58
59
5A
5B
5C
5D
5E
5F
5G
5H
5J
5K
5L
VZ @ IZT
(Volts)
Min
Nom
Max
1.90
2.09
2.2
2.5
2.8
3.1
3.4
3.7
4.0
4.4
4.8
5.2
5.8
6.4
7.0
7.7
8.5
9.4
10.4
11.4
12.4
14.3
15.3
2.0
2.2
2.4
2.7
3.0
3.3
3.6
3.9
4.3
4.7
5.1
5.6
6.2
6.8
7.5
8.2
9.1
10
11
12
13
15
16
2.10
2.31
2.6
2.9
3.2
3.5
3.8
4.1
4.6
5.0
5.4
6.0
6.6
7.2
7.9
8.7
9.6
10.6
11.6
12.7
14.1
15.8
17.1
IZT
(mA)
ZZT @ IZT
(Ω)
Max
IZK
(mA)
ZZK @ IZK
(Ω)
Max
IR @ VR
(μA)
Max
VR
(Volts)
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
100
100
100
100
100
95
90
90
90
80
60
40
10
15
15
15
15
30
30
40
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
564
564
1000
1000
1000
1000
1000
1000
1000
800
500
200
100
160
160
160
160
160
160
80
80
80
80
120
120
50
5
5
3
3
3
2
1
3
2
1
0.7
0.2
0.1
0.1
0.1
0.1
0.05
0.05
0.5
0.7
1
1
1
1
1
1
1
2
2
2
4
4
5
5
7
8
8
8
8
10.5
11.2
Page 1 of 4
Device
Type
Device
Marking
VZ @ IZT
(Volts)
Min
Nom
Max
MM5Z18V
5M
16.8
18
19.1
MM5Z20V
5N
18.8
MM5Z22V
5P
20.8
22
23.3
MM5Z24V
5R
22.8
24
25.6
MM5Z27V
5S
25.1
27
28.9
MM5Z30V
5T
28
30
32
MM5Z33V
5U
31
33
35
MM5Z36V
5V
34
36
38
MM5Z39V
5X
37
39
41
MM5Z43V
5Y
40
43
46
MM5Z47V
5Z
44
47
50
MM5Z51V
5−
48
51
54
MM5Z56V
5=
52
56
60
58
62
66
MM5Z62V
5≡
MM5Z68V
5>
64
68
72
MM5Z75V
5<
70
75
79
VF Forward Voltage = 1 V Maximum @ IF = 10 mA for all types
Notes:
1.
2.
3.
IZT
(mA)
ZZT @ IZT
(Ω)
Max
IZK
(mA)
ZZK @ IZK
(Ω)
Max
IR @ VR
(μA)
Max
VR
(Volts)
5
5
5
5
2
2
2
2
2
2
2
2
2
2
2
2
45
55
55
70
80
80
80
90
130
150
170
180
200
215
240
255
1
1
1
1
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
80
100
100
120
300
300
300
500
500
500
500
500
500
500
500
500
0.05
0.05
0.05
0.05
0.05
0.05
0.05
0.05
0.05
0.05
0.05
0.05
0.05
0.05
0.05
0.05
12.6
14
15.4
16.8
18.9
21
23.2
25.2
27.3
30.1
32.9
35.7
39.2
43.4
47.6
52.5
The Zener Voltage (VZ) is tested under pulse condition of 10mS.
For detailed information on price, availability and delivery of nominal zener voltages between the voltages shown and tighter
voltage tolerances, contact your nearest Tak Cheong Electronics representative.
The zener impedance is derived from the 60-cycle ac voltage, which results when an ac current having an rms value equal to
10% of the dc zener current (IZT or IZK) is superimposed to IZT or IZK.
Page 2 of 4
RATING AND CHARACTERISTIC CURVES
Fig.2 EFFECT OF ZENER VOLTAGE ON ZENER IMPEDANCE
Fig.1 TYPICAL FORWARD VOLTAGE
POWER PASSIPATION,mW
250
200
150
100
50
50
75
100
125
150
175
200
TEMPERATURE [℃ ]
Fig.3 POWER DISSIPATION VS. AMBIENT TEMP.
Fig.5 ZENER BREAKDOWN CHARACTERISTICS
Fig.4 TYPICAL CAPACITANCE
Fig.6 ZENER BREAKDOWN CHARACTERISTICS
Page 3 of 4
Fig.7 TYPICAL LEAKGE CURRENT
Flat Lead SOD-523 Package Outline
Note: Dimensions are exclusive of Burrs, Mold Flash & Tie Bar extrusions.
Page 4 of 4
很抱歉,暂时无法提供与“MM5Z5V1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.17334
- 200+0.14127
- 600+0.12345
- 3000+0.11276
- 9000+0.10347
- 21000+0.09839
