MM5Zxx Series
SOD-523 Plastic-Encapsulate Zener Diode
Features
SOD-523
Low Zener Impedance
300mW; Power Dissipation of 300mW
High Stability and High Reliability
Mechanical Data
3DFNDJH: SOD-523 Small Outline Plastic Package
Polarity: Color band denotes cathode end
Mounting Position: Any
Maximum Ratings & Thermal Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified.)
Parameters
Unit
Symbol
Value
Pd
300 1)
mW
Power Dissipation
Vf
0.9 2)
V
Forward Voltage @IF=10mA
Ts
-55-+150
Storage temperature range
Thermal Resistance, Junction to Ambient
RθJA
390
℃/W
1)
2)
3)
Device mounted on ceramic PCB: 7.6mm x 9.4mm x 0.87mm with pad areas 25mm²
Short duration test pulse used to minimize self-heating effect
f=1KHz
Electrical Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified).
Zener Voltage Range
Maximum Zener
3)
Impedance
Zzt
Zzk
Izk
@Izt
@Izk
mA
Ω
Maximum
Reverse Current
Typical
Temperature
coefficent @
IZTC=mV/℃
Min
Max
Test
Current
IZTC
Device
Marking
Nom(V)
Min(V)
Max(V)
mA
uA
V
MM5Z 2V4
00
2.4
2.2
2.6
5
100
600
1.0
50
1.0
-3.5
MM5Z 2V7
01
2.7
2.5
2.9
5
100
600
1.0
-3.5
MM5Z 3V0
02
3.0
2.8
3.2
5
95
600
1.0
10
1.0
-3.5
MM5Z 3V3
05
3.3
3.1
3.5
5
95
600
1.0
5
1.0
-3.5
MM5Z 3V6
06
3.6
3.4
3.8
5
90
600
1.0
5
1.0
-3.5
MM5Z 3V9
07
3.9
3.7
4.1
5
90
600
1.0
3
1.0
-3.5
MM5Z 4V3
08
4.3
4.0
4.6
5
90
600
1.0
3
1.0
-3.5
MM5Z 4V7
09
4.7
4.4
5.0
5
80
500
1.0
3
2.0
-3.5
0.2
5
MM5Z 5V1
0A
5.1
4.8
5.4
5
60
480
1.0
2
2.0
-2.7
1.2
5
MM5Z 5V6
0C
5.6
5.2
6.0
5
40
400
1.0
1
2.0
-2.0
2.5
5
MM5Z 6V2
0E
6.2
5.8
6.6
5
10
150
1.0
3
4.0
0.4
3.7
5
MM5Z 6V8
0F
6.8
6.4
7.2
5
15
80
1.0
2
4.0
1.2
4.5
5
MM5Z 7V5
0G
7.5
7.0
7.9
5
15
80
1.0
1
5.0
2.5
5.3
5
MM5Z 8V2
0H
8.2
7.7
8.7
5
15
80
1.0
0.7
5.0
3.2
6.2
5
MM5Z 9V1
0K
9.1
8.5
9.6
5
15
100
1.0
0.5
6.0
3.8
7.0
5
MM5Z 10
0L
10
9.4
10.6
5
1.0
0.2
7.0
4.5
8.0
5
MM5Z 11
0M
11
10.4
11.6
5
1.0
0.1
8.0
5.4
9.0
5
MM5Z 12
0N
12
11.4
12.7
5
25
150
1.0
0.1
8.0
6.0
10.0
5
MM5Z 13
0P
13
12.4
14.1
5
30
170
1.0
0.1
8.0
7.0
11.0
5
Revision:20170701-P1
Vz@Izt
Izt
ht t p : //
IR
www.lgesemi .c o m
VR
mA
mail:lge@lgesemi.com
MM5Zxx Series
Zener Voltage Range
Device
Marking
Vz@Izt
Izt
Nom(V)
Min(V)
Max(V)
mA
Maximum Zener
Impedance
Zzt
Zzk
Izk
@Izt
@Izk
Ω
mA
Maximum
Reverse Current
IR
VR
uA
V
Typical
Temperature
coefficent @
IZTC=mV/℃
Min
Max
Test
Current
IZTC
mA
MM5Z 15
0T
15
13.8
15.6
5
30
200
1.0
0.1
10.5
9.2
13.0
5
MM5Z 16
0U
16
15.3
17.1
5
40
200
1.0
0.1
11.2
10.4
14.0
5
MM5Z 18
0W
18
16.8
19.1
5
45
225
1.0
0.1
12.6
12.4
16.0
5
MM5Z 20
0Z
21.2
5
55
225
1.0
0.1
14.0
14.4
18.0
5
MM5Z 22
10
22
20.8
23.3
5
55
250
1.0
0.1
15.4
16.4
20.0
5
MM5Z 24
11
24
22.8
25.6
5
70
250
1.0
0.1
16.8
18.4
22.0
5
MM5Z 27
12
27
25.1
28.9
2
80
300
0.5
0.1
18.9
21.4
25.3
2
MM5Z 30
14
30
28.0
32.0
2
80
300
0.5
0.1
21.0
24.4
29.4
2
MM5Z 33
18
33
31.0
35.0
2
80
325
0.5
0.1
23.1
27.4
33.4
2
MM5Z 36
19
36
34.0
38.0
2
90
350
0.5
0.1
25.2
30.4
37.4
2
MM5Z 39
37.0
41.0
2
130
350
0.5
0.1
27.3
33.4
41.2
2
MM5Z 43
21
43
40.0
46.0
2
100
700
1.0
0.1
32.0
10.0
12.0
5
Typical characteristics
Revision:20170701-P2
ht t p : //
www.lgesemi .c o m
MM5Zxx Series
SOD-523 PACKAGE OUTLINE
SOD-523 Suggested Pad Layout
Revision:20170701-P3
ht t p : //
www.lgesemi .c o m
很抱歉,暂时无法提供与“MM5Z13V”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.14818
- 200+0.11621
- 600+0.09850
- 3000+0.08424
- 9000+0.07506
- 21000+0.07010
