MM5Z15V
MM5Z15V
    LGE(鲁光)
    SOD-523(SC-79)
    独立式 耐压:15V 电流:0.1UA@10.5V
MM5Z15V 数据手册
MM5Zxx Series SOD-523 Plastic-Encapsulate Zener Diode Features SOD-523  Low Zener Impedance  300mW; Power Dissipation of 300mW  High Stability and High Reliability Mechanical Data 3DFNDJH: SOD-523 Small Outline Plastic Package Polarity: Color band denotes cathode end Mounting Position: Any  Maximum Ratings & Thermal Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified.) Parameters Unit Symbol Value Pd 300 1) mW Power Dissipation Vf 0.9 2) V Forward Voltage @IF=10mA Ts -55-+150 Storage temperature range ℃ Thermal Resistance, Junction to Ambient RθJA 390 ℃/W 1) 2) 3) Device mounted on ceramic PCB: 7.6mm x 9.4mm x 0.87mm with pad areas 25mm² Short duration test pulse used to minimize self-heating effect f=1KHz Electrical Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified). Zener Voltage Range Maximum Zener 3) Impedance Zzt Zzk Izk @Izt @Izk mA Ω Maximum Reverse Current Typical Temperature coefficent @ IZTC=mV/℃ Min Max Test Current IZTC Device Marking Nom(V) Min(V) Max(V) mA uA V MM5Z 2V4 00 2.4 2.2 2.6 5 100 600 1.0 50 1.0 -3.5 0 5 MM5Z 2V7 01 2.7 2.5 2.9 5 100 600 1.0 20 1.0 -3.5 0 5 MM5Z 3V0 02 3.0 2.8 3.2 5 95 600 1.0 10 1.0 -3.5 0 5 MM5Z 3V3 05 3.3 3.1 3.5 5 95 600 1.0 5 1.0 -3.5 0 5 MM5Z 3V6 06 3.6 3.4 3.8 5 90 600 1.0 5 1.0 -3.5 0 5 MM5Z 3V9 07 3.9 3.7 4.1 5 90 600 1.0 3 1.0 -3.5 0 5 MM5Z 4V3 08 4.3 4.0 4.6 5 90 600 1.0 3 1.0 -3.5 0 5 MM5Z 4V7 09 4.7 4.4 5.0 5 80 500 1.0 3 2.0 -3.5 0.2 5 MM5Z 5V1 0A 5.1 4.8 5.4 5 60 480 1.0 2 2.0 -2.7 1.2 5 MM5Z 5V6 0C 5.6 5.2 6.0 5 40 400 1.0 1 2.0 -2.0 2.5 5 MM5Z 6V2 0E 6.2 5.8 6.6 5 10 150 1.0 3 4.0 0.4 3.7 5 MM5Z 6V8 0F 6.8 6.4 7.2 5 15 80 1.0 2 4.0 1.2 4.5 5 MM5Z 7V5 0G 7.5 7.0 7.9 5 15 80 1.0 1 5.0 2.5 5.3 5 MM5Z 8V2 0H 8.2 7.7 8.7 5 15 80 1.0 0.7 5.0 3.2 6.2 5 MM5Z 9V1 0K 9.1 8.5 9.6 5 15 100 1.0 0.5 6.0 3.8 7.0 5 MM5Z 10 0L 10 9.4 10.6 5 20 150 1.0 0.2 7.0 4.5 8.0 5 MM5Z 11 0M 11 10.4 11.6 5 20 150 1.0 0.1 8.0 5.4 9.0 5 MM5Z 12 0N 12 11.4 12.7 5 25 150 1.0 0.1 8.0 6.0 10.0 5 MM5Z 13 0P 13 12.4 14.1 5 30 170 1.0 0.1 8.0 7.0 11.0 5 Revision:20170701-P1 Vz@Izt Izt ht t p : // IR www.lgesemi .c o m VR mA mail:lge@lgesemi.com MM5Zxx Series Zener Voltage Range Device Marking Vz@Izt Izt Nom(V) Min(V) Max(V) mA Maximum Zener Impedance Zzt Zzk Izk @Izt @Izk Ω mA Maximum Reverse Current IR VR uA V Typical Temperature coefficent @ IZTC=mV/℃ Min Max Test Current IZTC mA MM5Z 15 0T 15 13.8 15.6 5 30 200 1.0 0.1 10.5 9.2 13.0 5 MM5Z 16 0U 16 15.3 17.1 5 40 200 1.0 0.1 11.2 10.4 14.0 5 MM5Z 18 0W 18 16.8 19.1 5 45 225 1.0 0.1 12.6 12.4 16.0 5 MM5Z 20 0Z 20 18.8 21.2 5 55 225 1.0 0.1 14.0 14.4 18.0 5 MM5Z 22 10 22 20.8 23.3 5 55 250 1.0 0.1 15.4 16.4 20.0 5 MM5Z 24 11 24 22.8 25.6 5 70 250 1.0 0.1 16.8 18.4 22.0 5 MM5Z 27 12 27 25.1 28.9 2 80 300 0.5 0.1 18.9 21.4 25.3 2 MM5Z 30 14 30 28.0 32.0 2 80 300 0.5 0.1 21.0 24.4 29.4 2 MM5Z 33 18 33 31.0 35.0 2 80 325 0.5 0.1 23.1 27.4 33.4 2 MM5Z 36 19 36 34.0 38.0 2 90 350 0.5 0.1 25.2 30.4 37.4 2 MM5Z 39 20 39 37.0 41.0 2 130 350 0.5 0.1 27.3 33.4 41.2 2 MM5Z 43 21 43 40.0 46.0 2 100 700 1.0 0.1 32.0 10.0 12.0 5 Typical characteristics Revision:20170701-P2 ht t p : // www.lgesemi .c o m mail:lge@lgesemi.com MM5Zxx Series SOD-523 PACKAGE OUTLINE SOD-523 Suggested Pad Layout Revision:20170701-P3 ht t p : // www.lgesemi .c o m mail:lge@lgesemi.com
MM5Z15V 价格&库存
很抱歉,暂时无法提供与“MM5Z15V”相匹配的价格&库存,您可以联系我们找货
