1N4148WT
1N4148WT
    MSKSEMI(美森科)
    SOD-523(SC-79)
    75V 150MA
1N4148WT 数据手册
www.msksemi.com 1N4148WT Semiconductor Compiance FEATURES Small Package Low Reverse Current Fast Switching Speed Surface Mount Package Ideally Suited for Automatic Insertion     MARKING:T4 T4 SOD-523 MAXIMUM RATINGS ( Ta=25℃ unless otherwise noted ) Symbol Parameter Value Unit 100 V 75 V RMS Reverse Voltage 53 V IO Average Rectified Output Current 150 mA IFM Forward Continuous Current 300 mA IFSM Non-repetitive Peak Forward Surge Current@t= 8.3ms 2 A Power Dissipation 150 mW Thermal Resistance from Junction to Ambient 833 ℃/W Tj Junction Temperature 150 ℃ Tstg Storage Temperature -55~+150 ℃ VRM Non-Repetitive Peak Reverse Voltage VR Reverse Voltage VRRM Peak Repetitive Reverse Voltage VRWM Working Peak Reverse Voltage VR(RMS) PD RΘJA ELECTRICAL CHARACTERISTICS(Ta=25℃ unless otherwise specified) Parameter Symbol Reverse voltage V(BR) Reverse current IR Forward voltage Total capacitance Reverse recovery time VF Ctot trr Test conditions IR=1μA Min Typ Max 75 Unit V VR=75V 1 µA VR=20V 25 nA IF=1mA 0.715 V IF=10mA 0.855 V IF=50mA 1 V IF=150mA 1.25 V VR=0V,f=1MHz 2 pF IF= IR =10mA, Irr=0.1*IR,RL=100Ω 4 ns www.msksemi.com 1N4148WT Semiconductor Forward 200 Characteristics Reverse 1000 Compiance Characteristics 100 (nA) (mA) Ta=100℃ REVERSE CURRENT IR 1 T= a 2 5℃ FORWARD CURRENT IF T= a 1 00 ℃ 10 0.1 0.01 0.0 0.2 0.4 0.6 FORWARD VOLTAGE 0.8 VF 1.0 Ta=25℃ 10 1 1.2 0 40 20 (V) REVERSE VOLTAGE Capacitance Characteristics 1.2 100 60 VR 80 (V) Power Derating Curve 200 Ta=25℃ (mW) 150 PD 1.1 POWER DISSIPATION CAPACITANCE BETWEEN TERMINALS CT (pF) f=1MHz 1.0 0.9 0.8 0 5 10 REVERSE VOLTAGE 15 VR (V) 20 100 50 0 0 25 50 75 AMBIENT TEMPERATURE 100 Ta 125 150 (℃ ) www.msksemi.com 1N4148WT Semiconductor PACKAGE MECHANICAL DATA 6\PERO A A1 b c D E E1 E2 L  'LPHQVLRQV,Q0LOOLPHWHUV 0LQ 0D[ 0.510 0.770 0.500 0.700 0.250 0.350 0.080 0.150 0.750 0.850 1.100 1.300 1.500 1.700 0.200 REF 0.010 0.070 7° REF 'LPHQVLRQV,Q,QFKHV 0LQ 0D[ 0.020 0.031 0.020 0.028 0.010 0.014 0.003 0.006 0.030 0.033 0.043 0.051 0.059 0.067 0.008 REF 0.001 0.003 7° REF REEL SPECIFICATION P/N PKG QTY 1N4148WT SOD-523 3000 Compiance 1N4148WT Semiconductor Compiance Attention ■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you before using any MSKSEMI Semiconductor products described or contained herein in such applications. ■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein. ■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment. ■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design. ■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from theauthorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of MSKSEMI Semiconductor. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI Semiconductor productthat you intend to use. www.msksemi.com
1N4148WT 价格&库存
很抱歉,暂时无法提供与“1N4148WT”相匹配的价格&库存,您可以联系我们找货
1N4148WT
  • 50+0.08229
  • 500+0.06567
  • 3000+0.04935
  • 6000+0.04381
  • 24000+0.03909
  • 51000+0.03642
库存:345
