SRRB751S-40
SRRB751S-40
    SALLTECH(萨瑞微)
    SOD-523(SC-79)
    肖特基二极管 40V 30mA SOD523(SC-79)
SRRB751S-40 数据手册
Document:S09D50014 SRRB751S-40 Schottky Barrier Diode Features Mechanical Characteristics  Small Surface Mounting Type  Package: SOD-523  Ideal for Automated Placement  Lead Finish:Matte Tin  Ultrafast Reverse Recovery Time  Case Material: “Green” Molding Compound.  Low Power Losses, High Efficiency  UL Flammability Classification Rating 94V-0  Low Forward Voltage Drop  Moisture Sensitivity: Level 3 per J-STD-020  High Surge Capability  Tape Reel :8000pcs  RoHS Compliant Applications Appearance & Symbol  Low Voltage  High-Frequency Inverters  Free Wheeling  Switching circuit Marking Information 5 5= Marking Code Rev.A02 -1-- www.salltech.com Document:S09D50014 SRRB751S-40 Schottky Barrier Diode Absolute Maximum Ratings (T=25ºC, RH=45%-75%, unless otherwise noted) Parameters Symbol Limit Unit VRRM 40 V VR(RMS) 32 V DC Blocking Voltage VR 40 V Average rectified output current IO 30 mA Non-repetitive Peak Forward Surge Current@t=8.3ms IFSM 0.2 A Power Dissipation PD 150 mW RθJA 320 ℃/W TJ -55 ~ +125 ℃ TSTG -55 ~ +150 ℃ Reverse Voltage (Repetitive Peak) Reverse Voltage (RMS) Thermal Resistance Junction to Ambient(Typ) Operating Junction temperature Storage Temperature Range Electrical Characteristics (T=25ºC, RH=45%-75%, unless otherwise noted) Parameter Symbol Test Condition Min Typ Max Unit V VBR IR = 1mA Reverse Leakage Current IR VR = 30V 0.5 uA Forward Voltage VF IF = 1mA 0.37 V Total Capacitance CT VR=1V, f=1MHz Reverse Breakdown Voltage Rev.A02 -2-- 40 2 p'F www.salltech.com Document:S09D50014 SRRB751S-40 Schottky Barrier Diode Typical Characteristics Rev.A02 -3-- www.salltech.com Document:S09D50014 SRRB751S-40 Schottky Barrier Diode Soldering parameters Pb-Free assembly (see as bellow) Reflow Condition Pre Heat +150℃ -Temperature Max(Ts(max)) +200℃ -Time (Min to Max) (ts) 60-180 secs. Average ramp up rate (Liquid us Temp (TL) to peak) 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max Reflow Rev.A02 -Temperature Min (Ts(min)) -Temperature(TL) (Liquid us) +217℃ -Temperature(tL) 60-150 secs. Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃ of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ -4-- www.salltech.com Document:S09D50014 SRRB751S-40 Schottky Barrier Diode Package mechanical data Symbol Millimeters Min. Max. A 0.50 0.70 A1 0 0.05 D 0.70 0.90 E 1.1 1.3 E1 1.5 1.7 b 0.25 0.35 c 0.08 0.15 L 0.12 0.28 L1 (0.3) Suggested Land Pattern Symbol Rev.A02 -5-- Dimension in Millimeters Typ. X (0.6) Y (0.7) P (1.42) www.salltech.com Document:S09D50014 SRRB751S-40 Schottky Barrier Diode Tape & reel specification - SOD-523 Symbol Dimension in Millimeters Tape D0 1.50+0.10/-0.00 E 1.75±0.10 F 3.50±0.10 P0 4.00±0.10 P1 2.00±0.10 P2 2.00±0.10 W 8.00+0.3/-0.1 D 178.0±2.00 D1 54.40±1.00 D2 13.00±1.00 W1 9.50±1.00 W2 12.30±1.00 Reel Contact information Jiangxi Salltech Microelectronics Technology Co.,Ltd. N0.699 Huangtang East Street,Ganjiang New District, Nanchang city,jiangxi province Tel: +86-791-83962891 Fax: +86-791-83962890 Rev.A02 -6-- www.salltech.com
SRRB751S-40 价格&库存
很抱歉,暂时无法提供与“SRRB751S-40”相匹配的价格&库存,您可以联系我们找货
